      05-23-2014, 11:11 AM   #111
BGR
Drives: C7 GS 7MT; e90 M3 6MT
Installed these this morning. Went smoothly. Tried to match the hight of the OEM tail lights as you can do some adjusting before/as tightening the nuts down.
      05-31-2014, 10:25 AM   #112
CAVU
CAVU's Avatar
Drives: '16 F87 M2
I installed my LCI Blacklines this morning. Thanks to Dack and others who contributed to this DIY. Installation was straightforward. Here are some before and after photos.
F87 '16 M2 ... Mineral Grey, 6MT, Exec, MPE
Gone: E82 '13 135is 475/586 ... Mineral Grey / Oyster, DCT, Premium, Tech, HK, Michelin PSS, BMW Performance Suspension
      05-31-2014, 04:58 PM   #113
Dackelone
European Editor
Dackelone's Avatar
Germany
10616
Drives: N54 e82
@RickMsport looking good!
      06-12-2014, 11:28 AM   #114
CAVU
CAVU's Avatar
Drives: '16 F87 M2
Originally Posted by Dackelone View Post
The black foam seal that seals the tail lights to the car body. If the tail light is not tight enough... water can leak into the car. Also make sure the rubber flap/seal of the tail light is routed correctly to "deflect" water around the trunk seal.
I took a look at the deflector seal today. The left one is fairly flush with the body of the car, but the right one has a significant gap. I plan to loosen the nuts and take another try at it, but the rubber seal nests where it wants to nest, there is not enough adjustment in the position of the lens assembly to get the seal to lay flush. I'll try to get a before photo and report how well I'm able to close the gap. If anybody has any other ideas please post!
      06-12-2014, 02:33 PM   #115
CM
Drives: 2011 135i Coupe
I'd be interested to see the pics RickMsport. I'm planning to install my blacklines this weekend and I want to see if I have that same gap.
      06-12-2014, 04:50 PM   #116
Dackelone
European Editor
Dackelone's Avatar
Germany
10616
Drives: N54 e82
Was your car ever rear ended? Wreck ? I guess you could always buy some foam tape at any hardware store and use that to layer up more foam so it seals better.
You can also buy the foam seal separately from bmw...
p/n 63217303319
p/n 63217303320
http://realoem.com/bmw/showparts.do?...63&fg=20&hl=32
      06-13-2014, 08:51 PM   #117
CAVU
CAVU's Avatar
Drives: '16 F87 M2
p/n 63217303319
p/n 63217303320
No, the car has never been involved in a collision. I might have inadvertently referenced the wrong "seal" in my original post. The issue is not with the foam seals behind the taillight assemblies, it is the integrated rubber seals that divert water from the longitudinal trunk lid channels over the top of the taillight assemblies. It is almost as if the seals were improperly manufactured and lacking a small amount of interference fit molded into their shape.
I loosened all mounting nuts this afternoon and confirmed that even maximum available rotation on the Y axis doesn't allow the seals to come even close to seating properly. I took some photos after putting it all back together.
I'm not sure what I could be overlooking. These assemblies really only fit one way, and once install and tighten the nuts while maintaining consistent gaps around the exterior of the taillights, the seals pretty much sit where they are going to sit.
      06-14-2014, 02:54 AM   #118
Dackelone
European Editor
Dackelone's Avatar
Germany
10616
Drives: N54 e82
@RickMsport
Yea... looks like they weren't made correctly. You can tuck the flap under the trunk seal(bottom pics)... I had to do that on my car. The other part lifting off the trunk opening... I would just use some black silicone RTV to seal that area(top pics). Maybe first contact the place where you bought these blacklines from. New parts do have a warranty. Its just gonna be a hassle bc you have to send them back in order to get new ones.
      06-14-2014, 05:45 AM   #119
Dackelone
European Editor
Dackelone's Avatar
Germany
10616
Drives: N54 e82
@RickMsport I took a look at my tails... mine looks the same as yours. Have a look.
      06-14-2014, 08:17 AM   #120
CAVU
CAVU's Avatar
Drives: '16 F87 M2
@RickMsport
I bought them from Schmiedmanns, so returning them will be a bit more of a hassle than if I'd gone with ECS or another US distributor. I need to decide if I want to try the silicone method... I think I'll start with an email with photos to Schmiedmanns and see what they say.
      06-14-2014, 06:53 PM   #121
Marc08EX
Marc08EX's Avatar
139
Drives: 2011 E82 135i
The OEM LCI (non blackline tails) I have looks like that as well.
2011 135i 6MT | Alpine White | Terracotta Boston Leather | M-Sport | BMW Performance Exhaust Resonator Delete | Active Autowerke Signature Exhaust | BMW Performance Suspension | Blackline LCI Taillights | BMW Performance CF Spoiler | CF Rear Diffuser | PPK | E92 M3 FSB | Matte Black Kidney Grilles | VMR V710 Jet Anthracite | Michelin PSS | BMW SS Pedals
      06-15-2014, 05:28 PM   #122
Overpar56
Proud AARP member in good standing
Overpar56's Avatar
28
Drives: Me nuts
Take the Mellow Yellow out of the trunk. That's causing a fluid imbalance. 😃
Let me know if you need another set of eyes on it. I'll be back in town later this week.
2012 135i DCT, Lemans Blue/black leather, PPK1, PE, Stoptech Sport rotors and Sport pads, unhealthy crackles and burbles and an aging demonic driver.
      07-19-2014, 10:33 AM   #123
BBursey
Work hard, play harder
BBursey's Avatar
14
Drives: 2011 135i
2011 135i  [0.00]
I saw you post this link in the "Blacklines with moisture inside" thread. I saw your post about the fit of these seals earlier and had a look at my original stock seals. Mine look exactly like the photos you posted and I expect they'll look the same after I install my blacklines this weekend.
I think you're absolutely fine - I'm more worried about getting the pressure on the gasket between the light assembly and the car body just right.
Cheers,
Bryan
2011 135i M Sport | COBB V3 AP Stage 1+ | ER FMIC and CP | BMS OCC | Dinan Stage 3 Suspension | Dinan High Performance Bushing Kit | M3 Wishbones | Modified CDV | Clutch Stop | APEX EC-7 Wheels w/ Michelin PSS 235/40R18 265/35R18 Tires | Maddad Street Series Exhaust | BMW Performance Kidney Grills | LCI Blacklines | Armrest Delete | Spoiler Delete | 28% Tint
      07-19-2014, 11:21 AM   #124
Marc08EX
Marc08EX's Avatar
139
How tight do the nuts have to be? I'm now worried about my blacklines... I'm not sure if I tightened the nuts down too much...
      07-19-2014, 07:16 PM   #125
BBursey
BBursey's Avatar
14
Drives: 2011 135i
2011 135i  [0.00]
I just installed my lights. The nut went from easy to turn with no leverage on small socket wrench to fairly snug in less than a quarter of a turn. I stopped right there.
Hope that works!
Cheers,
Bryan
PS> I love the way these look on my Le Mans Blue 135i!
      07-20-2014, 10:34 AM   #126
CAVU
CAVU's Avatar
Drives: '16 F87 M2
Cheers,
Bryan
Thanks for comparing my photos to your stock seals. I've been nervous about seeing water disappearing into those seals, but the water does seem to reappear on the outside of the car around the bottom taillight to body seam. I was careful to not over tighten the mounting nuts, and I don't see any water inside the taillights themselves. I'm keeping my fingers crossed!
      07-20-2014, 03:47 PM   #127
owen2001
owen2001's Avatar
Drives: 2013 135is
Just catching up on this thread. I installed my Blacklines about 2 months ago. My seal looks exactly like Rick's (top photo). The seal is not flush with the surface.
Mine do not look like Dackelone's (bottom photo). His have a much tighter seal. I'm going to take a closer look and see if I can get mine to sit a bit more flush w/ the surface. Thanks for posting those pics.
As of yet, no water/moisture issues. And I've been out in the rain and washing my car regularly.
2013 Jet Black 135is | 6MT | Coupe | #381/586
      08-15-2014, 11:31 AM   #128
berne
Sweden
46
Drives: BMW 135i
any one have done this on a the 2010 and up? just wonder if was have to be coded after the install? and is it just plug and play, dont need to modify any cabel or somting like that?
      08-15-2014, 04:29 PM   #129
Dackelone
European Editor
Dackelone's Avatar
Germany
10616
Drives: N54 e82
My car is a 2010. The Blacklines(#282 kit) or normal LCI lights are totally plug and play.
      08-17-2014, 10:51 AM   #130
berne
Sweden
46
Drives: BMW 135i
I think i dont have the lci onece... Will it be problem?
      08-17-2014, 11:03 AM   #131
Dackelone
European Editor
Dackelone's Avatar
Germany
10616
Drives: N54 e82
Not a problem. My car didn't have LCI's either. The xenon blacklines are totally PnP on all US spec cars. Since you have a EU 135i you have xenons... so the Blacklines will also work on your car.
      08-20-2014, 07:22 PM   #132
fututi
fututi's Avatar
South Korea
Drives: e82 120d
shipping from Odense to Seoul
easy to install
thanks!
