01-14-2013, 06:03 AM | #2003 |
General
10545
Rep 41,224
Besides newer software, it seems it only works with the Extended Panel Display. If you have the basic KOMBI, it won't work.
01-14-2013, 06:44 AM | #2004 | |
Rep 490
In any case, video is not high in my "wish" list, used to have a headunit on my JDM that could play any format I throw at it, alas I never play any video at all... law abiding |
01-14-2013, 08:10 AM | #2005 |
Rep 84
hi shawnsheridan, I think i have corrupted my FEM_body while doing the angel_light setting.
while reading code, error as followed: FEM_BODY[40] [yyyyyyy] readCPS o.k. cafd_fffffffff-255_255_255 Fehler: file for "cafd_fffffffff-255_255_255" not found! [c012] any solution. thanks 9-: |
01-14-2013, 08:12 AM | #2006 | |
Rep 84
01-14-2013, 08:17 AM | #2007 | |
Rep 490
No corruption yet When are we going to have sg f series coding session? |
01-14-2013, 08:18 AM | #2008 | |
General
10545
Rep 41,224
Try this: Connect => Read FA => Activate FA => Read VCM => Left-Click on FEM_BODY => Click on "Detect CAF for SWE" => Select the CAFD matching your I-Level => Select OK => Right-Click on FEM_BODY (the ECU itself not the underlying CAFD) => Select CODE. To determine your I-Level, go to VCM Module => VCM Master Tab => click Read under I-Steps. The I-Step (current) is the one you want to match when you select the CAFD from the "Detect CAF for SWE" options (e.g. F001-08-09-550).
01-14-2013, 08:19 AM | #2009 |
Rep 490
01-14-2013, 08:29 AM | #2011 | |
General
10545
Rep 41,224
If you do an OEM Retrofit, with 6NF base plate and run the 6NR FBAS Video Lines from the Base Plate to the Head Unit, you will not have Video on the USB Port. If instead you replace the OEM 6FL Aux-In USB Port with the AV-In USB Port from the Mini Cooper, and run FBAS Lines from the USB Port to the Head Unit, and rewire the Combox, then you can have Video on the USB Port.
01-14-2013, 08:34 AM | #2012 | |
Rep 490
01-14-2013, 08:46 AM | #2013 |
General
10545
Rep 41,224
Exactly. I have all of 6NR except Video, and that was fairly cheep, and no hardware modification was needed.
01-14-2013, 09:05 AM | #2014 | |
Rep 84
Hi Shawn, problem solved and new thing learnt. thanks man!!! |
01-14-2013, 09:09 AM | #2015 |
General
10545
Rep 41,224
Alright brother. FYI, You can code your whole car except DME module with the car running, and you never have to worry about maintaining proper voltage to it.
01-14-2013, 09:15 AM | #2016 |
Rep 490
Is there a dictionary of some sort that explains what each of the ecu abbreviations mean? I'm starting to get familiar with a few, combox, Hu, kombi, ihka, fembody. But still generally clueless about the rest
01-14-2013, 11:43 AM | #2017 | ||
Rep 52
[QUOTE=howiegu]
Did this work? |
01-14-2013, 06:33 PM | #2018 |
35
Rep 239
Is it possible to code dvd movie play on the business navi? Or do you really need the pro nav.
Im hoping to recieve my cable this week, but if i would have some information about this i know if i have look for this or not |
01-14-2013, 09:10 PM | #2019 |
Rep 1,544
The business nav unit doesn't have a dvd drive.
01-14-2013, 09:15 PM | #2020 | |
General
10545
Rep 41,224
DME is Digital Motor Electronics, which is why the motor can't be running when DME is coded.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 01-15-2013 at 11:20 AM.. |
01-15-2013, 01:20 AM | #2021 | |
35
Rep 239
01-15-2013, 02:01 AM | #2022 | |
TUGA
84
Rep 119
when I launch INPA or Tool32, I have an warning message from registry: "registry value failed in subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Serial May be there are problems!" just for info, I run the software on a Windows Vista Laptop. I has to launch the installation of the software by select the Windows Xp compatibility. perhaps it is because I select STD:OBD and Com1 during installation?! wich port I must select, to use INPA and Tool32 with a ENET cable on the LAN port? I get my new F30 only on March 15, so I have to wait for test! Thanks again for your help!! |
01-15-2013, 03:49 AM | #2023 |
Rep 122
Drives: F30 320D Sport
Garage List 2006 325iA E90 Sedan [0.00]
1999 320i E46 Sedan [0.00] 1991 318i E36 Sedan [0.00] 2012 320D F30 Sport ... [0.00] |
I think CHAMP has a DVD drive, but it can read only navigation DVD, not video or audio DVD. For audio CHAMP use audio and MP3/WMA CDs.
01-15-2013, 07:33 AM | #2024 | |
14
Rep 64
[QUOTE=dos1973;13306310]
