01-19-2013, 10:48 AM | #2135 | |
General
10545
Rep 41,221
48.3 Problems - New Security - New Updated Patch / Token Needed
I am told that new security was added to the 48.3 F20 PSdZData related to E-Sys and the Token validity, which is causing both the inability to save FDL Changes and in some cases the inability to even connect to F20 / F30 cars. So, a new updated Patch / Token is needed to use the new 48.3 PSdZData. That said, I do not think we will see again a "Free" token like the Code Away.EST was made, so get used to the idea of having to pay something (annually) going forward for an E-Sys Patch / Token. If anyone is interested in buying a new updated Patch / Token, PM me. I have a source, and the cost for one version of E-Sys (e.g. E-Sys 3.22.5) with Patch / EST Token Valid for 1 Year from issue date is 50 Euro / $65 USD. Oddly, F10 does not seem affected yet, but I assume it is coming.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 01-19-2013 at 03:26 PM.. |
01-19-2013, 12:18 PM | #2136 | |
671
Rep 1,985
Drives: 2020 G20 320i M Sport
01-19-2013, 01:43 PM | #2138 |
Rep 1,027
Can we use an older version of PZdata then for free still?
I am stuck..and i MUST have my features back.
M Sport Line Estoril Blue
01-19-2013, 02:35 PM | #2139 | |
Rep 1,892
Once you are there, you won't be able to read any of the updated modules with the older dataset. Can you confirm that you are at 12-11-505, or are you at a lower level and just trying to use 48.3? |
01-19-2013, 02:42 PM | #2141 |
General
10545
Rep 41,221
Yes, but same as CIC, you need a 9C FSC Code, and if you also want Video / iPod Out GUI, you need to have FBAS Video Line from either 6NF Base Plate or a modified 6FL USB Port.
01-19-2013, 02:43 PM | #2142 |
General
10545
Rep 41,221
01-19-2013, 02:46 PM | #2143 |
General
10545
Rep 41,221
It isn't common, in fact, Dealers try and avoid programming a car. If there is a SIB (Service Bulletin) that requires new software, they will program it, and if you are having problems with the car, and ISTA troubleshooting directs them to program the car, then they will. Other than that, you won't get new software.
01-19-2013, 02:59 PM | #2144 | |
Rep 1,027
istep current f020-12-11-504 last f020-12-07-533 shipment f020-12-07-530 car was updated yesterday for a NAVI patch and another patch they said
01-19-2013, 03:08 PM | #2145 | |
General
10545
Rep 41,221
Whatever update they did yesterday, it was not full programming or you would have F020-12-11-505. That said, 48.2 may also have the new security in it. All I have heard is switching back to 48.1 if you can solves the issue, but no one I know has switched back to 48.2, probably because 48.3 was released so soon after 48.2, most people skipped 48.2 when they updated. So, 48.2 may have the same issues as 48.3.
01-19-2013, 03:10 PM | #2146 |
Rep 17
01-19-2013, 03:13 PM | #2147 |
General
10545
Rep 41,221
Yes. In my F10, I bought 9C FSC Code, had it imported and activated in CIC, added 6NR, and 6NF since it is required for 6NR, to my VO, wrote VO to car, and coded HU_CUC and CMB_MEDIA, or on this case only HU_NBT.
01-19-2013, 03:25 PM | #2148 |
Rep 1,027
Ok i tried all differnet ways to make my new coding work again..
I bought the new ESYS token and it works!! i am happy.. i was willing to pay for being able to code in the first place..so i am fine with the $65.. Thank you shawn and ANDY
01-19-2013, 03:28 PM | #2149 | |
General
10545
Rep 41,221
Hopefully soon someone with the connection problem will also score the update Patch / Token and confirm it solves that problem too.
01-19-2013, 03:37 PM | #2150 |
Rep 17
01-19-2013, 03:40 PM | #2151 |
Rep 1,027
So where is the NEWEST cheat sheet.. since it cost me money i am going to code everything possible.
01-19-2013, 06:13 PM | #2152 | |
48
Rep 385
Well that explains a lot.
Dammit I just spent the entire morning re-reading everything and programming my car with 48.3 to be baffled as to why there was no errors and I know how to do it as I'm experienced with it and yet still no coding would stick. I see your post about the recent changes. I will have to check my integration level and if it's low enough can you please point me to 48.1 data files by PM? If it's not, how do I buy E-Sys 3.22.5 and a 1 year token from your source? How quickly can I get the link and the token as tonight may be the only free night I have for a while to do this coding. Again, PM please and thank you. Thank you again. Quote:
01-19-2013, 06:16 PM | #2153 | |
General
10545
Rep 41,221
01-19-2013, 06:17 PM | #2154 | |
48
Rep 385
http://www.f30post.com/forums/showpo...postcount=1822 |
01-19-2013, 06:19 PM | #2155 |
48
Rep 385
01-19-2013, 06:22 PM | #2156 |
General
10545
Rep 41,221
Not necessarily. As I wrote above, 48.2 may also have the increased Token Security. It was barely around long enough before 48.3 came out, so there just isn't many users nor feedback on it.
