BMW X3 Forum
BMW X3 Forum
      09-19-2014, 07:50 AM   #23
bowler_1
Drives: 2011 E70 X5 4.0D M Sport
Replacing Front and Rear brake pads
Having been advised by my stealer that my rear brake pads needed changing and that they wanted £265 for the job (rears only), although there were no warning lights showing, I checked both front and rear pads visually through the wheels and could see that the fronts were about 5-6mm and the rears about 4-5mm.
Checked on the forum where there are several excellent write-ups and also on Google and as a retired mechanic I could see no issues in doing the change myself.
Purchased both front and rear sets of Pagid brake pads for about £72 and did both jobs yesterday in about 5 hours without any issues whatever. Just a note of warning, the sensors have a very small "U" shaped metal clip which falls off when you remove it from the brake pad and is easily missed when you do the first one !!. This clip ensures a tight fit between sensor and brake pad.
My X3 F25 has 23500 mls on the clock so I thought that changing pads was a bit premature. All discs were absolutely fine, no scoring or ridging.
The remaining pad thicknesses were: Front 6mm and Rears 4mm so actually I need not have changed the fronts yet but anyway job is now done. Incidentally thickness of new pads is Front 19mm and rears 18mm.
I will now need to reset the mileages in the iDrive system.
It seems to me that the sensors are not touched until the brake pad thickness gets to around 2-3mm as neither of my sensors had been touched.
Just saved myself about £450 .
      04-17-2015, 04:22 PM   #24
///Mposter
Macgyver
///Mposter's Avatar
Drives: 2007 e92 335i
Bump for Sticky DIY section to be created
      05-03-2015, 11:36 AM   #25
Mingstar88
78
Drives: BMW X3 35i
thanks for the guide. i will be looking to get my hands dirty soon to do my front brakes. i have watched some videos of DIY BMW brakes, hopefully i wont be running into much trouble.
      05-03-2015, 01:13 PM   #26
TonyX3driver
15
Drives: X3 F25 (2011), X5 F15 (2017)
Originally Posted by woodchuck1 View Post
Excellent writeup, thanks.
Whenever I have one pad on a wheel wear out faster than the other, I assume the cause is a stuck caliper. Do BMW brake pads not have that little metal tab that drags on the rotor to indicate wear? I bet they thought their electronic indicator was superior. Sometimes simpler is better.
Guys, I'm eyewhitness of the similar situation. One rear pad comlpetely out to the metal very soon. Other 3 pads almost new. It was fault of mechanic who changed pads last periodical service. Those pads can be accidentally installed in whong position. Because pad with sensor was nearly untouched, there was no cluster indication and result was metal squeeking when braking and disc damaged.
All was claimed and changed at dealer's expenses....
      05-03-2015, 01:29 PM   #27
TonyX3driver
15
I believe in old fashion way:
1.Time ti time look at iDrive interval and reset it before it shows low mileage for change.
2. Drive normally until pad sensor is weared out. In this case you still have min. 2mm pad thickness (min. 5000km??) and can shop for new pads now.
3. Change pads with new sensor. DYI
4. Reset iDrive again.
Am I right??
      05-04-2015, 02:10 AM   #28
plymjack
Nuclear Chief of the Watch
plymjack's Avatar
120
Drives: X3 (F25) 2.0D, i3 BEV
Just had my rear pads changed at 30k miles, were down to 3mm, cost at dealers £285 which is steep but as its still under warranty I dont want any issues. Fronts are still around 8mm and showing another 15k so happy with that.
we use cruise control and auto hold so 30k is fine. I expect the rotors are good for 60k miles so will expect to change then.
BMW i3 (BEV) 2014. . Capparis White. . Park Assist, Comfort Access, Enhanced USB
BMW X3 (F25) xDrive20d SE 2017. . . . Oyster Leather . . 8 Speed Servotronic. .RFTs. . Electric Seats
Canon 70D 500mm, 85mm, 40mm, 24mm
Sony QX10 & GoPro Hero 3
      05-05-2015, 02:45 AM   #29
TonyX3driver
15
This sounds good to me. I have about the same mileage, still front and rear pads original without warning. But thickness is low already.
      05-05-2015, 06:36 PM   #30
Radioactive
Drives: '11 X3 28i '10 535i '04 325i
Just replaced the rears for the second time @ 59K miles. This time I replaced with Akebono pads and Zimmer rotors. I've noticed no difference in performance; but the amount of brake dust is near zero with the Akebono's. I brought the pads to the mechanic who told me that the Akebono's were his first choice for non OEM replacements and they out wear the BMW pads with almost no dust.
      05-06-2015, 03:13 AM   #31
jeschiotz
Drives: BMW X3
What is the with limit on the rotors(front? Rear?) also,my dealer tild me that since handbrake is electric the motor for the brake should be zero set to retract the caliper allowing acces for new pads This could only be done electronic on their hooked up car analyzer (or something)
      05-06-2015, 07:08 AM   #32
Radioactive
Believe it's 18mm. Should be stamped on rotor.
      05-07-2015, 03:12 PM   #33
///Mposter
Macgyver
///Mposter's Avatar
I think the step you are asking about calls for the T45 to be inserted into the Electronic Hand Brake ( EHB) in a clockwise rotation to set it to "zero" for new pads.
GTX3076R , ADV, JB4, FMIC, BOV, 17"APEX, 255/40/17 SQ, 6-SPD Manual
      05-08-2015, 12:45 AM   #34
TonyX3driver
15
      05-08-2015, 08:28 AM   #35
jeschiotz
Drives: BMW X3
Originally Posted by TonyX3driver View Post
Hehe,thats typical me just not reading all information! ThX anyway
      05-13-2015, 09:27 PM   #36
Hornet_Rider
Drives: X3 35i 2011 M-Sport
If you get the initial yellow warning and plan on doing your breaks yourself, reset the mileage meter (search on google) before it gets down to 0 Km or miles left. You absolutely need a new sensor if you get the red warning. Systems recognize the resistance of the old sensor and requires a new value to be reset if you have the red warning. The front is a bit of a pain to change, rear one is easily accessible.
      05-20-2015, 07:03 AM   #37
Larrylotus
Drives: 2018 X5 xDrive35d (F15)
Brake wear yellow warning : cannot reset ?
2013 F25 2.8i : iDrive says about 300 miles before pad replacement, front and rear. Yellow warning still.
I had all the pads replaced and rotors turned yesterday. I was told that sensors were not touched and could be re-used.
Problem : when I go into the service menu to reset either front or rear warning, it let's me go through the process but then a message : "impossible to reset".
Could it be that I really need new sensors even if they appear to not have been worn ? Are they really "2-stage" sensors ?
Thanks !
      05-20-2015, 10:42 AM   #38
Radioactive
Thanks !
Try unplugging, then replugging old sensors.
Believe they are three stages. Sensor wire with no resistance runs to outside of sensor with another wire with resistance runs parallel and to the inside of other wire. Before wear current runs through outside wire. When the sensor wears enough its cuts through outside wire. Current then runs through resistance causing drop in current which computer picks up. Finally if it wears through that wire causing no current flow and warning that "Everybody is gonna die of massive brake failure"
      05-22-2015, 06:42 PM   #39
Mingstar88
78
Drives: BMW X3 35i
question
instead of T30/T45, can i use allen head 6/7mm?
watched alot of vids tutorials online for bmw brake job, they are all saying the allen head
thanks inadvance
      05-22-2015, 08:17 PM   #40
///Mposter
Macgyver
///Mposter's Avatar
Originally Posted by Mingstar88
question
thanks inadvance
Very possible if its the same size at the star points. From what I remember it was not very hard to turn. I guess if it came down to it a flat blade that fit snug could do it.
      05-23-2015, 04:25 PM   #41
///Mposter
Macgyver
///Mposter's Avatar
Not that I can confirm it actually fits into it but I can confirm that 7 hex is the closest size to T45.
      05-23-2015, 11:19 PM   #42
Mingstar88
78
Drives: BMW X3 35i
thanks, ill try and report back.
6mm(T30) is for the rotor and 7mm(T45) is for the 2 plastic covers from behind the caliper.
      07-13-2015, 09:00 PM   #43
Mingstar88
78
Drives: BMW X3 35i
just replaced my front brake pads today. my 2nd DIY to the car next to engine air filter change. it is really rewarding for someone that's really noob mechanically. i would like to thank OP's post along with youtube vids!
I didn't take many pictures since i was busy working on it.
      07-16-2015, 01:02 AM   #44
jxterma
Drives: 2012 x3 35i
After zeroing the EHBrake and putting on new pads, I have an yellow light on for "Parking brake malfunction". The EHBrake cannot engage when I put the parking brake. Actuator is not turning. Do you know how to reset? Thanks in advance!
xbimmers
