      02-21-2018, 04:32 PM   #155
tjswarbrick
<(O0=[][]=0O)>
tjswarbrick's Avatar
Drives: 2012 N55 E88
Originally Posted by Mandinca View Post
Yes, that does help, a lot !
You removed the rear spacers due to rubbing....fender rubbing ? How bad was it and would a 10mm or maybe 6 or 8mm have worked ?
I'm sorry, I just noticed that you said the winglets are 2.5" off the ground, can you measure from ground to jack point ? (do you still have the plastic moulded pieces attached to the car?)
That winglet measurement doesn't make sense to me. Your fender lip height is the same as mine but your winglet is 2.5 and mine are 3.5.
Thanks.
I re-measured the winglets. Mis-read the markings on the tape measure - I've got 3.25" clearance under them (with completely worn, about to be replaced, 225/40 MPSS.)
Don't have enough clearance to get a good read on the front jack point.
Harbor Freight steel 3-ton low-profile floor jack has about an inch of clearance before hitting the pad. So probably right around 4" above the ground. But that's not a very accurate measurement.
2012 E88 M-Sport 135i DSB Metallic
COBB CP, ZHP Knob, E60 SSK Lever, E92 M3 FSB, RSFB inserts, Koni Sport, Eibach Pro, UCP, MPSS, AP axle-back, MHD Stage1+ 91
<(O0=[][]=0O)>
      02-22-2018, 12:33 PM   #156
Mandinca
Drives: 2008 E88 and 2016 F85
Thanks, all this is very useful information for me to make a properly informed decision. It looks like we have all the same ride height characteristics so I can swap my set up to one similar to yours and hopefully stiffen up the ride while eliminating the rubbing, which is exactly what I want to do !
Last question, then I'm done.
Did you need to use the camber plates or did you just do it anyway ?
      02-22-2018, 01:11 PM   #157
tjswarbrick
<(O0=[][]=0O)>
I currently have -1.6 and -1.7 deg negative camber up front. For that, I needed the plates.
I think it's a bit too much for DD / street use.
At 21k miles, front tire inner shoulders are worn to the cords, but I'm not to the wear bars yet on the tread.
So, after getting new front tires on Saturday, I'm going to have it backed off to -1.2 or -1.3 degrees.
I'm not an expert, but I don't believe that camber plates are required for that level of negative camber, though you'll probably need to remove the camber pins. From what I understand, using the Dinan plates to get that level of negative camber puts me in the middle of the adjustment range. Without, you'd be at the far end of available camber.
But you'll want to do some more reading to make sure I'm not blowing smoke (or remembering it wrong.)
I do note that people say they add about a 1/4 inch of height to the front end. So I wouldn't mount the Swift's without 'em. Even with, I wouldn't mind a little more clearance up front.
<(O0=[][]=0O)>
      02-22-2018, 01:28 PM   #158
Mandinca
I'm not looking to track it or even drive it particularly hard as a DD, just go with the stock alignment - assuming the konis and swifts will allow it....will they ? As I said earlier, I'm a complete noob when it comes to suspension. I saw the pics you posted and thought, that's exactly the "look" I want. I doubt your negative camber is even visible in the pics.
      02-22-2018, 01:37 PM   #159
tjswarbrick
<(O0=[][]=0O)>
I was wrong about the available negative camber.
http://www.1addicts.com/forums/showthread.php?t=399902
I think you'll need some just due to the lowering. How much is clearly up for debate, and a matter of personal preference.
If you don't add spacers, I don't imagine clearance will be an issue regardless.
<(O0=[][]=0O)>
      02-22-2018, 02:01 PM   #160
Mandinca
Oh I think I see, if I use the spacers then the neg camber pulls the top of the tires inwards so they don't rub ?
      09-06-2019, 01:36 PM   #161
GO444
Breitling
GO444's Avatar
Germany
27
Drives: BMW 1 Cabrio
Having Fun In Germany
b1aze565.50
      02-19-2020, 01:57 AM   #162
Skotcoop
Skotcoop's Avatar
Drives: G01
Originally Posted by mjovic View Post
Eibach Pro-Kit
This looks sick. I ordered my set today. Curious how much drop you went with and what size tires you're running and if spacers or not. Also did you use a camber plate up front?
2010 135i M-sport SOLD
2019 X3 M40i Glacier silver w/cognac
      02-19-2020, 02:17 AM   #163
Skotcoop
Skotcoop's Avatar
Drives: G01
Originally Posted by Chandon View Post
Bilstein B14
What wheels are those?
