BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Coding / ConnectedDrive / Audio-Video / Electronics / Bluetooth / I-Drive & Nav
      03-18-2024, 11:40 PM   #1
beckumf
beckumf's Avatar
Drives: 09 E92 M3
Need help amp
Hello,
I bought an E92 M3 recently and the amp is broken from water damage unfortunately from previous owner. I have the yellow cones, which I’m pretty sure is the upgraded sound system. It is a 2009 M3 Comp (non-zcp) idk if that matters.
What amp do i need?? HELP PLEASE
      03-19-2024, 07:43 PM   #2
Redd
Drives: 2010 BMW E92 M3 Dakar Edition
Yellow cones are Individual Audio. You can take out the damaged amp and match part numbers on realoem.
      03-19-2024, 07:44 PM   #3
beckumf
beckumf's Avatar
Drives: 09 E92 M3
Individual audio? What does that mean? Is it the upgraded system of the base?
      03-19-2024, 09:52 PM   #4
spammysammich
spammysammich's Avatar
1585
Drives: 2009 E92 M3 Dakar Yellow II
2009 BMW M3  [10.00]
I doubt your car is a comp. That package wasn’t offered in that model year. Individual Audio is an option level for the in car electronics. Realoem.com and google are your friends.
      03-19-2024, 09:53 PM   #5
beckumf
beckumf's Avatar
Drives: 09 E92 M3
It’s a comp non-zcp.
      03-19-2024, 09:54 PM   #6
spammysammich
1585
2009 BMW M3  [10.00]
Also you will want to track down the source of that leak. PNW rain will just kill the next one you put in.
      03-19-2024, 09:55 PM   #7
spammysammich
1585
2009 BMW M3  [10.00]
Comp implies competition package which you don’t have and others have corrected you on already.
      03-19-2024, 09:56 PM   #8
beckumf
beckumf's Avatar
Drives: 09 E92 M3
Basically, he was installing LCI taillights and had the trunk open. He went inside for a little bit to eat or something, it just started to rain and got a little water on it and fried if unfortunately.
      03-19-2024, 09:59 PM   #9
spammysammich
1585
2009 BMW M3  [10.00]
A lot of people install new tails and neglect to put new gaskets on. They’re little foam gaskets that often get torn. Check to make sure they’re present. They can also let water into the trunk area.
      03-19-2024, 10:01 PM   #10
beckumf
beckumf's Avatar
Drives: 09 E92 M3
I’ll take a look at it when I go to find the part number of the amp. Thank you for the help, also your M3 is so clean man👍🏼
m3post
