07-18-2023, 10:33 PM | #1 |
17
Rep 91
Suspension creaking noise out of nowhere (video)
https://youtu.be/AjzlWJtSaOw
58,000 miles lowered on KW HAS driving home from work. Everything was fine. I took a side street to beat some traffic. There was quite a bit of potholes in two speed bumps which I went over pretty slow speed but after that the car started making a crazy squeaking and clunking noise anytime I went over a bigger bump, and when I would turn left or right , I lifted the car check the sway bar bushings sway bar end links the coil. Everything looks tight and in good working order. Any idea what this could be? Could it be ? a ball joint? |
07-20-2023, 10:58 AM | #2 |
223
Rep 396
same noises started happening to me @ 20K miles and after nailing a pothole on dinan has.
control arm bent and/or bushings blown out.
current: 23 g20 m340ix
previous: 2016 f10 m5 /// 2017 f80 m3 zcp /// 2004 e46 m3 zcp /// 2010 e90 335i msport |
07-29-2023, 06:41 AM | #4 |
138
Rep 214
Does the sound stop completely once the engine is warm? If so, I may have the same problem when going slow over speed bumps. I’ll get back with you if I resolve it. I’m looking at the lower control arms first.
Current:2021 Mazda MX5, 2013 BMW M5 Tuning Tech Stage 1, 2013 Buick Encore, 2013 Chevy Traverse LTZ
Past: 2002 Jeep Grand Cherokee, 2014 BMW 550i MSport, 2005 Jaguar S-Type R, 2000 BMW 540i, 1997 BMW 540i, 1997 WS6 Pontiac Firebird, 1992 Eagle Talon TSI |
07-31-2023, 10:36 AM | #5 |
381
Rep 319
i have the exact same issue that just started @45k miles on stock setup. It sounds like a spring or something creaking just like in your video. Mines not as bad as yours yet. Now I will look into swapping out those balljoints for something like powerflex/monoball
-=SpeedProtocol=- 2014 M5 Sakhir Orange- BPM Stage 1 - Soul Performance Exhaust - PG Intakes - CarboTech 1521 Pads - Turner Monoballs 2021 M5 Motegi Red- Stock |
