05-10-2024, 10:04 PM | #21473 |
134
Rep 210
Common cause of front clunk going over bumps/driveway at slow speed/turning is inadequately torqued sway bar end links, might need to torque an additional 5 lb ft on top of factory torque spec.
If you have over 100,000 miles, then change end links. |
05-10-2024, 10:22 PM | #21474 | |
Rep 821
Can't remember the name of that part, something like swivel bearing support. Mine was torqued rotated, making contact to the damper. Untighten the nut in green, rotate it to straighten up, torque down. Be sure that the part itself (in blue) doesn't rotate again when you're torquing. |
05-10-2024, 11:19 PM | #21475 |
Rep 491
Was hard to tell from the video, but seems to be a very different sound.
Car has fresh SPL end links to the sway bars (Hotchkis), which were double checked by the race shop I use. Shop mentioned that front monoballs can make some noise, but this seems to be separate (and the same sound I noticed before the overhaul). Also re-torqued the steering rack bolts last weekend as a check. Basically everything connecting to the knuckles is new, with the exception of struts. Sound happens at all speeds, but it does seem to take time or heat for it to start happening. It's quiet when the car is cold. Once it starts, you start turning, you hear a very noticeable pop or series of pops from one side of the car. I think it comes from the inside wheel during a turn; it affects both sides. If I go over a speed bump, it almost feels like there's a bit of slack in the suspension before the pop occurs. |
05-10-2024, 11:35 PM | #21476 | |
Rep 821
05-11-2024, 07:17 AM | #21477 |
134
Rep 210
If the sound is not present when cold & comes on after some driving would mean it’s not a loose part. Since everything other than the struts is new, maybe check the strut mounts/top hats, they do wear & also need grease..
Maybe post this question in the suspension/chassis/brake section to get better responses.. |
05-11-2024, 09:05 PM | #21478 |
111
Rep 60
Cleaned my engine bay
15
jvictormp921.00 januza79.00 play2lose58.50 CamasM3e933224.00 mym3adventures177.50 B8bydesign689.00 kolosy1559.00 Al Bundy's Dodge1680.00 Smithynigel63.00 PACarGuy686.50 wyatth3554.50 GcD131.50 Zeus69103.00 NiBe463.50 nah dude238.50 |
05-12-2024, 04:35 AM | #21479 |
Rep 7,141
e90sanmarino110.50 |
05-12-2024, 04:10 PM | #21481 |
Friends don't let friends ESS
3224
Rep 888
Drives: '11 Lemans Blue 6mt Harrop e90
Garage List 2011 E90 M3 [9.00]
2003 Porsche 911 Turbo [9.75] 2019 BMW X5 xDrive40i [0.00] 2013 Mercedes E550 ... [0.00] |
Cleaned up my front brake caliper pins, moved my coil over settings to street, and replaced the spark plugs. Getting ready for a little highway adventure.
05-12-2024, 10:12 PM | #21482 |
Rep 1,138
Drives: 2009 E92 M3 Dakar Yellow II
#8 plug and coil always make me rethink my life choices.
05-12-2024, 10:41 PM | #21483 |
1559
Rep 2,085
how do you manage the settings? is it marked on your camber plates, or are you just talking about ride height?
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3 I think I have an M3 problem. |
05-12-2024, 11:12 PM | #21484 |
Rep 1,075
Got my car back a few days ago from mild midlife surgery. Car has 71k on it, 54k of that under my ownership over 9 years.
Slon vanos covers removed, mporium bolt on covers installed. The covers have been eating at me alive since I found a tab that came undone on one of my slon covers. Now it's resolved forever. I don't ever want to think about vanos covers again. Since my harrop supercharger had to be removed for the job, I had everything replaced in the valley of the V. Lifetime throttle actuators, idle air control valve, starter motor and fuel breather. Throttle actuators have about 30k on them (OEM replacements), and they originally went at 43k, so it was getting close to time anyway. Basically all the things you would not want to suddenly go wrong in the middle of nowhere on a m3 with a harrop on it. I enjoy road tripping the car, so this is a major consideration. Finding someone capable of replacing any one of those items and dealing with the harrop could be hundreds of miles away if an incident happens in the wrong place. Doing it yourself requires the venue and the tools. Not a situation I want to be in. Now the car just needs an oil change and detail and we are ready for summer. |
05-12-2024, 11:24 PM | #21485 |
3224
Rep 888
They’re manually adjusted dampers, firm ride on track , little softer for the street. I have front camber plates but haven’t done the work for the track camber yet.
05-13-2024, 05:06 PM | #21486 |
2646
Rep 2,145
Drives: 2011 E92 M3
Bought some fuel. Used some fuel.
Twas a good rip with some friends. 3 E92s and a Shoe all with a view.
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
Ajolives923.50 B8bydesign689.00 jvictormp921.00 PACarGuy686.50 DrFerry6734.50 recentfuture121.50 NiBe463.50 reidetailing645.00 |
05-13-2024, 06:34 PM | #21487 |
1573
Rep 2,871
After 7 hard days at Watkins Glen International within 10 days span, The Rebrake machine is getting some love
05-13-2024, 07:37 PM | #21488 |
Alex - IG @screamer
645
Rep 483
My much awaited documentary of my 2011 E92 M3 in Moonstone Metallic x Rust Brown is finally out.
I really hope you all enjoy the documentary. Drop a like and comment on the video, and consider subscribing to my Youtube channel.
Instagram: @screamer
- 2013 Subaru STi Hatch - White - Racecar - 2011 BMW E92 M3 - Moonstone - Collector Car - 2008 BMW E90 M3 - Silverstone - Racecar |
05-14-2024, 06:22 PM | #21489 |
3224
Rep 888
The nice thing about the K&N is that it’s built to receive the intake receptacle, forming an indisputable seal. This paper filter is the Mahle LX 1590 which is purportedly the oem supplier. Does anyone know of a paper filter with a snug fitting to the intake elbow? See second pic. The Mahle is a contact seal which is prone to leakby if the setup shifts over time.
Update - looked at ~8 paper filter manufacturers and they all have the OEM design for the interface with the intake elbow. Guess that is a K&N innovation. Last edited by CamasM3e93; 05-16-2024 at 08:31 AM.. |
05-15-2024, 08:04 PM | #21490 |
Rep 15
Changed out the thermostat, sensor, fuel breather valve and an oil change last week. Yesterday, hacked up a macht schnell x pipe i got a good deal on and welded on some basically new oem cats. Wanted the secondary delete and better x overall to go with my GT2 catback. It sounds perfect to me
05-19-2024, 10:58 PM | #21491 |
1559
Rep 2,085
replaced the OBD connector after kicking the old one getting out of the car (had a bt dongle plugged in, and forgot about it). those pins SUCK to get out. ended up ripping one after it got wedged in the connector, but thankfully had a matching replacement pin in a rando kit i bought off amazon recently.
jvictormp921.00 |
05-20-2024, 01:48 PM | #21492 |
e90noob
1590
Rep 1,868
https://www.fcpeuro.com/products/bmw...h-0280158164kt is the fuel injector something to replace as preventive maintenance? or just wait until there's an issue?
2008 E90 M3 / LCI trunk + euro tail swap
Production date - 2008-04-22 |
05-20-2024, 02:05 PM | #21493 | |
Rep 1,138
smokinjoe64666.00 CamasM3e933224.00 |
05-20-2024, 03:26 PM | #21494 | |
Naval Aviator
666
Rep 694
Just replaced all injectors along with camshaft position sensors as PM at 76K mls.
e92 M3 - Interlagos Blue | Recaro GTs w/Fox Red Extended |Carbon Leather
Performance Mods: Alpine Stage II; SuperSprint config: non-resonated front+X-pipes+F1s; cat-less; aFe CAI; Bilstein B16s w/EDC; Brembo BBK; AutoSolutions SSK |
