BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Coding / ConnectedDrive / Audio-Video / Electronics / Bluetooth / I-Drive & Nav
BPM
      03-19-2024, 10:09 AM   #1761
S65Hunter
S65Hunter's Avatar
1188
Drives: 2009 E92 M3
  [0.00]
Originally Posted by dat1981 View Post
I have the same issue. My phone stays connected after shut the car off and screen mirroring doesn't work. (Grey unit)
So I just went to the settings menu on Mr12volt (car side) and went down to "more settings on phone". That will pull up a menu on your phone, there's settings for auto connect and stay connected after shut, or something along those lines.
2008 328i e93- 3SIM, StageFP tune, magna flow #12148 muffler + vibrant resonator, BMS filters, Bilstein B8s, H&R sport springs, ECS sway bars, whiteline rear subframe bushings, rouge engineering trans mounts, custco front strut bar, M3 front lower control arms. Cosmis R1 18x8.5 245/40 front 18x9.5 255/35 rear.
      03-19-2024, 03:14 PM   #1762
Thumbie
Thumbie's Avatar
96
Drives: 2011 M3/4/6
The unwanted connection issue is pretty common. I haven't messed around with that setting yet, but worried it won't auto-connect once I'm back in the car.
-Thumbie
2011 Jerez E90 M3 6-speed Competition Package
      03-19-2024, 05:54 PM   #1763
GORDON.M3
GORDON.M3's Avatar
1423
Drives: E92 M3 • F25 X3 M-Sport
For those of you having issues with the phone staying connected after you lock your car is because the car hasn't fully shut down.
The Mr12volt is connected to the power on the car's amp. it takes a certain time for the amp to fully shut down and timeout hence why the Mr12volt is still online.
make sure you lock your car will still stay on standby.
INSTAGRAM: GORDON.M3
North American Mr12Volt Carplay/Android Auto Distributor
DINAN | EVOSPORT | VAC | ARP | RD SPORT | NEEZ | EIBACH | CSF | IND | BILSTEIN | KLASSEN | BREMBO | ENDLESS | BBS | BPM SPORT | PROJECT MU | EVENTURI
      03-20-2024, 03:03 AM   #1764
dat1981
Taiwan
Drives: 06' E91 328i
Well, that make sense why Mr12volt still connected.
      03-20-2024, 03:06 AM   #1765
dat1981
Taiwan
I'll have a look at that. This issue not really bother me but screen mirroring did. I ask Mr12Volt via WhatsApp but they did not reply.
      03-20-2024, 06:08 AM   #1766
B21
B21's Avatar
153
Anyone know what the new passcode is for Version 3 MMI boxes to get into factory settings is now?
The old code doesn't seem to work..
Yabaa0.00
      03-20-2024, 06:28 AM   #1767
azatos612
Drives: E60
I have the same issue, screen mirroring doesn't work. (Blue unit). I noticed this after updating to iOS 17.
      03-21-2024, 12:54 PM   #1768
Yabaa
Drives: Bmw E61
Help! I installed the mr12volt today in my E61 with CCC. Everything is wired up, but the CD option is greyed out.
The coding is correct.
I had the mr12volt bluetooth adapter from earlier, that was connected where the cd changer was connected. I disconnected the bluetooth adapter and used the bypass loop there, but still nothing..
Anyone?
UPDATE: Found the problem!
When I was moving the new wires between the head unit and the screen, I removed the glovebox for extra room, and what I didnt know was that there was another fiber optic(most) cable just chilling there that I disconnected. So that was the reason why CD was greyed out.
Everything is working now and im super happy with it so far
And also, thank you to everyone that posted and helped in this thread, helped me a lot
      03-22-2024, 11:23 AM   #1769
Vlad_Shagov
Drives: F07
Hi guys!
I just found out about the existence of Mr12Volt device two days ago, and I am very interested in purchasing this device.
But I have a question to you guys. Maybe you know something about it.
- I have a 5GT F07 with CIC system. And i have rear entertainment system (two monitors for rear passengers). Because it is old CIC system, there is nothing to do with rear screens except watching DVD discs.
But now i'm curious... maybe with the Mr12Volt unit there is possibilities to run CarPlay or Android Auto on a rear screens, because as i remember there is also possibility to access to CD changer from the rear monitors...
I will be very grateful for your advice
      03-22-2024, 07:52 PM   #1770
ygoz
71
Drives: 2009 E90 M3
Originally Posted by Vlad_Shagov View Post
Hi guys!
Won’t work - the MMI only hijacks from front/main CIC screen.
What use would you have for CarPlay on the passenger screen though?
      03-24-2024, 08:44 PM   #1771
Bashar368
Bashar368's Avatar
774
Drives: 2017 green
Can anyone do a quick notes for me and everyone else that’s going to do this upgrade
#1) best place to purchase and which version do we need
#2) which back up camera fits the best and has the highest resolution
#3) i coding necessary
Thank you in advance
      03-25-2024, 04:14 AM   #1772
Matt@Evolve
Matt@Evolve's Avatar
1972
Drives: F82 M4, E36 M3 Touring, Z3
1 - https://www.evolveautomotive.co.uk/collections/mr12volt
2 - GreenYi from Aliexpress
3 - You will need CD Changer to be coded in if you do not have one.
Thumbie95.50
      03-25-2024, 05:45 AM   #1773
Vlad_Shagov
Drives: F07
You are right... I just realised how stupid this idea is.
I just don't know what to do with this rear screens. I like the idea to have a screens on a back, but it looks like there is no quality option with CIC for rear screens except DVD discs.
I tried to connect external devices with RCA cable to the back seats, but the quality is terrible. Much much worse than DVD.
      03-25-2024, 05:56 AM   #1774
Vlad_Shagov
Drives: F07
Ok, i have another stupid question. The last one, i promise :-)
Is it possible to install the Mr12Volt on the car, but also install the android screen unit, but use it only as a big screen, but stream the CarPlay through the Me12Volt?
Maybe it sound a bit complicated, but as i know this Android screens can be used to show the original CIC system, but with bigger modern screen.
So i mean use Android screen just because it is big and modern, but use it to stream the picture from the CIC, and at the same time CIC will be streaming picture and sound through the Mr12Volt.
So, in another words, Mr12Volt stream the picture to the CIC, and CIC stream the picture to the Android screen.
      03-27-2024, 03:44 PM   #1775
travelist
travelist's Avatar
Drives: E92 M3
Anyone found a solution to that horrible high pitch ringing noise when you start up the car?
      03-27-2024, 05:40 PM   #1776
Thumbie
Thumbie's Avatar
96
Drives: 2011 M3/4/6
If the android screen just takes whatever video signal from the CIC it should work. But not sure it's worth it since the oem CIC screen is pretty high quality.
-Thumbie
      03-28-2024, 10:27 AM   #1777
MineralWhiteF80
Dont listen to me
Drives: F82, E92 M3, G30 M550i, E46
is everyone in agreement that Mr12Volt is the best Carplay option for 2024? Hard to find solid information on these infotainment upgrade options.
Instagram: @thatwhitem4
      03-28-2024, 11:32 AM   #1778
Matt@Evolve
1972
Hugely happy with it, have a load of customers who are too and it's seeming really reliable day to day too.
      03-28-2024, 11:38 AM   #1779
spammysammich
spammysammich's Avatar
1585
Drives: 2009 E92 M3 Dakar Yellow II
2009 BMW M3  [10.00]
On forums it’s the squeaky wheels that are participating. The rest are of us with no glaring issues or problems are quietly enjoying the system and not bothering to chime in. Forum bias makes it look like they’re problematic. I doubt they are. They’re a great update for CIC, I have no clue how they are on CCC.
      03-28-2024, 12:08 PM   #1780
brettcp
Drives: 2012 E93 M3
I believe (and somebody please correct me if I'm wrong) that mr12volt the only one that uses the car's MOST/fiber loop.
I have a car with a Kremersino carplay unit (the later version with the DSP which fixed the lack of bass issues) that uses AUX in, and another car with the mr12volt. To my ears they both sound very similar.
My CIC mr12volt unit recently failed... the right audio channel died, and the USB port died. Went through hours of troubleshooting. It was a model P2000-MD, the one prior to the current model that uses the OEM mic.. was 2 years old so it was out of warranty. Ended up just ordering the new model with the OEM mic support.
      04-04-2024, 12:48 PM   #1781
avivienni
ASH
avivienni's Avatar
Drives: BMW 335i E93 2009
2009 335i  [10.00]
Any luck bro? I’m tryna find out the same thing
      04-06-2024, 07:56 PM   #1782
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
That's a bummer. I was hoping it would sound better. The BT audio vs AUX on my kremersino with the bass fix favors the BT for clarity and not sounding as muddle.
If that is the case, my current solution of using BT audio + Kremersino ACP will not be replaced.
IG:ruhrohz_m3
Journal: Link
E9x ZCP Suspension Info: Link
Track Chat Discord: https://discord.gg/VsKbTyqBVj
SF Bay Area: DM For coding services
m3post
