E93 Scratches on Rear Cupholders
04-12-2023, 09:57 AM | #23 | |
Rep 445
Drives: '11 E93 M3 6MT, '08 E92 335Xi
Appreciate you've successfully done this and can share the magic!
Pete
S65Hunter1187.50 |
04-13-2023, 08:26 PM | #24 | |
Rep 1,462
"]https://ibb.co/bdBfpFJ][/url][/URL]
2008 328i e93- 3SIM, StageFP tune, magna flow #12148 muffler + vibrant resonator, BMS filters, Bilstein B8s, H&R sport springs, ECS sway bars, whiteline rear subframe bushings, rouge engineering trans mounts, custco front strut bar, M3 front lower control arms. Cosmis R1 18x8.5 245/40 front 18x9.5 255/35 rear.
04-14-2023, 09:17 PM | #25 |
Rep 6
Thanks for the picture. I am also having problems taking the cup holder out. I tried prying at the points you are showing, but I had to stop because I felt I was getting close to braking it.
I plan to paint it in situ, after I cover the rest of the area. |
04-26-2024, 02:18 AM | #26 |
Rep 1
Just finished replacing mine, and found a very simple method to undo the hinges. Insert flathead screwdriver into the slot and twist/rotate it so the screwdriver is causing the main body to flex inward away from the hinge. It literally just pops up and out when you do that.
StradaRedlands4994.00 |
