      08-09-2020, 03:07 PM   #1
nbrigido
Drives: 2003 Z4
Sparco Pro Corsa
Looking at a set of Sparco Pro Corsa.
Just picked up the car and the previous owner put on Pilot Sport 245 35 18 at all 4 corners. The rears are stock no worry but it is the front.
Will the 18 x 8 ET45 work all around or do you think the follow will work, recommenced the Tire Rack
Front 18 x 8 ET 45
Rear 18 x 9 ET 39
      08-09-2020, 10:09 PM   #2
b1aze
Just one more taste...
b1aze's Avatar
Drives: 2013 128i 6MT MSport
9J ET39 with a 245 Tire will be a tight squeeze and you might rub a hair but very doable. I’m on 17x9J ET38 with 255s but got my fenders rolled for good measure. I still rub on really hard dips at speed but more on the liner than fender I think
      08-22-2020, 03:55 PM   #3
Olgeezer1
Drives: 2010 128i 6MT Sport Pkg. 18"
If you stay with the same size all around you'll be able to rotate your tires and double their life. Also gives nicely balanced handling with less understeer than a staggered setup.
      08-30-2020, 04:50 AM   #4
nbrigido
Drives: 2003 Z4
little change of plans, was able to find a set of 313 wheels that needed some TLC. they we original 1 series. After to good refinish, came out great. no rubbing. Then only issue, I and still working with staggered wheels and a square tire setup
      08-30-2020, 08:28 AM   #5
blue135
Drives: 2008 135i Convertible
313s are best looking wheel on a 1, in my mind.
