05-19-2022, 11:55 AM | #177 |
Rep 818
Drives: BMW X5 XDrive35i
5/19/2022
Had an oil analysis completed by Blackstone Labs. Honestly couldn't have asked for a better result, huge sigh of relief.
2017 X5 XDrive35i X-Line | Sophisto Grey | MHD Full Flexfuel Tuned | Mosselman Turbo| Sutphin Tuning TCU | Nostrum Stage 2 HPFP | ER Charge Pipe | BimmerHausPerformance Intake and Inlet | ApexBuilt Catted DP | VRSF FMIC | Zeitronix Flexfuel Kit | KateCool Oil Cooler | Variant Wheels | Conti DWS06+ |
M302_imola844.50 |
05-19-2022, 11:57 AM | #178 |
Rep 1,497
06-02-2022, 12:26 PM | #179 |
Rep 818
6/2/22
Today was Dyno day! We tested the E50 blend using 3 runs. As you'll see in the graphs, Run 1 was a throwaway because the car was adjusting to the AWD Mustang Dyno. Runs 2 and 3 were VERY consistent and therefore deemed valid. Because it was an AWD Dyno, even having XDelete enabled disabling XDrive, we still had to put the car in test mode via the gauge cluster. I'm also told Mustang dyno's read lower than DynoJets and no correction factor was applied other than SAE corrections. Final numbers were 400WHP/492WTQ. Not bad for a big old pig with an N55.
06-02-2022, 06:56 PM | #180 | |
Rep 942
Drives: 2016 BMW X5
06-02-2022, 07:56 PM | #181 |
Rep 818
I actually did not too long ago , dragy attached !
FCX52410.50 parthpatel1556.50 |
06-02-2022, 08:09 PM | #182 |
Rep 942
Drives: 2016 BMW X5
Wow. 4 seconds is incredible. Can you share (keep in mind I am a relative lay person when it comes to some of this) exactly what you had to upgrade to accomplish this output? How much concern is there to impact to longevity? Obviously performance and longevity always work antagonistically, but nonetheless.
06-03-2022, 03:09 AM | #185 |
557
Rep 296
06-03-2022, 10:07 AM | #186 | |
Rep 818
06-03-2022, 10:10 AM | #187 |
Rep 818
Nah, leaving that to the pros lol.
06-03-2022, 10:13 AM | #188 | |
Rep 818
1) just for my own peace of mind to make sure I didn't need to address anything regarding the rod bearings since we're at 50k miles now. 2) a health check since we've turned it up quite a bit and plan on doing a bit more so in the future.
parthpatel1556.50 |
06-03-2022, 12:50 PM | #189 |
39
Rep 123
I was looking at a E85 tune, but not enough gas stations nearby… Have you tried that vs the E50? Also, if you don't mind me asking, who do you have doing the custom tune?
06-03-2022, 12:57 PM | #190 | |
Rep 818
A member of our forum made the tune for me! Paging WOT808
whoismorggan555.00 Monkeypoop39.00 |
06-03-2022, 01:02 PM | #191 |
Rep 1,532
That's an insane time for an N55 X5. Nice.
2013 335is Mineral/Coral - DR 6466 - DR Mani - PI - Motiv FF - Dodson Clutches - OEM CF Roof - M3 GTS DCT/LSD/DS/Halfshafts/Suspension/Subframe/Brakes/Chassis Bracing F+R - DEFIV Diff Brace - 437M/R888R
2015 X5 35D - 1990 535i [RIP] - 1992 318i Convertible - 2002 540i/6 |
sukhk5272205.50 |
06-03-2022, 01:52 PM | #192 |
Rep 818
Thanks man! I'm on a quest to break 3's so with a bit more driver mod and some lightweight wheels I think we can get there.
06-03-2022, 01:56 PM | #193 | |
Bimmer Nut + Software Dev
555
Rep 802
Drives: 2018 Audi S3 IE Stage 1
Current: 2018 Audi S3 IE Stage 1
Past: '08 Infiniti G37S, '87 Porsche 944 Turbo, '13 328i, '15 M235i, '15 F80 M3, '16 M235i, '15 335i, '17 X5 xDrive35i @whoismorggan |
06-03-2022, 02:06 PM | #194 | |
Rep 818
whoismorggan555.00 |
06-03-2022, 05:24 PM | #195 |
555
Rep 802
I wish it wasn't $1,600. Would be nice to fill up with E85 since it's $2 cheaper than 93 😄
sukhk5272205.50 |
06-04-2022, 03:36 PM | #196 | |
214
Rep 96
You're right, a 'stage 2' hpfp is the best option for full e85 on the stock turbo. You can run full e85 on one of the stage 1 hpfps or even the stock pump but will have to limit boost so that the HPFP pressure doesn't dip low enough to misfire. The lpfp in EWG cars seem to handle e85 well into the low 400s just fine.
S55 and N55
Monkeypoop39.00 |
06-08-2022, 10:30 AM | #197 | |
Rep 1,497
You make me want to spend more money, therefore I hate you |
06-08-2022, 11:19 AM | #198 | ||
351
Rep 383
M302_imola844.50 |
