09-19-2018, 06:09 PM | #1 |
47
Rep 319
steering wheel column noise
Hey guys, anyone experience a buzzing sound at speeds of 40-80 coming from the steering wheel column? It happens from time to time but mainly on the freeway. It's so annoying!! please help.
2016 m6 GC |
09-19-2018, 08:37 PM | #2 |
88
Rep 238
Drives: BMW M6 comp
Garage List 2019 Aprilia RSV4 [0.00]
2015 Land Rover Ran ... [0.00] 2014 MV Agust Rival ... [0.00] 2009 KLR650 [0.00] 2016 Kawasaki KX450F [7.50] 2016 BMW S1000RR [8.50] 2014 BMW M6 [8.00] |
yes i have this problem, only over rough roads on freeway speeds, have no idea what the F it could be lol.
09-19-2018, 10:54 PM | #3 |
52
Rep 182
Drives: 2015 BMW 650i GC
Me too. Sounds like a module or connector is loose near the base of the housing. I plan on opening up the column and seeing what it is. As soon as I figure out how to open the column...
09-20-2018, 07:46 AM | #4 |
17
Rep 51
I've noticed that too. Still can't figure it out whether it's coming from the steering wheel or the steering column. It's really bumming me out because I just got my MY2014 M6 gran coupe traded in for my M4, and I never experienced such annoying rattle with my M4.
09-20-2018, 09:56 PM | #5 |
Rep 582
I know this might be a long shot but what your explaining it almost sounds like the vibration sound you would get from the steering wheel with lane keep assist ?
09-20-2018, 10:22 PM | #6 | |
Rep 433
Refer to this thread: https://f10.m5post.com/forums/showthread.php?t=810952&page=8 It is your vibration motor generator resonating with the road. Is it a kind of high pitch buzz? If so refer to SIB 661017 Defect code: 6137143900 |
ts-m516.50 |
09-21-2018, 12:17 AM | #7 |
52
Rep 182
Thanks for the info, but that's not what's happening on my car. Only on rougher roads I can hear something rattling in the column near my knees. It's not coming from the wheel.
09-21-2018, 07:36 AM | #9 | |
17
Rep 51
I bought 3rd party warranty with my M6 GC, so I'm hoping that will take care of this problem. I am going to raise this to the sales rep where I bought my M6. I'm relieved but also surprised at the same time that there's so many out there with this issue. Thanks to you all and bimmerpost for these information! Wish me luck. Last edited by ts-m5; 09-21-2018 at 07:44 AM.. |
09-22-2018, 12:09 PM | #10 |
Rep 14
Drives: 2017 Alpina B6
Faulty Vibration Generator
I had a similar issue. Took 3-4 visits to dealer including drive-along with service manager. Under warranty, replaced the steering wheel vibration generator.
Looks like the part number is 32-33-7-849-416 As you may know, this part is fundamental to the lane departure feature. For sure it fixed the problem. Hope this helps... |
ts-m516.50 |
10-06-2018, 09:49 PM | #11 |
Rep 19
I was having the same issue on my coupe, it was driving me crazy. My service guy here in Miami hooked me up and changed the whole steering wheel under warranty. Haven't heard the noise since.
10-09-2018, 04:58 AM | #12 |
17
Rep 51
I just had the vibration generator changed few days ago. I'll say it took away of about 90% of the rattling noise. Subtle buzzing is still there...I'll spend several more days to see if the new part needs some time to settle in to stop the subtle buzzing. Otherwise, I might just want the whole steering wheel changed to new one.
Circled in yellow is the new one. |
06-30-2019, 09:47 PM | #14 |
36
Rep 89
This is good to know. Mine definitely has an obnoxious noise coming from that part of the steering wheel. I will replace the part and see if it solves the problem.
07-08-2019, 08:20 PM | #15 |
Rep 1
Only had the car 2 weeks, its driving me crazy!! have you fixed yours? I'm waiting on BMW service to get back to me.
07-13-2019, 09:05 PM | #16 |
36
Rep 89
Just replaced the vibration generator this evening. Not entirely sure that was the problem as the original generator didn't have much play and the only difference is a little more of the shaft exposed on the old one. I'll take it for a test drive tomorrow and hope for the best.
Update: It worked!! Drove the car around and it was definitely the problem. The rattling was there since I bought the car and just assumed that was how the lane assist worked, it is so much better after replacing it! Does not sound so cheap anymore.
2015 M6 GC competition - fabworx downpipes/aFe dry filters/bootmod3 stage 2
11-03-2022, 09:18 PM | #17 | |
87
Rep 185
Drives: 2013 BMW ///M6 F13
Question is, can I just remove it and not replace it? I don't want or care about that feature lol |
11-04-2022, 10:25 AM | #18 |
64
Rep 232
Drives: 2016 M6 Gran Coupe MT
I have a vibration also. It isn't the lane departure warning. It happens on rough highway at a certain speed. It's a vibration down in the column, and I can kind of damp it if I put my hand down there. Annoying. And kind of loud, so a passenger can hear it. It isn't a motor, it has to do with the vibrations from the road. I mean, if the mount of the motor is loose, that could be. But it isn't because of the lane departure motor, I'm well aware of what that is.
11-04-2022, 01:28 PM | #19 | |
Rep 424
11-05-2022, 10:18 PM | #20 | |
Rep 5
11-08-2022, 10:37 PM | #21 |
Rep 45
I'm having this same resonating issue. It happens when driving on less than ideal roads at higher speeds and comes from the steering column. Not to be confused with the buzz that is triggered from the lane departure/blind spot assist, which also seems to sound a bit more "buzzy" than I think it should.
danielgmanm687.00 |
11-13-2022, 03:30 PM | #22 |
Rep 731
I had this issue, the dealer knew exactly where to look, very common fault I suspect, had that vibration sensor and indicator stalk replaced, fixed 95% of the issue, I put the 5% down to rubbish plastic / trim quality
