09-14-2022, 11:58 AM | #155 |
Supreme Allied Commander
3890
Rep 54,576
Drives: F80 M3
Drive a Tesla Model 3 or Model Y as well? PM us for Swift spring upgrade for your Ohlins Road & Track, KW V3 or MCS.
09-19-2022, 03:09 PM | #156 |
3890
Rep 54,576
Drives: F80 M3
We may have access to a couple kits that landed State side recently. Please PM if you are looking for a set, they won't last. Those who placed pre-orders, your order is on its way and tracking sent to you.
The main/larger shipment is still coming Jan. 2023. |
10-28-2022, 01:03 PM | #158 |
3890
Rep 54,576
Drives: F80 M3
All sold, but a few more kits are coming in on 12/9. PM to place your order.
11-10-2022, 12:31 PM | #161 |
3890
Rep 54,576
Drives: F80 M3
This is the latest step in the Öhlins Racing automotive philosophy – Road&Track by Öhlins.
A more than 30 year long tradition of high-end racing commitments and state-of-the-art solutions within advanced suspension technology is now available for street cars all over the world. The focus has been clear from the very beginning – superior road handling without sacrificing comfort in your day-to-day transports. The time of compromises are over! We have also added a clever light-weight design with a majority of the parts in aluminium and on top of that all shocks have suffered through vast corrosion tests according to ISO 9227. The end result is a 2-year limited warranty on all of our products - worldwide. BMS MU00(Worldwide) or BMS MU00S1(USA) General > DFV (Dual Flow Valve) > Rebuildable > Corrosion salt spray tested (ISO 9227) > 2 year Limited Warranty Front > McPherson Strut > Single bleed adjuster > Spring preload adjuster (approx. 20-30 mm lower than standard > Coil Springs (rate 80N/mm) > Dustcovers > Use with original top mounts Rear > Conventional Shock Absorber > Single bleed adjuster > Separate spring preload adjuster (approx. 20-30 mm lower than standard) > Coil Springs (rate 140 N/mm)(Additional springs at the rate of your choice will be supplied at no additional cost) > Dustcovers > Use with original top mounts F2x F3x (X-drive and RWD) 1-series (F20,F21) 2-series (F22,F23) 3-series (F30,F31,F34,F35,G20,G21) 4-series (F32,F33,F36) ***Vehicle with EDC will need to have EDC coded out*** ***We can ship the standard kit worldwide at a very discounted rate. PM us your address for a quote!*** BMS MU00S1 |
11-23-2022, 02:15 PM | #163 |
3890
Rep 54,576
Drives: F80 M3
These are once again sold out. Next batch due in Feb. of 2023.
PM us on very special pricing for E8x E9x none M and F8X M R&T pricing. |
11-28-2022, 04:51 PM | #164 |
3890
Rep 54,576
Drives: F80 M3
Ohlins out of the box spring rates ride just fine. Still softer than Sport+ on 10 clicks open.
12-04-2022, 08:32 PM | #165 |
3890
Rep 54,576
Drives: F80 M3
A more than 30 year long tradition of high-end racing commitments and state-of-the-art solutions within advanced suspension technology is now available for street cars all over the world. The focus has been clear from the very beginning – superior road handling without sacrificing comfort in your day-to-day transports. The time of compromises are over! We have also added a clever light-weight design with a majority of the parts in aluminium and on top of that all shocks have suffered through vast corrosion tests according to ISO 9227. The end result is a 2-year limited warranty on all of our products - worldwide. BMS MU00(Worldwide) or BMS MU00S1(USA) General > DFV (Dual Flow Valve) > Rebuildable > Corrosion salt spray tested (ISO 9227) > 2 year Limited Warranty Front > McPherson Strut > Single bleed adjuster > Spring preload adjuster (approx. 20-30 mm lower than standard > Coil Springs (rate 80N/mm) > Dustcovers > Use with original top mounts Rear > Conventional Shock Absorber > Single bleed adjuster > Separate spring preload adjuster (approx. 20-30 mm lower than standard) > Coil Springs (rate 140 N/mm)(Additional springs at the rate of your choice will be supplied at no additional cost) > Dustcovers > Use with original top mounts F2x F3x (X-drive and RWD) 1-series (F20,F21) 2-series (F22,F23) 3-series (F30,F31,F34,F35,G20,G21) 4-series (F32,F33,F36) Landing Stateside in August. ***Vehicle with EDC will need to have EDC coded out*** ***We can ship the standard kit worldwide at a very discounted rate. PM us your address for a quote!*** BMS MU00S1 |
03-08-2023, 08:06 PM | #169 |
3890
Rep 54,576
Drives: F80 M3
Very very special pricing on Ohlins Road and Track for all applications. Order must be submitted by the end of the business day on March 12th.
PM for a quote! |
03-10-2023, 11:43 AM | #170 |
3890
Rep 54,576
Drives: F80 M3
PM for a quote! |
05-16-2023, 03:19 PM | #172 |
3890
Rep 54,576
Drives: F80 M3
Another Ohlins R&T(OEM rates) with Vorshlag camber plates going on F22 M240i
