Help yourself Software part II
07-09-2022, 01:52 PM | #178 |
Rep 138
anyone ever get ISTA+ 4.32.15 working from this repo? I have it working but get errors when I do basic service tasks like resetting the CBM on my 2016 x5 xdrive50i
I'll get an error like this "Error in testmodule: ABL_LIF_FAHRZEUGDATEN_BATTERIE" usually after it complains of not being able to measure the battery voltage. Whats interesting is that i appear to be able to do more like launch the CBM service reset service if i dont do a complete readout. In fact ive had it complain of low battery voltage when i did this because i didnt have it on a charger or running. Heres the complete error. what stands out to me is this part "This copy of CoreFramework.dll is not licensed !!!" I suspect i missed something in the install process. does anyone have a install guide? Ive been searching around but havent come up with something that looks like its for this specific version/set of files. Code:
System.Exception: Failed to invoke service program. ---> System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.Exception: This copy of CoreFramework.dll is not licensed !!! at BMW.Rheingold.CoreFramework.DatabaseProvider.Vehicle.hasFFM(String checkFFM) at BMW.Rheingold.CoreFramework.VehicleContext.IsSet(IEquipmentLocator equipment) at BMW.Rheingold.Module.ISTA.ABL_GEN_AT6100_BATT_COND.BZE() at BMW.Rheingold.Module.ISTA.ABL_GEN_AT6100_BATT_COND.Konfiguration() at BMW.Rheingold.Module.ISTA.ABL_GEN_AT6100_BATT_COND.Initialisierung() at BMW.Rheingold.Module.ISTA.ABL_GEN_AT6100_BATT_COND.Start(ParameterContainer InParameter, ParameterContainer& OutParameter, ParameterContainer& InAndOutParameter) at BMW.Rheingold.Module.ISTA.ABL_GEN_AT6100_BATT_COND.run(ParameterContainer InParameter, ParameterContainer& OutParameter, ParameterContainer& InAndOutParameter) --- End of inner exception stack trace --- at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at BMW.Rheingold.Module.ISTA.ISTAModule.callModuleRef(String refPath, ParameterContainer inParameters, ParameterContainer& outParameters, ParameterContainer& inAndOutParameters) at BMW.Rheingold.Module.ISTA.ABL_LIF_FAHRZEUGDATEN__BATTERIE.Start(ParameterContainer InParameter, ParameterContainer& OutParameter, ParameterContainer& InAndOutParameter) at BMW.Rheingold.Module.ISTA.ABL_LIF_FAHRZEUGDATEN__BATTERIE.run(ParameterContainer InParameter, ParameterContainer& OutParameter, ParameterContainer& InAndOutParameter) --- End of inner exception stack trace --- at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at BMW.Rheingold.Module.ISTA.IstaServiceProgramInvoker.DoInvoke() --- End of inner exception stack trace --- at BMW.Rheingold.Module.ISTA.IstaServiceProgramInvoker.Invoke() at BMW.Rheingold.Module.ISTA.ModuleBootstrapLoader.InvokeRunMethod(MethodInfo run, Object[] param) at BMW.Rheingold.Module.ISTA.ModuleBootstrapLoader.doIt() |
07-09-2022, 09:20 PM | #179 |
Rep 13,134
When you start getting method errors it may be an indication that you
don't have all the C++ redistributables installed in your operations system. Check the microsoft website to be sure. |
07-11-2022, 07:54 PM | #180 |
Rep 138
any suggestions on what I might be missing? the readme says i just need 2019. Ive got java, .NET 4.8. I went to town and added a bunch of visual C++'s that were listed in another install guide for a different version of ISTA+.
I do not see any of these errors when doing the same tasks on my e90 but thats over the DCAN cable not ethernet. Ive also checked MD5's on the install files... |
07-11-2022, 08:24 PM | #181 |
15
Rep 82
My only suggestions is to try some AIO (all-in-one) runtime files. There are some good ones that look at what you've got installed, uninstall any old versions and install all newer or missing versions. Majorgeeks is a good source, and I found another good one I think was from "PC gaming dot de".
My errors were different to yours, but I eventually found that one of the .net files that was already installed had some kind of issue, and manually uninstalling and reinstalling it via the AIO solved it. |
12-12-2022, 02:13 AM | #186 |
Rep 13,134
diagnostic manual ista/inpa
https://www.google.com/url?sa=t&rct=...xo19teM9vkTF-C https://www.google.com/url?sa=t&rct=...7x8H3pN8h1fMuF https://bimmerprofs.com/diagnostics-inpa-part-1/ https://www.google.com/url?sa=t&rct=...lkXEhlQYy4i9Nb https://www.bimmerforums.com/forum/s...-P-actually-do https://www.bimmerfest.com/forums/at...1&d=1590283589 https://www.google.com/url?sa=t&rct=...kBbC27TJLX3BGe https://www.google.com/url?sa=t&rct=...WekqhcC6hsgK2c primary links https://www.e90post.com/forums/showthread.php?t=1681573 https://www.nathansbmwworkshop.com/b...or-dean-videos ista problems https://www.e90post.com/forums/showthread.php?t=1661945 https://www.e90post.com/forums/showthread.php?t=1581663 See ista problems thread See attachment for software links |
06-15-2023, 06:13 PM | #192 |
Rep 2
I need a password to extract ista/p, where do I find it?
Hey I might be a bit late to the party, but does anyone by any chance have a version of ISTA/P I could install?
I attempted to use this one - https://mega.nz/file/Eht3STIJ#SGF2C5...h6gJQg1DhiOJsY But I would download the file, unzip/ extract it. Then when I would run the installer and verify my version of the software, then when I ran the ista loader it is unable to find the ISTA/P file even if I search manually for it, then when I try to extract the 25gb file (I assume is the ista file) I need a password to do so? |
