03-07-2024, 01:22 AM | #4 |
Rep 790
Not sure if it would cause the car to blow warm air, but I would think so being ac related. As far as easy, you would need to carefully get into that section of the harness, reconnect, and re-wrap for protection. Not sure what the best method of joining the wires would be since their are so many, maybe a butt connector that heat shrinks or solder and use a heat shrink shield? My main concern would be longevity after the fix so make sure it’s done right 👍 and be careful with the other wires because damaging another wire will just cause other issues. So doable yes, easy 🤷‍♂️ a quick google search is showing new harnesses going for $150-$450 also
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
