03-05-2022, 05:29 PM | #23 |
Retired Curmudgeon
2985
Rep 4,047
Once everything is cleaned up, please post close up pics of pinion and ring gears so we can see wear on teeth. Mileage would be helpful as well.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
03-06-2022, 12:19 PM | #24 |
1478
Rep 2,672
Finding it difficult to get a consistent backlash measurement, basically the amount of play between the ring and pinion gear. The amount of grease is not helping the situation, this is the basic setup though for reference. (Perhaps it will be easier to get a measurement on the new clean setup.)
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
03-06-2022, 12:49 PM | #25 |
1478
Rep 2,672
To pull stub axles / flanges just use a long screw driver and lever against the side cover bolts. Flanges came out pretty easy after you get past the initial tension holding them in place.
03-06-2022, 12:59 PM | #26 |
1478
Rep 2,672
13mm bolts on side covers, torque wrench seemed needed.
03-06-2022, 01:10 PM | #27 |
1478
Rep 2,672
Side cover pries off with two screwdrivers, some light hammering on one of the screwdrivers helped get things started here, side cover came out pretty easy. Don't forget to label your shims driver/passenger as they are likely different widths on each side. You can also see the o-ring that will be replaced inset in the inner portion of the side cover.
03-06-2022, 01:20 PM | #28 |
1478
Rep 2,672
After the side covers are off, the diff falls out. Thinking these must be the same bearings used on the e46 m3, may order a set to compare them with.
DrFerry6728.50 |
03-06-2022, 03:51 PM | #30 |
Retired Curmudgeon
2985
Rep 4,047
Full send. No need for a float test. I'm looking for pitting, chipped, cracked, and severely uneven wear on the gears. I don't see anything like that.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS Last edited by admranger; 03-06-2022 at 03:58 PM.. |
///Mobbin1478.00 |
03-06-2022, 09:00 PM | #31 |
1478
Rep 2,672
Ended up ordering all of the following from BMW Parts Now (best price on the e39 m5 flanges):
2 x E39 M5 Output flanges - part no. 33131214068 2 x E92 M3 Shaft Seal w/ lock ring - part no. 33107510289 2 x E92 M3 O-rings - part no. 33111214144 2 x E92 M3 Differential drain/fill plugs - part no. 33117525064 Ordered from Amazon: 1 x VIVOHOME 1100 Lbs Steel Lift Jack with Dolly 1 x Permatex 85080 Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker, 9.5 oz. PowerBead Can 2 x E46 M3 Differential Carrier Bearings - JLM104948 - went with Timken Brand Ordered from Rockauto since shipping delayed with Amazon: 2 x E46 M3 Differential Carrier Bearing Races - JLM104910 - went with Timken Brand Decided to try the E46 M3 bearings/races, if they don't look right back to the drawing board. In case anyone is interested in the total spend here, the diff was $1975 shipped and I spent ~$615 on all the misc. stuff, though the lift jack with dolly will be re-usable on other jobs. I do still need to order the Giken gear oil also.
03-06-2022, 09:36 PM | #32 |
1478
Rep 2,672
Another YouTube video showing an e46 m3 diff rebuild for a 2005-2006 e46 m3. Same vLSD as the E92 M3 and the bearings look the same also.
DrFerry6728.50 |
03-07-2022, 09:13 AM | #33 |
5355
Rep 2,806
Drives: '09 E90 M3 - IB
Really great info you’re sharing here.
As for the small parts, to ensure getting the right ones on the first try, I would encourage you to reach out to Dan at Diffs Online. He knows the correct parts needed. He sold me the small parts for my diff. |
Bartledoo2691.50 |
03-07-2022, 10:54 AM | #34 | |
1478
Rep 2,672
I had considered grabbing the smaller parts from one of the diff builders but they all mark these parts up quite a bit (3x-8x depending on the part). I get that they've done the research and need to make a profit, just would rather source myself if I can. Fwiw, I just found out there is a 3-5 week wait on the E39 M5 flanges, I'm fine to wait that out but means no updates for awhile. On the same topic, if you are in a pinch it is nice that the diff builders keep these parts in their inventories!
03-08-2022, 05:29 PM | #35 |
1478
Rep 2,672
Pretty sure these e46 m3 bearings are the correct ones.
03-15-2022, 09:04 AM | #36 |
1478
Rep 2,672
So a hammer and screwdriver not enough for me to get the bearing races out, will take them to a shop and have them pressed/out new/in when I have the bearings pressed on the new diff. I did find a visible part number on one of the races and it matches the e46 m3 race part number!
03-15-2022, 12:25 PM | #37 |
VisionAutoworks
322
Rep 206
Hey great thread here I have the OSG on my k-series honda and love it, plan to get it for the e92 as well. Jealous!
When I was reading OSG website tech info about this LSD they wanted you to buy a longer e9x output flange (P/N 33132229972) then shorten both by a bit. Which seems like kind of a headache if you want it done right, need to be machined... See link: https://cdn.shopify.com/s/files/1/01...es/d37.pdf?826 Are the E39 M5 flanges a direct "pnp" swap alternative instead of shortening the e9x parts? This alternative makes much more sense and would probably cost less in the long run.
IG @cchen9_
03-15-2022, 01:23 PM | #38 | |
1478
Rep 2,672
03-15-2022, 02:35 PM | #39 |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
Sub'd.
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
///Mobbin1478.00 ///M Power-Belgium63418.00 |
03-15-2022, 03:18 PM | #40 | |
VisionAutoworks
322
Rep 206
IG @cchen9_
03-25-2022, 10:28 AM | #41 |
1478
Rep 2,672
Parts are in! Also grabbed some yellow gear marking compound from Amazon.
The install continues.
03-25-2022, 10:30 AM | #42 |
1478
Rep 2,672
New and old flanges for reference.
03-25-2022, 01:43 PM | #44 |
1478
Rep 2,672
Out with the old and in with the new, nice having a buddy with a shop!
