Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > TPMS "Inactive"
      01-05-2011, 10:33 AM   #1
nodabs
Drives: '07 335I
TPMS "Inactive"
My '07 335I has started indicating the TPMS is 'Inactive'. I can reset it but within a short period it will fail again. I suspect that either a wheel sensor is bad or there is a problem with the antennas in the car. Is there a way to test the wheel sensors to find if one of them has failed. Oh, yes! I'm out of warranty. I'm running the oem wheels and the sensors that came in the wheels.
      03-02-2011, 05:38 PM   #2
JUSTIN335
JUSTIN335's Avatar
Drives: 2012 535i m-sport
Just got the same problem today while driving. Im under warranty but if anyone knows a fix it would be better than driving to the dealership.
2012 F10 535i
2013 E70 X5M
2007 E92 335i - sold
      03-13-2011, 10:38 PM   #3
rollsISU
Drives: 2007 335i 6SPD Sedan
I'm curious about this too. I've seen it a few times on cold days. It's been awhile so I can't say exactly how cold. Maybe in the 10-30F range. It's pretty infrequent so I doubt I'd have much luck if I took it to the dealership. I'm guessing they'd just tell me they didn't see any problem.
      03-13-2011, 11:48 PM   #4
itsbrokeagain
itsbrokeagain's Avatar
Drives: 1999 528iT, E53 X5, E46 325xi
Same issue with mine. I have to catch it when it's on to scan the car, as it decides to reset itself when you restart the car..
      03-18-2011, 12:12 AM   #5
335iseb
335iseb's Avatar
Drives: 2008 335i
My just came on now too on the way home from work today. Saying "Inactive."
      03-18-2011, 12:14 AM   #6
TXe92
Drives: 2007 335i Coupe
      03-18-2011, 06:36 AM   #7
E92M356789
El Jefe
E92M356789's Avatar
Venezuela
39
Drives: e30 325i
I just installed my rims yesterday and I had brand new TPMS and still the light is there. I checked the tire pressure and its right, I reset while stopped and still the light is on.. My car is 07 335i, any other ideas???
      03-19-2011, 05:24 PM   #8
335iseb
335iseb's Avatar
Drives: 2008 335i
My seemed it fixed itself a day later. So far on day 2 with no inactive message anymore.
      03-21-2011, 01:01 PM   #9
JUSTIN335
JUSTIN335's Avatar
I just realized that mine will become inactive and then reset itself or start working again several times while I'm driving. It will say inactive when I start the car but if I check the control messages later it says no errors. It will break/work like 4 times within a continuous 1 hour drive.
2012 F10 535i
2013 E70 X5M
      03-21-2011, 02:57 PM   #10
vietmike101
Drives: 328i
does it say inactive when you start the car or when you reset the tmps setting?
      03-21-2011, 05:50 PM   #11
JUSTIN335
JUSTIN335's Avatar
Sometimes right after starting or after driving for a while. Resetting doesn't do much since the error occurs randomly. It has happened almost immeadietly after resetting for me.
2012 F10 535i
2013 E70 X5M
      03-21-2011, 07:09 PM   #12
bmwfan1
bmwfan1's Avatar
Drives: 335i
Mine does the same thing in an 09 LCI. Cant reset or anything! WTFuck?
It's getting there...
      03-21-2011, 07:16 PM   #13
mid-corner fun
Drives: F80 M3, '22 X3MC
Happens to my '08 on very cold days, and with different sets of wheels. It doesn't seem to leave any codes behind (BT) which is annoying as I've gotten the "we don't see anything wrong" spiel from the dealership twice already.
      02-03-2012, 11:07 AM   #14
banky
34
Drives: 2007 335i e92
last super bump, but any solutions here? my car is doing something similar after getting the car back from the shop. they refinished the rim so im assuming they dismounted and then remounted the tire.
im getting TPMS inactive and when i try to reset, it just says on my screen: (non idrive)
[TPMS ICON]
INACTIVE
-> RESET
      05-24-2012, 02:19 PM   #15
acj75
acj75's Avatar
Drives: '07 E92 335i
Digging up an old thread here, but has anyone found a solution? My car is doing this now. It starts with a front right tire is low warning. After a reset or two it'll eventually show a tpms inactive message. I took it by Discount, and they inspected my front right tire. No trouble found.
'07 E92 BMW 335i
      05-24-2012, 07:16 PM   #16
EYE4SPEED
Ex-Diesel Driver
EYE4SPEED's Avatar
Drives: Audi SQ5
Did you try filling with a little air to change the pressures and then hit reset while the car is parked and on?
      05-25-2012, 01:30 PM   #17
bavarianx
bavarianx's Avatar
Drives: 2006 X5 4.4i
If you have an 07 its probably getting close to replacement time on your sensors.
Some tire shops have a tool, looks like this:
That shows battery life and if its functioning. The sensors last 5-7 years then the battery runs out..
      06-01-2012, 04:44 PM   #18
acj75
acj75's Avatar
You were correct. Took it back to Discount and the tool showed the battery was dead. They replaced it, and everything is good
'07 E92 BMW 335i
      06-04-2012, 06:57 PM   #19
bavarianx
bavarianx's Avatar
Usually when one goes they are all ready to go...
http://www.huf*********/HUF_BERU_RDE008_s/1520.htm
      06-11-2012, 01:46 PM   #20
Kruz
Kruz's Avatar
Drives: 2021 M2C 6MT
Same problem here. Finally put on my summers and upon startup it says Inactive, but then goes away before I can reset.
Are the TPMS batteries replaceable and at what cost, or is there a need for a whole new TPMS?
Anyone have luck getting their warranty/extended warratny to cover this?
2021 BMW M2 Competition, BSM, Exec Pkg, 6MT
GONE:07/07 E90 335xi SG
Black Dakota|Alum|ZSP|2AB|ZPP|ZCW|Nav|CA|6FL|PDC| Blacklines|3M
Summers: 235/40/18 265/35/18 Hankook Ventus V12 on VMR 701s
A/S: 225/40/18 255/35/18 Pirelli PZero Nero M+S on OEM 162s
      06-16-2012, 09:49 PM   #21
Gilda G
Gilda G's Avatar
Drives: M235i xdrive
Woke up this morning with a flat rear tire so I brought the tire to a local shop and had it replaced. Mounted the tire back on the car now Im getting TPMS Malfunction then TPMS Inactive message.Did the reset in the idrive.. nothing happens just keep saying resetting for about 5 minutes. I went back to the tire shop they scan my tires and say all is working that its a faulty message and that i have a pound to much in the two front tires. He adjusts it for me and then the front left sensor go inactive on his screen. He said its bc of the pound over the allowed and that I have metal air caps instead of plastic. I find this very strange since everything was working fine until i replaced the flat rear tire. These sensors are about 14 months old can they go bad that fast or should I give it a few days and see if it reset before replacing them?
SOLD: 2015 BMW M235i Glacier Silver on Coral Red
35% tints, Gloss Black Roof, AFE Magnum Force Stage 2 Intake, AFE Power Scorcher, P3 Vent Gauge and Fabspeed muffler delete.
      06-16-2012, 09:57 PM   #22
Kruz
Kruz's Avatar
Anything's possible. Did you check the nut on the stem itself?
