01-02-2024, 03:52 PM | #1 |
Rep 11
update navigation on 2009 Z4 E89
I bought 4 CD's to update my navigation system. They are part
01990037287 "Road Map North America Premium2017-1". I've been reading some of older posts and they say I need a FSC code before I can install the CD disc's? Where can I get the FSC code and what are the steps to install the update? Thanks |
01-02-2024, 05:26 PM | #2 |
Rep 624
[QUOTE=nanneyman;30778837]I bought 4 CD's to update my navigation system. They are part
01990037287 "Road Map North America Premium2017-1". I've been reading some of older posts and they say I need a FSC code before I can install the CD disc's? Where can I get the FSC code and what are the steps to install the update? Thanks[/ https://fsc-code.com/home/20-bmw-lifetime-fsc-code.html
Change history here… https://www.dropbox.com/s/8h1vabklgz...0List.pdf?dl=0 Build thread here… https://z4-forum.com/forum/viewtopic.php?t=131886 |
01-02-2024, 06:47 PM | #3 |
Rep 53
Be careful with the DVD update, I did mine once successfully to 2020 map, tried again with 2023 maps and it failed. Later I found out that the DVD drives can screw up when they get old. And you don't need to pay for an FSC code, software exists.
01-03-2024, 01:05 PM | #5 |
Rep 11
I now have a FSC code and my four "North America Premium 2017-1" CD disks. Can anyone tell me what my next step is to load the disks?
Just sure where to start. thanks |
01-04-2024, 12:20 PM | #6 |
Rep 517
OP, AnubisZed on the UK site had a map update video that didn't involve CDs or FSC. I did. And if I can, everybody can. It was with via the USB port, though.
2016 35is, monoballs, camber plates, KWV3, PS4S, xHP, MHD, LFB pedal, flat bottom wheel, red indicators, black headlamps
01-05-2024, 02:58 AM | #7 | |
Rep 624
If USB support is present you see this tick mark..
01-05-2024, 05:54 PM | #9 |
Rep 53
That's where the pic above comes from, no tick, no USB update.
My car is 2014 build, no tick and no firmware update available. In fact my dealer website lists no map update for CIC at all. So, 2020 map will remain. I do have an MMI installed so no problem. |
01-09-2024, 08:12 AM | #10 | |
Rep 514
Firstly, the updated versions of CIC (iDrive) were around 2011, so a 2014 Z "should" have the tick and should be able to have an updated map (latest version is 2024-1). The last Soiftware update (Multimedia and Bluetooth) was in 2013 (as this coincided with the 3 series going from E9* to F3* so the only E series CIC left was for the E89 and BMW decided not to do any other updates for it). Now it's the Firmware that makes the difference with the Maps. A minimum of C13 is required, with, I think, the latest being C16. Firmware C13 also gives you the ability to use a Combox for music streaming as well. And yes that's my video above, and, as stated above, you still need to generate an FSC (software is linked in the video description). Alas I can't give out a link to the latest map version as a download as all links keep getting taken down.
Dave
2011, E89 23i, Grey with Red leather.... relatively basic (getting less and less basic with every new retrofit)! My Z4 E89 YouTube channel... https://www.youtube.com/channel/UCtt...0vHFUQnoEvKB2Q |
01-09-2024, 05:10 PM | #12 |
Rep 514
Dave
