E90 330i oil leak
12-31-2021, 10:54 PM | #1 |
Rep 0
E90 330i oil leak
hello,
I have an E90 330i for several years now. I recently noticed that the engine costumes engine oil at an unusually high level- I have to refill 1 unit of the engine oil for every ~700-1000-mile drive. I also saw oil on the left engine bay (see images).However, I don't smell anything or see any oil on the ground. I replaced the valve cover gasket about 2 years ago, do I have to do this again? Can someone help me diagnose the issue? thank you so much! |
01-04-2022, 10:41 AM | #4 |
Rep 0
Thanks for your reply! do you think this leakage is concerning? should I repair this? is it okay if I ignore the engine oil burning issue and keep refilling when it's empty? or should I send the car to a dealer for diagnosis ASAP? thanks!
01-04-2022, 11:30 AM | #5 |
42
Rep 68
That leakage is a problem but shouldn't be concerning unless you start getting smoke from under the hood as the oil leak gets worse and starts dripping onto the manifold. I would check elsewhere to see if there are leaks. If not, you could be burning the oil
