05-01-2024, 09:13 AM | #1 |
9
Rep 34
Strange issue (Manual Transmission)
I know that there aren't many of us here but perhaps someone has some ideas.
my F06 developed strange behavior, first I started to get warnings on the dash saying the Auto Start/Stop is malfunctioning. It would come and go and recently started to do it pretty persistently, but also, not sure if it's related (if so I really don't understand how that can be?) hill hold assist seems to not work anymore. While auto start/stop is an annoyance as it's pretty pointless feature especially on a manual transmission car, hill assist is a handy feature Any troubleshooting clues anyone? Thank you!
2014 F06 M6 6 Speed, Frozen Grey, Zandvoort, Executive, Driver Assist Plus, Night Vision, Carbon ceramic brakes
05-01-2024, 11:49 PM | #2 |
120
Rep 108
Wow. So I just went to check, and I didn't even realize that my manual had auto start/stop! It was set to off, and unlike modern BMWs, it must remember the last setting. Anyways, if you have access to ISTA or similar, I would run a scan and do diagnostics on the system. I don't think hill assist is related, but I am far from an expert on that.
05-02-2024, 10:08 AM | #3 | |
9
Rep 34
05-03-2024, 08:41 AM | #4 |
Rep 751
Drives: '13 F13 M6, '94 JDM Supra
I believe you'll have an auxiliary battery under the trunk panel and when they get weak the auto stop start system can have issues.
2013 F13 ///M6 Alpine White • Zandvoort Full Merino Driving Assistance Pkg • Exec Pkg • Vent Seats
Vorsteiner VFF-103 Carbon Graphite 343M dimensions • H&R Lowering Springs • Soul PP Resonated Muffler Delete • AeroFunction AF-1 Carbon Front Lip • Carbon Front Grilles • Carbon Mirror Caps • IND Black Fender Vents |
05-06-2024, 11:11 AM | #5 |
9
Rep 34
thank you!
05-21-2024, 02:15 PM | #7 |
9
Rep 34
Just a follow up. It is not a battery issue. I replaced the battery as the original one was getting tired and showed 19% life on the BMW diagnostic tool at the dealer. Got the brand new OEM one and properly coded/registered.
The Auto start/stop malfunction didn't go away neither hill assist and then it dawned on me that I only see the issue of hill assist not working when this auto start stop warning comes up and it does work when there is no error. It must be related to some sort of a clutch pedal switch/sensor!!! I have not dug there and wanted to ask people here. It makes tons of sense to be related in this case as failing sensor/switch will deem auto start and hill hold inoperable, right?!?! Anybody has a service manual that indicates that part by any chance?
