04-11-2016, 07:03 PM | #23 |
Rep 1,726
yep, i installed a M-Performance OEM x-brace.
to my knowledge the xbrace came standard on the M3 convertibles. but not in the coupes. however, the bolt holes are present in my model year, so i simply bought one and bolted it on.
My Trackable Street Car
2016 BMW M4 GTS |
04-11-2016, 07:18 PM | #24 | |
Rep 1,422
Yup! Beware of shock towers failing due to metal fatigue/corrosion. One of my buddies had 2 E36s get towers replaced. It's like $300 worth of welding for a $65 part! They'll look ok from outside but inside they're brittle and rotten. |
05-04-2016, 08:51 PM | #25 |
Rep 1,726
***update***
Did the following: -front left tierod replacement and alignment -Bimmerworld dual fuel pickups to address starvation -all aluminum radiator and expansion chamber, new coolant hoses -clutch fan delete, E-fan install, Stewart water pump
2016 BMW M4 GTS |
05-04-2016, 08:54 PM | #26 |
Rep 1,726
and lastly...
mounted my trusty RE71Rs, installed studs and spacers. a bit of a compromise in sizing. I wanted to run apex 17x8.5 wheels with 245/40/17 but ran into some funding issues (closing on a house) and had to conserve. Instead, I mounted 235/45/17 onto my stock 17x8 rims. they are just a tad bigger in diameter and circumference compared to the 225/45/17. about 1.4% bigger. i think it fills out the wheel well nicely. alittle more sidewall than i wanted though
2016 BMW M4 GTS |
06-14-2016, 01:42 PM | #29 |
Rep 922
Very nice, I like the build so far. If you don't mind me asking, what was the price you paid for the car alone? I'm trying to get an idea of how much it costs to buy one and get it up to speed. The E36 M3 has always been one of my favorites.
Max
2006 330i 6MT Jet Black / Black
06-14-2016, 06:29 PM | #30 |
Rep 1,726
i paid $7800. alittle steep, but was the only car that 1)wasn't a rust bucket 2)unmolested 3)had complete records and 4)passed a PPI
2016 BMW M4 GTS |
06-14-2016, 06:30 PM | #31 |
Rep 1,726
it was fun while it was up and running. encountered an unrecoverable engine problem and had to retire.
car is being fixed and put together this week.
2016 BMW M4 GTS |
06-14-2016, 07:54 PM | #32 | |
Rep 922
Max
06-15-2016, 07:17 AM | #33 | ||
Rep 12,310
I do firmly believe that if you are going to pull the trigger, do it now rather than later. Every time I check, the price keeps going up. Quote:
Good thing these engines are horribly expensive.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
06-21-2016, 04:52 AM | #34 |
Rep 3,870
What happened to the engine?
Hiccups? Now that you ran it on the track once, what other mods or improvements do you see requiring or needed next? |
06-27-2016, 06:52 PM | #35 |
Rep 1,726
I money shifted.
no one to blame but myself. I was running M Performance engine mounts and UUC black durometer transmission mounts + enforce cups. was caught up in the moment, meant to shift from 3rd to 4th but ended up in 2nd. engine lost compression. CEL came on. pulled over immediately and shut her down. TL;DR. had "new" motor put in. It was a well maintained 134k motor, passed compression tests. I had a shop transfer my baffled oil pan (did the OPN mod), t-stat and housing, and stewart pump. I also had them delete the A/C (was on the fritz anyways), and installed smaller pulleys. Back in the car it went, but also replaced the stock flywheel with a lightweight one, new OEM clutch and AKG Motorsports shifter. I picked her up last weekend. She feels like a new car. (basically is) my wallet hurt....alot.
2016 BMW M4 GTS |
10-03-2016, 06:39 PM | #37 |
Rep 1,726
Audi Club HPDE @ Dominion Raceway
ACNA_Dominion_9_2016_8 by Neil Lee, on Flickr ACNA_Dominion_9_2016_15 by Neil Lee, on Flickr
2016 BMW M4 GTS |
