12-22-2022, 12:36 PM | #158 |
Supreme Allied Commander
3893
Rep 54,602
Drives: F80 M3
Swift's flagship products that made Swift a regular name in the worlds most famous racing series. These products have been the child for over 80 years of industrial spring experience. Hundreds of engineers proven concepts and theories were materialized in this springs development. The end, the product is the lightest, most durable, and the most linear spring rate on the market.
While most track racers have already began the ritual of swapping their springs, many swap from one brand to another let you notice the stiffness only as being either softer or harder. What if a spring could change other dynamics, such as a noticeably lighter unsprung mass, smoother weight transferring, better ride quality, lower tire temperature, and increased ability to anticipate vehicle reaction? Like most racers, Swift team hates to hear ?what if?, so they built the ?what if? into reality. All of the Swift Springs are made with our exclusive material called H5S.TW. Without this specially designed material, our light weight spring design does not exist. Our metric coilover springs are measured and rated in the metric system. The metric system is used widely in the sports compact market, and therefore we want to provide an easy understanding for the suspension tuners. We offer the widest range of metric coilover springs from 3kg through 34kg in various inner diameter and springs length. The diameter, length, and rates that we offer will cover users with a need of a daily comfortable commute, up to world class racing machines. Which ever suites the needs of the individual! Note: Spring sold as each. Available in 60, 65 and 70mm ID. Please specify static height and rate desired or call if you have any questions. |
02-21-2024, 11:16 AM | #174 |
3893
Rep 54,602
Drives: F80 M3
While most track racers have already began the ritual of swapping their springs, many swap from one brand to another let you notice the stiffness only as being either softer or harder. What if a spring could change other dynamics, such as a noticeably lighter unsprung mass, smoother weight transferring, better ride quality, lower tire temperature, and increased ability to anticipate vehicle reaction? Like most racers, Swift team hates to hear ?what if?, so they built the ?what if? into reality. All of the Swift Springs are made with our exclusive material called H5S.TW. Without this specially designed material, our light weight spring design does not exist. Our metric coilover springs are measured and rated in the metric system. The metric system is used widely in the sports compact market, and therefore we want to provide an easy understanding for the suspension tuners. We offer the widest range of metric coilover springs from 3kg through 34kg in various inner diameter and springs length. The diameter, length, and rates that we offer will cover users with a need of a daily comfortable commute, up to world class racing machines. Which ever suites the needs of the individual! Note: Spring sold as each. Available in 60, 65 and 70mm ID. Please specify static height and rate desired or call if you have any questions. Wholesale and international orders welcome. |
