Ask a Professional Detailer...
07-25-2007, 03:34 PM | #177 | |
Rep 151
Drives: 1999 328i, 1995 VW Passat
Re: frequency of clay - 1-2 times per year. I just clayed my 2 cars for the first time, and have decided to go once a year, during my full detail. I'm sure twice a year is fine, and think any more frequency is unnecessary. I bought Clay Magic, and used about 2/3's a bar for a single car. I break off a good sized piece (cut the bar into 15 pieces, and take one), make a sphere of it, flatten, generously spray lubricant onto the 18"x18" area (my comfort zone in terms of size of area to clay at one time), and clay the entire area. Then I flip the clay over, and use it on the next 18"x18" area. I then throw it away - to be used no more. Or, you may want to save it for your windows (good idea). But clay is relatively cheap, and why risk using piece of contaminated clay to add new fine scratches to your finish? Cheers, Ron Last edited by rtjones; 07-27-2007 at 02:40 PM.. Reason: typo |
07-27-2007, 02:27 PM | #178 | |
361
Rep 5,052
Say you used a clay bar on your vehicle last month and you drive through a construction zone and you pick up tar and other contamination that does not come off with your typical washing and drying procedure, then it would be appropriate to clay even though you did the previous month. There are very few variations of clay on the market, some are fine grade some are medium grade, but other than that there's not much of a difference. I recommend Ron's advice on chopping the clay up into ~15 pieces and using them once and throwing them away. I just clayed a new vehicle I picked up and neglected to follow that method and did find some minor imperfections added due to the clay process and using 1 piece of clay continuously over the course of the detail. Ron's method would minimize that, and I plan on following that same method next time I use a clay bar on my vehicle. Keep up the great work, and let us know how you make out w/ the paint overspray and your own vehicle. Ron - thanks for chiming in, great advice. George |
07-30-2007, 08:16 PM | #179 |
Rep 9
Hi George,
I am hoping you can help. You'll see that I posted a message to the board related to this but I wanted to see if you have specifically encountered this before first hand. Used Meguiar's conditioner / cleaner on the interior this weekend. I wasn't careful enough and the black seatbelts got oily stains on them. Is there any known way to safely remove the stains? Thanks! |
08-01-2007, 04:41 PM | #180 |
105
Rep 2,317
Thanks for all the advise George. Turns out that it looked like someone spray painted something about 2 feet from the car. Entire car is coated with white spray. It took more than clay to get it off. I had to go to the 3M rubbing compound. It seems to have gotten the paint off. However the car is in worse shape than just that. It seems that they have a tree sap stains on the hood too. If I spend more time with the rubbing compound will that take it off or can you suggest anything more aggressive if need be.
Thanks again. |
08-01-2007, 07:52 PM | #181 | |
Completely obsessed with detailing
299
Rep 15,442
Drives: E90 SG 330i, white Scion tC
and i recently got scratches on the face of one of my rims. It's a funny story but i'll get right to the point. It looks as though only the clear coat was scratched, but it's a bit dirty in there. How would I clean it out and how would I go about bringing it back to its original state? thanks in advance for the detailing wisdom george! |
08-02-2007, 08:44 PM | #182 | |||
361
Rep 5,052
The best solution to light swirls is investing in a Porter Cable 7424 Buffer along with a finishing polish, such as Menzerna PO106ff (one of the best available) or Final Polish II. For your wheels, try using something like Mother's Billet Polish (found locally at any automotive store) or consider using something like P21s Finish Restorer, which works great on scuffs and oxidation, due to its chemical cleaners and micro abrasives. Let us know what you end up using and how you make out with everything. George |
08-02-2007, 09:07 PM | #183 |
299
Rep 15,442
^i used a klasse AIO applied by a buffer and scratch x by hand. neither had any effect. I'll be trying a razor on the window probably tomorrow.
08-02-2007, 09:39 PM | #184 |
52
Rep 2,225
"Menzerna PO106ff (one of the best available) "
Hey George, how aggressive is this polish? I picked up some ugly marks on my hood by a glass chip guy, and Griots #4 didn't quite get the job done. I was going to step down to Griots #3, but thought I'd ask about the Menzerna. Thanks.
07 335i sedan | Steptronic | Black saphire | Terra | ZPP | ZSP | Cold Weather | CA | PDC | Nav | OEM Alarm
08-05-2007, 10:20 AM | #185 | ||
361
Rep 5,052
I haven't used the Griots polishes personally to compare the two unfortunately. George |
08-06-2007, 10:26 PM | #187 |
361
Rep 5,052
BNR32, car looks stunning! Lots of depth and gloss. Nice photo work as well
What were your thoughts on Poorboy's EX compared to other products you've used? Thanks for sharing. George |
08-06-2007, 10:33 PM | #188 |
Rep 1,864
I've used other waxes and sealants before, but poorboys it's really something else! I'm loving how this sealant incorporates the carnuba compound. This gives my colour a real depth and gloss, which I'm always looking for. Thanks again, you now have a dedicated customer!
:rocks: |
08-06-2007, 10:53 PM | #190 |
Rep 1,864
08-06-2007, 11:09 PM | #191 |
Rep 1,657
08-07-2007, 09:00 AM | #192 | |
361
Rep 5,052
George |
08-09-2007, 11:56 AM | #193 |
Rep 3,432
Hey George, I'm new to the whole detailing thing. As of now all I got is Meguiar car wash, Zaino AIO, and Zymol liquid wax. If I do them in order is it good enough for a starter? I'll try Zaino detailing for my next time. Thanks for your help.
08-09-2007, 04:06 PM | #194 | |
361
Rep 5,052
Some things that I think no one should detail without: - Learning the best washing and drying techniques and investing in high quality tools to do so, ie. quality wash mitts, waffle weave drying towels, quality automotive shampoo, and a Grit Guard Insert. This is important because this is where a majority of swirls and other imperfections stem from. - Never let your vehicle go without protection. Between the Z-AIO and Zymol Liquid Wax, you'd want to reapply the Z-AIO every 3 - 4 months, and apply the wax once a month. If it's the typical Zymol Cleaner Wax in a the blue bottle found locally, you might as well not use it with Z-AIO. You will strip off any protection the Z-AIO leaves behind and apply a layer of a less durable protection from the Cleaner Wax. Invest in a high quality carnauba paste wax to layer over the Z-AIO or just leave the Z-AIO alone afterwards. Knowing how long your layer of protection will last is key. If a product says it will last 4 months, I reapply every 3. Durability can vary dramatically based on miles driven, storage, how it is cared for, climate, etc. I always under estimate how long the product says it will last because they often rate them under optimal conditions. You are off to a good start, let me know if there is anything else I can answer to help take your detail to the next level. George |
08-09-2007, 04:21 PM | #195 |
“One finds limits by pushing them”
123
Rep 529
What would you recommend to remove a light coat of dust that builds on the car, after detailing?
MY2019 M2C
Street Bike: Honda Grom. Track Bikes: 02 SV650/09 R6 "It is a shame for a man to grow old without seeing the beauty and strength of which his body is capable" |
08-09-2007, 10:06 PM | #196 | |
361
Rep 5,052
This combination when used correctly, is effective at removing light dustings, while minimizing adding imperfections in the paint. To maximize the usage of the Spray & Wipe, consider a 4oz fine mist bottle, which also makes it convenient to store in your glove box for bird droppings and other forms of unexpected contamination. George |
08-10-2007, 08:22 AM | #197 | |
123
Rep 529
MY2019 M2C
08-14-2007, 08:08 PM | #198 |
52
Rep 2,225
Hey George - ok, I'm ready to pull the trigger on several DI products, but I want to run some things by you first. I've got a black saphire, and I currently have some minor scatches left behind by a glass chip guy (he decided to wipe my hood with what must have been a disgusting towel). I don't need help on the basics, ie car wash/prep, and here's what I'm planning:
1) Fine clay bar with lube......which lube do you suggest?....PB spray and wipe, or something else? 2) SSR2 Medium polish , random orb (I've already tried a light polish, and it didn't get it the job done). 3) SSR1 light polish, random orb 4) Menzerna FMJ, 2 coats, one right after the other, let cure 24 hours. Can I apply this with my orbital? 5) PB Natty Blue (applied by hand). One or 2 coats? Do you have a machine pad that you'd recommend for steps 2, 3, and if possibly, 4? Lastly, my new alloy wheels are about to ship, and I would like to protect them as best I can. Would you suggest your wheel wax, or sealant? Thanks!!!
