BMW M3 Forum (E90 E92)
      04-25-2016, 02:08 PM   #45
SR-71
SR-71's Avatar
Drives: 09 E90
Done! Thanks OP for the great write up. Only took 3hrs to complete. That's saving $285/hr
      04-28-2016, 02:59 PM   #46
audioMeth
BTC maxi
audioMeth's Avatar
Drives: F80
Originally Posted by VictorH View Post
Does anyone have the torque value for the thermostat cover cap bolts?
Thanks
throwing a thermostat code @45k miles looking for torque specs as well.
      07-09-2016, 10:18 PM   #47
kb9uwu
Supreme Czar
kb9uwu's Avatar
Drives: AW E90 M3 6MT (GONE)
Thanks for the DIY! Did this yesterday. I kept the injectors connected and lifted them up slightly to get enough clearance to remove the tstat housing. Was too lazy to unhook each injector, but it worked out ok!
Turns out old tstat was fine, it was a faulty coolant temp sensor in the tstat housing. Oh well, new one installed.
      07-12-2016, 07:34 PM   #48
da jemster
da jemster's Avatar
78
Drives: E46 M3,E93 M3,F22 M235i,i1 i3
Thanks for this DIY! I too kept the injectors connected.
'04 E46, '08 E93, '16 F22 M235i, '17 i01 i3
      07-21-2016, 10:26 AM   #49
Richbot
Drives: Jerez Black E90
For all who have done this, has replacing the t-stat resolved the 2B59 code for you, if you had it prior to the replacement? I'm not getting an SES but when I pull codes as a matter of routine checks or whatever, it is setting this code periodically
      07-21-2016, 03:04 PM   #50
da jemster
da jemster's Avatar
78
Mine was P0128
      07-24-2016, 04:46 PM   #51
azndrunk74
Drives: Frozen Black F10 M5
i had code 2b59 and replaced both the thermostat and thermostat sensor. might as well since you are taking the housing apart. the sensor is only an additional 2 minutes of work. replacing both resolved the issue for me.
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
      07-25-2016, 11:37 AM   #52
kb9uwu
Supreme Czar
kb9uwu's Avatar
I also had 2b59 (for months). I replaced both tstat and sensor and it was only the sensor. Buy and replace both "while you're in there."
      07-25-2016, 12:10 PM   #53
nholmes
Track Whore
nholmes's Avatar
Drives: women wild
Good call on the sensor. I wish I would have known about this when I had the car apart.
Oh well, we'll see how long it lasts.
Originally Posted by ridinwide View Post
Even though you answered my PM like you're missing a chromosome or have some other issues I still want these.
      07-25-2016, 03:26 PM   #54
azndrunk74
the tricky thing is that 2B59 doesn't pop a cel. the car will take forever to warm up, defaults to a rich tune, your mpg takes a hit, and you will be down on HP.
i dyno'd my car a few weeks back and it was significantly underpowered compared to my friend's stock m3. the hp curve looked strange up top. i was pretty bummed and eventually traced it back to the thermostat sensor and read up on all the issues it can cause.
after replacing spark plugs, thermostat, thermostat sensor, and throwing in an underdrive pulley my car feels significantly faster than the stock m3 (as it should, since i also have test pipes).
      07-25-2016, 03:35 PM   #55
nholmes
Track Whore
nholmes's Avatar
Drives: women wild
Good to know, I'll keep this in mind if my car starts doing this
      08-03-2016, 09:14 AM   #56
Richbot
Yeah mine's been popping 2B59 intermittently for months and isn't really exhibiting any other strange behavior or a mileage hit, but it's warm out. Good note on the things the ECU does with that signal I didn't even think about that
      02-01-2017, 11:45 AM   #57
Locksmythe
Locksmythe's Avatar
Drives: 2009 e92 M3 AW/FR
Originally Posted by nitrojunky View Post
got a p0128, just did my thermostat.
the above idea for the transfer pump works excellent. i barely dripped anything; i could probably have done this job in my street clothes.
one lesson i learned while doing mine: be sure to lube up the o-rings and/or align the thermostat body very carefully; i cut two o-rings during installation and discovered it only after letting the car warm up and finding a very noticeable leak. got to R&R the intake manifold a second time. that said, having done it twice now, i find R&R of the intake manifold very easy. all hose clamps can be accessed with an ~6' socket extension. the hardest part of the entire job is cleaning off the old gasket material from the housing and block.
I also found a leak after complete reassembly. Apparently it is okay to test without putting the plenum back on, so I will do that next time. I had bought 5 of the small o-rings for the back, but mine looked good so I didnt change them. I fear the issue may be the ones in the front because the housing appears to have sharp edges where the hoses attach from the radiator.
I also did not disassemble the fuel rail, though I tried and was unable to get the screws to budge. Lifting the fuel line that crosses the housing out of the plastic clip was sufficient to allow access. Perhaps it led to the o-ring damage, however. Will try the dish soap recommendation, unless there is another recommended fluid to use. Perhaps a little undiluted coolant?
The hardest part for me was the hose at the top right corner of the plenum. had an impossible time disconnecting and I think i broke part of the release ring on the hose when I reassembled, which may make the second disconnect to find the leak that much more horrible. We'll see.
      02-01-2017, 07:07 PM   #58
Richbot
I did not remove the fuel rail hose either. No leaks so far. New hoses and rear o rings and I spent a good long while cleaning everything before putting it back together
They probably leaked because you didn't replace. My new rings were much more pliable than the old ones
      02-02-2017, 04:06 PM   #59
Locksmythe
Locksmythe's Avatar
Apology for the double post, but some may read this forum more than the other.
Where do the four O-rings go? My housing only had two of them on the engine block side. on the front side the o-rings were integral to the hoses and were larger.
      02-02-2017, 06:36 PM   #60
Richbot
That's all of them
      02-02-2017, 08:45 PM   #61
JsL
Drives: 2011 AW M3 ZCP
I posted this in another Thermostat thread, but ECS tuning has a Thermostat replacement kit and it has 4 orings. It could be a mistake, but just adding that bit of info to this thread.
https://www.ecstuning.com/b-genuine-...11537836155kt/
      02-03-2017, 07:01 AM   #62
Richbot
D'oh I'm an idiot the two connectors on the back of the tsat housing have one of those o rings at each end. My connecting pipes would not budge from the housing so I didn't even realize they were separate pieces
      02-05-2017, 11:17 AM   #63
Locksmythe
Locksmythe's Avatar
Turned out the O-rings listed in the other thread are incorrect part numbers. they were way too small.
If anyone has the correct part number I am sure many would appreciate it.
      02-05-2017, 04:09 PM   #64
Locksmythe
Locksmythe's Avatar
Now I have managed to crack the clamp ring on the idle control valve tube that connects at the top right corner of the plenum. I tried JBWeld plastic epoxy but it didn't hold. That hose is $70... Any other way to get one of those connectors?
      02-05-2017, 05:05 PM   #65
gfisher99
Drives: '11 E92 M3, '18 M2, '22 X3M
Hey guys - I've had an annoying noise that I've been trying to track down and I think it may be my water pump. When I put a stethoscope on the metal pipe that goes into the block from the coolant expansion tank and presumably out to the heater core (its the metal, 3-way pipe), I can hear the whirring noise very well. If I put the scope on pretty much any other part of the engine, I cannot hear it.
I've also started getting the 2B59 code along with the very long warmup times (in excess of 15 mins of 60mph driving). I know the thermostat needs replacing but will gladly replace the pump if it cures the noise I am hearing.
I have posted this video before and people said it sounds like a normal S65, but I have heard a few others in person that do not have this noise. Please take a listen to the video, specifically between 27-43 seconds. It sounds like mechanical gears or something. Could this be noise from the water pump?
Please let me know what you guys think?
      02-06-2017, 08:24 PM   #66
andym3
Drives: 2010 m3
Can someone confirm if this is the correct O-ring before I buy them?
diy m3 e9x, e9x m3, repair, thermostat
m3post
