10-31-2022, 01:32 PM | #17711 |
Rep 474
Drives: 2009 128i 6MT
Good move replacing the jack points. One of mine broke while on a stand and it made for a very bad day...
10-31-2022, 01:38 PM | #17712 |
Rep 474
Replaced my 6FL port with the newest P/N. Had tons of issues including static/distortion and one side of the audio cutting out until you cranked up the volume which were driving me up the wall.
After install and some brief testing the new ports seem to have fixed my issues. Not really surprised cause using the old aux port was like throwing a hotdog down a hallway while the new one is nice and snug. New port also seems to have improved clarity a bit. Could be a placebo, but wouldn't be surprised if the much more solid connection did result in an improvement Also swapped back the broomstick back to the ZHP knob once again. Been flip flopping between the two for a while but I think I've finally settled on the ZHP. |
Fishee1059.50 |
10-31-2022, 06:09 PM | #17713 |
Слава Украине!
2336
Rep 2,443
Finally made it out. Thunderhill West, 16 October.
Papa Popov319.50 ________4163.50 Fishee1059.50 1and11865.50 Donkeyshins384.00 mkeiser505.50 Afam28302.50 desertman1232215.50 Kowalski20111194.50 MaC-N54-E82495.50 Fakemike369.50 |
10-31-2022, 09:01 PM | #17714 |
________
4164
Rep 2,301
Oil change.
Sometimes I’ll pour a quart of the new oil in the filter housing while the old oil is draining, to flush out the ducts from the old oil… too much? Oh well lol makes me feel better |
Fishee1059.50 tjswarbrick762.00 |
11-01-2022, 11:37 AM | #17715 | |
54
Rep 105
11-01-2022, 04:00 PM | #17717 | |
Loves me some MHD!
1866
Rep 1,726
Interesting... I was just looking at mine the other day wondering if that's a thing that needs cleaning... like a sunroof maintenance item. But yeah, they've been there as long as I've owned my 1er
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla . . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg |
WrathOTM553.00 |
11-01-2022, 04:55 PM | #17719 |
Loves me some MHD!
1866
Rep 1,726
Huh...., nifty
Not sure if it matters, but mine is a super early 2009 model year Basically 9 or 10/2008, so it has the y1ot1 start button bezel, but has the bigger '09 nav screen. As far as I know those things were OE and I'd be surprised to find it was a cost cutting exercise on the 128!
1and1
11-01-2022, 07:53 PM | #17720 |
Rep 3,651
Swapped the manual transmission fluid tonight, going from MTF-LT2 to try the Redline D4. After a lot of reading and chatting with Redline the D4 was worth a try. See if I can shift a little better in winter (I do actually drive the car occasionally if the roads are clear - no snow or salt).
Going to do the oil tomorrow, it's been only a couple thousand miles but it's been a year. I stuck it in a different thread specific to the gearbox oil, but if anyone here knows... for a 135i, manual trans fluid, I only got about 1.25 or so quarts put back in before it came out the fill plug hole. Car was level (ramps front, stands back). I didn't allow the old stuff to drain forever, but the majority of it was certainly gone. Does that sound right? I was expecting to get closer to 2 quarts in. And no I wasn't doing the rear diff or anything, I was under the shifter, maybe forward a foot or so, with the pair of 8mm allen plugs and etc. |
mkeiser505.50 |
11-02-2022, 06:37 AM | #17722 | |
Rep 458
tracer bullet2545.00 |
11-02-2022, 07:36 AM | #17723 |
Rep 3,651
Yeah I think it's that simple. It's funny I'm 2nd guessing it. The little bit of reservoir at the bottom of the transmission case before it hits the fill port is really short / small. I knew before I got started that it wasn't really going to hold much.
11-02-2022, 10:14 AM | #17724 | |
Rep 493
Pretty noticeable difference, and improvement over stock. I think I used around 1.75L, give or take. Can check what's remaining in the bottle if you like. |
11-02-2022, 01:11 PM | #17726 |
Rep 783
Drives: 2010 328ix E91, 2011 128i E82
When I bought Little Red, my 2011 128i, a year ago, it had all kinds of ABS and traction control warnings on and could not be driven unless traction control was turned off. The sensors were good so I decided it was the reluctor rings on the axles that the sensors were reading - they had corrosion built up under them and were throwing off the sensors. Quick fix was shimming the sensor out with a washer but long-term fix would be replacing the axles (yes, you can pull the old axles and install new rings but with 141K miles better to just put in new axles). I finally got started on the job a couple of weeks ago, and, as is often the case, getting the old parts off was the most difficult part of the job (so far). I started on the right side (that is where the codes related to the problem were coming from), but could not get the axle out of the splines - it was seized in good. I had been questioning whether I should also do the bearings and hubs (and the control arms/bushings) but that was going to ramp up the cost significantly. Fate made the decision for me with the seized axle. Poking around on the auction site I found entire assemblies for sale - knuckles, bearings, hubs, all control arms, and axles for a reasonable price (I had the seller separate the axles and keep them since I already had my new ones). They were newer (90K miles) and cleaner/less rusty (off a Texas car) so I went that route. Biggest obstacle I had was the toe arm bolt to the subframe was seized and had to be cut out with a reciprocating saw. I've got the right side on, with the exception of the eccentric bolt for the toe arm (I ordered the wrong part so correct one is on its way). While I wait for the needed bolts, I tried separating the old axle from the old assembly. It took a puller/pusher tool, a lot of penetrating oil, and a lot of banging but I did eventually get it: Inspecting under the rings, it certainly did look nasty: The new axles from GKN have solved the corrosion problem but making the ring an integral part of the axle housing (i.e., molded or cast in) rather than a separate ring. The old knuckle - I'll have to get the old hub and bearing out and then get it cleaned up and maybe it will be worth something - new ones go for over $800, so . . . maybe . . . I'm taking the opportunity while everything is out to clean and paint the brake calipers/brackets (just going with black) and then will switch out the brake lines to braided stainless and do a brake bleed/flush. I won't be able to get back to it until next week so Little Red will sit up on the Quickjack for another few days.
K9Leader 2010 328i x-Drive, E91 - Space Gray/Black 2011 128i E82 6MT - Crimson Red/Black |
11-03-2022, 08:22 AM | #17727 |
115
Rep 100
Been there, done that! While you're there, you may want to check and make sure the 4 eccentric bolts used for adjusting the alignment can rotate and are not seized. I'd even recommend that you replace them regardless, as a preventative maintenance thing. I had to cut 2 of the bolts and one snapped because they were seized. When I dropped my rear subframe to totally rebuil the rear suspension, including replacing all 13 pressed in bushings, the rusted fasteners were the biggest problem.
11-03-2022, 10:13 AM | #17728 |
Rep 3,651
Wash & wax. Put the winter wheels and tires on. Oil showed up, Liqui Moly 0W40 LL-01 from FCP, and so that finally got put in.
Car is tip top! |
11-03-2022, 11:19 AM | #17729 |
506
Rep 324
11-04-2022, 01:21 PM | #17730 | |
Rep 19
N55135i306.00 |
11-04-2022, 05:23 PM | #17731 |
Rep 1,017
As long as you code them out, it's no problem at all. It's relatively easy to do as long as you have an OBD adapter.
Official BMWP Whore - BMWP suspension kit w/ M3 arms, BMWP big brake kit, BMWP intake w/Mishimoto tube, BMWP exhaust, BMWP carbon strut brace, BMWP short shifter, and BMWP carbon spoiler. OZ Leggera HLT w/ 245 square setup.
11-04-2022, 06:59 PM | #17732 | |
Rep 783
