HPFP failure FAQ!
03-07-2010, 09:32 PM | #178 |
Rep 5,018
Drives: VALNCYA
itS going back into dealer.
it has not started 3 times for me since my last service, now a BMW Tech is going to be there when the car is serviced 3rd times a charm, i hope we can get this resolved :? Last edited by MusclezMarinara; 03-16-2010 at 11:08 AM.. |
03-08-2010, 10:12 PM | #179 |
Rep 1,759
Lately my car has been taking longer to crank over in the morning, even in warmer weather at times. Never got a 1/2 engine light, no limp modes, no SES light, etc. Do you think it could just be time to change the spark plugs or is it more common to be early stages of a faulty HPFP? I'm JB3 tuned btw.
03-09-2010, 03:19 AM | #180 | |
Rep 458
03-09-2010, 07:58 AM | #181 | |
153
Rep 390
03-10-2010, 10:51 AM | #182 |
Rep 4,244
i have a 2010 with 1200 miles and it's been taking a long time for the car to start. noticed it happens primarily in the morning and when it the car has been sitting around for hours. if i turn off the car and start it again immediately then it starts normally. let's see if the dealer is willing to run some tests for me.
2010 E92 BSM 335i | M-Sport | ST Coils | Linea Corse Lemans | Cobb AP | BMS DCI | Cyba Tips
03-11-2010, 11:34 AM | #183 |
Rep 1,754
Just had the pump on my '08 replaced -- car was in for a different problem, and I reported continuing long cranks in the morning. No codes. They pressure-tested the pump and it failed. Now I have the new one...let's cross our fingers and toes that fixes it!
03-14-2010, 02:46 PM | #184 |
56
Rep 45
At 56k miles in 21 months of ownership my June 08 335i M sport was showing no signs of the infamous HPFP failure, perfect idle, perfect start everytime, but just over a week ago it started throwing up the emissions light. Took it straight to my dealer and they could find nothing wrong, and cleared the light.
Following morning on way to work it flashed up engine malfunction and went immediately into limp mode, before almost stalling in front of oncoming traffic at a T-junction. Called BMW emergency services and their technician spent over an hour trying to trace a fault before it threw an ECU software code when stalling at idle. Car was recovered to dealer, and after a day of testing it apparently showed that all four O2 sensors (either side of the Cat) recorded that the car was running too lean and that they believed the HPFP was the cause. Have now installed the new pump (943) but still cant have car back, as it now shows that the injectors are not working correctly and these are on back order. |
03-15-2010, 12:37 PM | #185 | |
Rep 1,938
03-16-2010, 07:28 PM | #186 |
Rep 315
Just for reference, my old 2008 had the HPFP fail with 149 miles on the odometer. Anyone have fewer miles than that?
'10 335i sedan/AW/Premium/M-Sport/Steptronic/Active Steering/6FL/Logic7/Sirius/heated seats/rear fold seat/alarm/Navi/Performance Power Kit
03-16-2010, 08:59 PM | #187 |
Rep 1,938
To me it looks you hold the record, but there are people following the sticky who may now someone even less lucky. I hope the pump you are running now will serve you better. Good luck.
03-17-2010, 12:42 PM | #188 |
21
Rep 91
My neighbor's 535xi failed at 87 miles in her driveway
03-17-2010, 01:09 PM | #189 |
Rep 1,938
I stand corrected. My hope that the pump would last at least 150 miles was clearly unrealistic and futile - I gather the true record is zero miles travelled.
03-17-2010, 03:00 PM | #190 |
Rep 144
Is anyone aware of a new SIB for the long cranks. I took in my car for the summer tires swap and talked to the SA about long cranks once in a while. They had reprogrammed the DME with the new SIB and the SA told me that this will fix the HPFP issues. FYI, My car has the 881 HPFP.
2006 Z4 3.0i, 2006 Z4M Roadster,2006 X5 3.0i
Gone: 2005 M3 ZCP,2007 Cayman S Last edited by White_335I; 03-17-2010 at 03:14 PM.. |
03-17-2010, 03:33 PM | #191 | |
111
Rep 2,164
Drives: 2020 BMW 330i xDrive
My 09' just was in for this. However, I got poor throttle response from it. they are checking the issue as we speak.
Former BMW Client Advisor
03-17-2010, 05:46 PM | #192 |
Rep 5,018
Drives: VALNCYA
so now BMW dealer says it was a "Low pressure sensor" lets see what happens
03-17-2010, 09:14 PM | #193 | |
Rep 144
Do you know the pump number in your car?
Gone: 2005 M3 ZCP,2007 Cayman S |
03-17-2010, 11:32 PM | #194 | |
Rep 30
03-23-2010, 03:39 PM | #196 |
Rep 698
Drives: you crazy..
Garage List 2019 BMW M2 Competi ... [0.00]
(SOLD) 2016 BMW M235i [10.00] (SOLD) 2015 BMW M4 [10.00] (SOLD) 2008 e93 M3 [10.00] (SOLD) 2007 e92 335i [6.50] (SOLD) 2003 e46 325i [10.00] |
A couple of weeks ago I've had 3 different long cranks with an interval of 200-300miles..
So basically there's no pattern.. It stopped doing the long crank last week and it's been 600miles now since the last long crank that I had.. I took it to the dealer yesterday(that's the only time I have) and the indicated Fault 2FBF PRESENT. Following Diagnosis as per SIB 11 55 06, Vehicle REQUIRES PROGRAMMING. PROGRAMMING NOT POSSIBLE DUE TO AFTERMARKET EQUIPMENT INSTALLATION. - The aftermarket installation that they're refering to is the Pioneer Z110 stereo that I have. My SA mentioned that it requires the original stock stereo for them to perform the software update. I have the stock stereo but it's just hidden under my compartment. My questions are: - What does the SIB 11 55 06 contain? Does anyone have a copy of it? - Does it really require the stock stereo to be present in order to perform the upgrade? - I'm not sure what version I'm in right now but do I have to have the upgrade installed? I'm already in 49,400mi... Anyone help? I'll open up a thread if I don't get an answer around... Thanks in advance... Last edited by punky8d; 03-23-2010 at 03:49 PM.. |
03-24-2010, 01:04 PM | #197 |
22
Rep 367
I took my o7 335i to the dealer for long cranks/half check engine light as well as the dreaded wastegate rattle. Now they call me a day later telling me they changes the software to fix the crank/engine light issue, but they can't replicate the rattling sound.
Come on, the rattle is soo clearly audible it's bulshit thati have to go back down there and argue with them. What's the most recent bulletin for the HPFP and what does it say to do? I want to show it to them because I think they either 1) changed the pump and are not telling me because it will be the 4th pump replaced on my 20k mile car 2) they reall. Did just reprogram it Regardless I need to have them replace the pump so if someone could direct me to the most recent bulletin that would be great |
03-25-2010, 09:18 AM | #198 |
786
Rep 2,639
...well long cranks and some stuttery acceleration and i knew it was the pump again, thanks to warranty... my punp (HPFP) #4 is...
13-51-7-594-943 .... so it looks like i recieved the "new" version, car is running like a charm, I hope this one lasts a while :-) ~Frost
M240i Coupe (6MT) (2021: 6/2021 build )
Accord Coupe (6MT) (2017) 335i Coupe (6MT) (2007: 9/06 build SOLD 8/2016) Prelude (5MT) (1995) |
