$3AH Backup Camera + Top View Camera Retrofit Development Thread
04-25-2020, 07:26 PM | #45 | |
Rep 26
is my TRSVC module is working. That's why I would like to somehow connect my cheap RCA camera to see if module is working. |
04-25-2020, 11:47 PM | #46 | |
Rep 1,353
Appreciated for following up. Yeap. I am waiting my oem wiring harness from Europe. As soon as it gets here I am doing the oem retrofit.
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
Luka1176.00 |
04-25-2020, 11:49 PM | #47 |
Rep 1,353
I wouldnt cut of the trunk. I bought cheap Chinese handles for the Chinese Emulator. Now i am upgrading to OEM module so i installed the f10 camera on chinese handle. No need to cut and yes I am the only person who has done this way :
Luka1176.00 |
04-26-2020, 10:21 AM | #48 |
Rep 720
Problem with those small boot handles is you can't get your fingers in the same. I have fairly large hands and hated the feel of the Chinese handle. Cutting out the boot lid for the larger (including camera) OEM camera was a must for me.
04-26-2020, 10:57 AM | #49 |
eBay Special
3103
Rep 3,038
Drives: E90 330xi
What does it look like on your car?
Common sense is a flower that does not bloom in everyone's garden
04-26-2020, 11:12 AM | #50 |
Rep 720
colorado.e9x3103.00 |
04-26-2020, 03:50 PM | #51 |
Rep 1,917
How did you install the camera in the handle? Did you just epoxy the camera into the handle?
04-26-2020, 11:49 PM | #52 |
Rep 1,353
I don't know, but I do not have any problem with the size or the function. I think it is perfect for me and I am 5 11, my hands are pretty big. And OEM camera must for me as well. That's why I have gone thru all this after having a perfectly working Chinese set like less than 2 months old
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 04-26-2020 at 11:56 PM.. |
Luka1176.00 |
04-26-2020, 11:54 PM | #53 | |
Rep 1,353
I will never going to cut my trunk for the camera. It is just me. I like oem application but also like to keep it oem But it looks pretty good if you can cut it right for the FX handle. Here is how it looks like : And this is the differences between Chinese handle Vs F10 m5 handle :
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 04-27-2020 at 12:09 AM.. |
Luka1176.00 |
04-27-2020, 02:18 AM | #54 |
Rep 1,579
Does anyone have the part number for the 10 pin connector that powers the TRSVC?
EDIT.... Part number is 61139132577 Last edited by smass; 05-17-2020 at 06:33 PM.. Reason: found answer |
johnnyorange58.50 |
04-27-2020, 07:25 PM | #56 |
Rep 1,353
e84 PDC has an additional coding option for RVC and TVC also controlling the Parking menu with Camera screen such as turning on and off when u engage/disengage the shift or when u turn the car off . If u re using the e9x PDC because it never introduced with camera, what happens is when u re using the Chinese EMulator with that PDC, it does not turn the CIC Parking menu off when ur shift is disengage or car turned off, and it stays up until u turn the car completely off which means u need to either press the start stop button 2 times (First Turn off the car second turn everything off) or press Parking button right before shut the car off otherwise if u just shut the car off with pressing the stop button once parking button will not function due to PDC only works when the ignition is ON
Also because of the RVC and TVC option on e84, it sends additional Can signal to TRSVC to start/stop broadcasting for the camera. Without the e84 PDC no one going to wake the TRSVC on and u will never going to see the camera screen on CIC, it will only show the PDC unless u re using Chinese EMulators. Because Chinese emulator is always awake and up and when PDC gets the signal from reverse shift, that turns the Parking menu on and because the Chinese Emulator aways Up, it broadcasts and allows u to see the camera screen and no need additional Can signal from PDC. In parking menu the Brain is PDC, TRSVC is working for PDC! But if the whole point is using the OEM application, YES e84 PDC is must!
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 04-27-2020 at 07:35 PM.. |
Luka1176.00 |
04-27-2020, 10:37 PM | #57 |
Rep 1,917
SaNGRia990.00 johnnyorange58.50 |
04-27-2020, 11:14 PM | #58 |
Rep 1,353
Thank you buddy. Appreciated.
04-28-2020, 07:11 AM | #59 | |
Rep 26
Or I can just use RCA cable from Chinese retrofit and connect to TRSVC. I saw also that 3 cables from TRSVC need to be connected to CIC instead of 2 from Chinese retrofit |
04-28-2020, 10:03 AM | #60 | |
60
Rep 109
is that ok? I mean I need an e84 pdc |
04-28-2020, 11:12 AM | #61 |
60
Rep 109
oh currently in my car is the trsvc surround module for e70 with camera. and I also have trsvc camera from f30 with only reverse camera only. bimmer retrofit told me that because my car was an e82 and I have a e series nbt evo emulator better to get the e series trsvc camera module as that is the only one that will work for me car. not sure if icam will work with my setup but I just want to have a backup camera so that my 1m will be like same infotainment as the m2
04-28-2020, 11:19 AM | #62 | |
Rep 1,353
But after making many many researches what I see clearly that F series TRSVC uses CANBUS 1 just like the E series. F series PDC uses the CAN2 line. So TRSVC in theory should work with E series Without any issue! And does not matter you use E series TRSVC or F series TRSVC you will not be able to code it on NCSExpert anyway. Even tho you can code it somehow, there is no point because there is nothing to code on TRSVC module. And Hitch Zoom Option can be coded under CIC with changing the Value of MACRO_TRAILER_COUPLING to Aktiv .
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 04-28-2020 at 01:34 PM.. |
04-29-2020, 01:02 PM | #63 |
60
Rep 109
05-08-2020, 08:56 PM | #64 |
Rep 26
I just installed my TRSVC and PDC from E84. Camera from F10
All is working perfect! Flash new modules to match vin number. Big thanks to SaNGRia for his help and for other from this thread. If someone is looking for PDC module and CIC reverse camera emulator look on this post please https://www.e90post.com/forums/showthread.php?t=1718859 |
05-09-2020, 11:54 AM | #65 |
Rep 1,353
Great Job buddy. Nothing better than OEM. And thank you also helping me out flashing Congrats!
