Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY: Install SSD in CIC
      02-25-2020, 11:55 AM   #89
nsjames
Drives: 08 328xi Touring
you open the software manager and you type n those package names and you let it do it for you.
your biggest isue is running it from a flash drive.
it won't work as such.
put it on a second partition.
      02-27-2020, 09:01 AM   #90
Beachparty
Drives: F30 335i
So I have Linux Mint installed on a separate partition. It’s up to date.
However I can’t manage to find QNX or VM player in the software installer.
Is there other repository I can list so Linux finds them ?
Sorry for my lack of Linux knowledge... this is all new to me !
      02-27-2020, 09:35 AM   #91
opjose
opjose's Avatar
242
Drives: 335xi
https://itsfoss.com/install-vmware-player-ubuntu-1310/
Follow those instructions.
      03-01-2020, 11:41 AM   #92
Beachparty
Drives: F30 335i
Originally Posted by opjose View Post
Nice ! Thank you… I'm trying this right now
      03-01-2020, 11:56 AM   #93
Beachparty
Drives: F30 335i
So that part went well and it says VMPlayer successfully installed.
However nothing happen when I try to open it…. Is there something else I should do in order to run the software ?
      03-01-2020, 03:32 PM   #94
opjose
opjose's Avatar
242
Drives: 335xi
How are you trying to run it?
      03-07-2020, 11:02 AM   #95
Beachparty
Drives: F30 335i
By double clicking it ??
      03-07-2020, 03:38 PM   #96
opjose
opjose's Avatar
242
Drives: 335xi
Since the Vmplayer does not know which file to open it may just terminate quickly.
Try running it from the command line to see what is actually happening.
      03-07-2020, 03:51 PM   #97
Beachparty
Drives: F30 335i
I tried to open the QNX Neutrino file using "open with" and select VM Player but no joy there.
What would be the command line to run the software from command ?
      03-07-2020, 04:34 PM   #98
opjose
opjose's Avatar
242
Drives: 335xi
If you have bash-completions turned on as most distros do then type vm and hit tab a couple of times to see all of the available matching commands.
You may also try
man vmplayer
and
apropos vmplayer
To find commands.
      03-14-2020, 12:54 PM   #99
Beachparty
Drives: F30 335i
You may also try
man vmplayer
and
apropos vmplayer
To find commands.
Well.... no joy with any of those !
Is there any ways I can work on expending the partitions with a Windows based software and eventually change the extension format using fdisk tools ?
Or maybe someone can direct me to a VM machine that already has everything installed and working... maybe I could manga to connect to one of those using a windows system...
      03-18-2020, 04:32 AM   #100
user0011
Drives: E91 330d
Hi there,
I have the same plan, backup worked. My CIC recognizes the SSD and the navigation works.
However, if I now want to change the participations according to plan in GParted, I get the following error when i apply the changes:
move partition to the right and grow it from 74.53 GiB to 74.53 GiB - Error
Link Picture: https://www.bilder-upload.eu/bild-c3...23904.jpg.html
And try it again and again... but it doesnt work.
How can I solve it?
Thank you so much.
      03-18-2020, 11:54 AM   #101
Giuseppean
Italy
Drives: 320d '09, X1 18d '20, 318is'95
Thanks for this diy, I'll try it!
      03-21-2020, 12:19 PM   #102
user0011
Drives: E91 330d
Hello,
now the partitioning has finally worked. But now I have the problem that my hard drive appear as two devices with the newly created partitions.
Screenshot: https://ibb.co/b1Ts3wY
What am I doing wrong?
Thank you
      03-31-2020, 02:05 PM   #103
Beachparty
Drives: F30 335i
Update
So I have managed to make it work under a Windows based system.
The whole backup works and the new drives loads in the car
When it comes to extend the music partition, I managed to mount all the folders to the temporary root/folders I have created.
I’m stuck at mounting my USB smemory stick that I want to use to store the data while I extend the partitions. I always get an error message.
This is what I use to mount
mkdir backup
mount -t qnx6 /dev/hd2t7 /root/backup
This is the answer I get
Can’t mount /root/backup (type Qnx6)
Possible reason: Corrupted file system detected
Any thought ?
      04-05-2020, 01:49 PM   #104
Beachparty
Drives: F30 335i
Another update
I found the way to mount the flash drive so I managed to backup the two folder onto it.
I did the partition size change then went back to QNX to format the new partitions, however there names have changed from hd1t77.4 to hd1t131 and hd1t77.5 to hd1t131.1
I formatted both new partitions then mounted them so I could write the data back onto it.
Everything went fine but the car will no see the music partition or the size of the media library.
Is this because the names have changed ?
Thanks
Edit : I think I found the problem. I forgot to validate the partition extension change in GParted
      04-06-2020, 01:23 PM   #105
user0011
Drives: E91 330d
Did you solve the problem with that?
In my post above, i have the same problem.
Thank you!
      04-07-2020, 09:32 AM   #106
John.duh
Drives:
Just went through the procedure myself. Managed to follow it to the end and will test in the car tomorrow.
Wish me luck :-)
Update
mkdir backup
Any thought ?
You should mount /dev/hd2t77.4 /root/backup
If you ommit the .4 you're mounting the entire disc and not the partition you need.
      04-07-2020, 09:43 AM   #107
John.duh
Drives:
Originally Posted by user0011 View Post
Hello,
Thank you
Did you change the partition type to 4d instead of 83 ?
These are the commands:
Code:
sudo fdisk /dev/sd(insert correct letter here)
command : t
partition : 9
partition type : 4d
      04-10-2020, 05:12 PM   #108
user0011
Drives: E91 330d
Code:
command : t
partition : 9
partition type : 4d
Yes I did, but same problem
      04-11-2020, 04:01 PM   #109
opjose
opjose's Avatar
242
Drives: 335xi
It looks like you created a Linux ext2 file system on the drive as well as the qnx partitions.
See http://www.qnx.com/developers/docs/q...artitions.html
Your drive is not appearing as two devices.
Your drive is appearing as one device with two partition tables, one for ext2 and one for qnx.
      04-21-2020, 08:25 PM   #110
POBEP
POBEP's Avatar
Drives: E70 E90 E91
Huge thanks to Jagaer for great DIY!
I went with Micron MTFDDAT128MBD (you can get it today from flebay new for $30USD plus shipping).
Toughest part was pulling out trim without breaking something.
If you unlucky (like me) to have automatic transmission, you may need to shift to N or D to get enough room for drive to come out.
(remember to keep parking brake engaged).
Before pulling drive out, I waited for car to go to sleep and disconnected battery.
I forgot to buy a PATA-2-USB (or PATA-2-SATA) adapter.
Dell 700m was commenced as substitute (I used it last when my bought E91 in 2010)
This was not a great choice:
- old PC hardware is slow. very slow. way too slow. not worth your time.
- most modern linux distributions refuse to boot on 15year old platforms (few hours to try-and-fail)
- YUMI and UBCD with g4u did the job of booting, imaging and cloning
Old drive health report showed quite a number of relocated sectors.
I created original image backup, then cloned disk-to-disk and made another image of the cloned drive.
Finally, I compared MD5 checksums of the original and cloned images (big fan of testing, cause I am human)
Since I disconnected the battery, I had no need to reset CIC unit.
It powered right up, before I noticed my music was playing.
Flebay link:
https://www.ebay.com/itm/New-Micron-...D/223496341305
I actually got mine from another seller (due to temporary store closure with one above)
Make sure yours comes in a sealed electrostatic package.
The (unlisted) seller sent me an open box item and was very rude when I asked him to replace it with new one.
