Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > **Bluetooth Retrofit Guide** for TCU and ULF
      07-21-2012, 10:37 PM   #111
ChuckD05
NeedsMoarBoost
Drives: 08 135i / 06 e90 325xi
anyone retrofit blue tooth into a CIC idrive 09 e92?
if so LMK
thanks
08 135i 6m - 12.1@120.2 2.0 60ft - JB4/Meth - SOLD
09 335i e92 Mtech - RB FBO
      11-14-2012, 09:48 AM   #112
The1Ash10
15
Drives: BMW
So, I have an e90 330i with bluetooth and would love to be able to play music through my phone. Is there any additional add-on that I can get to be able to perform this function?
      11-30-2012, 05:38 PM   #113
tcw
Drives: 2008 335i
Mulf2 & TCU for sale
200 shipped each
http://www.e90post.com/forums/showthread.php?t=774290
2008 335I E92, AW, VFF700, 18" Forgestar F14, M3 front/side, M-tech rear, AMS IC, H&R Touring Cup Kit suspension, HID AE, ER Charge Pipe & Synapse BOV, CIC Retrofit, Quafie, DSS, Defiv Lockdown, SPEC 2+/Steel SMFW, Walbro 450
      12-15-2012, 10:44 AM   #114
spottv
Drives: bmw 335i coupe
e92 mulf
hi i have a 335i e92 with cables in boot i managed to get a mulf unit 84.21.9-111718-01 which will take the cables.
Does this allow BT etc. I prsume coding to be necessary.
      08-31-2013, 04:42 PM   #115
BlackTyEvent
Boy Wonder
Drives: 2007 328i - Jet Black
over $1000 all said and done? ill pass.
      09-25-2013, 07:17 PM   #116
Augster
Master Gunner
77
Drives: 2008 335i Sport
Want to add another success story for retrofitting a 2011 GSM TCU, as suggested by Dracon, into my 2008 335i, build date 02/2008. I also put in a 2011 FZD, but apparently the newer cars are using the same FZD part numbers, including the mic.
I didn't even have to do any programming as my S640A Telephone pre-prepped car automatically sensed the new components and the activated Bluetooth module from the donor car, enabling pairing with my iPhone 5 and activation of voice recognition. But the system can't "hear" me so I'm thinking either the mic is bad, or the connections are not seated properly (or maybe I really have to do "some" programming or reset). Will have to check it tomorrow.
FYI, the S640A package already includes the backup Bluetooth antenna. I discovered that after pulling the rear package shelf to install the new one I had purchased.
      09-26-2013, 12:06 AM   #117
Dracon
Drives: 2013 F10 M5
2013 BMW M5  [0.00]
If I remember my retrofit correctly, you still need to do some coding. $640 is the telephone prep, but when you officially retrofit $640 is removed and it's replaced by $639. Then everything should work 100%.
I'll have to check my ISTA/P reports when I get home on Friday night.
      09-26-2013, 08:23 AM   #118
Augster
Master Gunner
77
I've read about two others having mic issues, and one of them seemed to involve a pair of mics (phone and nav) and 2 vs 3 wires to the phone mic and had to re-pin a clear-sheathed wire and yellow wire at the fuse box. I hope I don't have to resort to this method as the FZD and mic are the same part numbers for my Model Year application (even though the assembly came out of a 2011).
I also have never actually "coded" VO's (when you add $639 will $640 automatically be removed or do I need to manually remove it?) yet with NCS Expert; I've only run the new battery registration job, which is relatively simple and straight-forward. So I'm still wrapping my head around what exactly I need to do with modifying the code file, which modules I need to "touch", and what other "jobs" I need to run (like "SG_RESET"). I do have all the software and profiles I need to accomplish the task.
      02-16-2014, 03:42 PM   #119
Augster
Master Gunner
77
This is to provide closure to this issue as I finally resolved the non-functioning mic!
Hopefully, my experience and solution will help others performing a Bluetooth upgrade that already has the 6FLA USB/Audio Interface package installed.
2008 335i Alpine White Sport Sedan AT | Avant Garde M364 Staggered 19"
      06-29-2014, 10:11 AM   #120
monkeyalan87
Drives: 120d M Sport
Great guide thanks!
      07-22-2014, 05:00 PM   #121
datbimmer
Wastegate Rattle
113
Drives: 335i m6t nav sport
I tried reading through the thread but I still am not sure. for a 07 335i which already has voice recognition, Do I need TCU or MULF ?
