My CIC Combox 6FL retrofit log (and DIY focused on coding)
12-30-2019, 06:57 AM | #67 |
Rep 1,352
12-31-2019, 07:57 PM | #68 |
Rep 1,352
UPDATE : I ve successfully installed the version 2.0.2 to my other laptop. Since I am far from the home , being without the OBD cable , might causing software not to open after the first time. I will check it around Sat and report back.
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
01-01-2020, 01:33 PM | #69 |
98
Rep 121
It will open without a cable. It won’t open if you don’t have Java installed, so that might be the issue. Also I noticed you said 2.0.2 again which is the wrong version, hopefully you used 2.2 (02.02) as instructed!
01-03-2020, 01:28 PM | #70 |
Rep 1,352
Ok. Java is installed. It opens the software after the installation but not after exiting out. And I will double check the version. You might be right i think i have the wrong version.
01-03-2020, 04:35 PM | #71 |
Rep 1,352
I have succesfully installed the Version 02.02 to my main laptop. The reason CIP installer was showing the start button disable was the previous version was installed before and in order to activate that button you need to go to older version installer .bat then click uninstall them it allows you to install the software properly.
The issue I am having with the 02.02 is Java. "luckily I have a screenshot software that I can screenshot the problem right before the cmd page dissappears" so it says Java Home is not set to valid java installation. What I dont understand is the previous version had no problem to open it. Java home still in the EC-APPS as JavaSoft/JRE/1.5.0_22 and I opened the current Start_FSTool_v2_CarServer.bat with notepad. It says SET JAVA_HOME=C:\EC-Apps\JavaSoft\jre\1.6.0_22 Additionally echo.Please set JAVA_HOME to your Java directory (Version greater or equal 1.5) I even edited and changed to : SET JAVA_HOME=C:\EC-Apps\JavaSoft\jre\1.5.0_22 But No luck! So annoyed with this very simple task UPDATE : I don't know how but after trying about an hour I was able to run the correct version with Java and I was able to activate the 6F All I need to do is wait for the cable and connect from CIC to trunk. Everything is in the menu. I also checked the combox version. Luckily seems like it is the latest version. Thank you so much Last edited by SaNGRia; 01-04-2020 at 12:08 AM.. |
01-05-2020, 01:10 AM | #73 |
Derbo Tuning
3610
Rep 3,022
Thanks for documenting this!
I'm in a saga to convert to combox as well. I ended up ordering kufatec adapters so I can reverse if necessary. What exactly does $644 do differently than $639?
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
01-05-2020, 07:20 PM | #75 |
Rep 1,352
I have finally done everything and Everything is up running.
I had to use my daughter's iPhone to activate the Apps and it works like a charm. But I thought you can use the apps without the phone is connected.
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 01-05-2020 at 07:40 PM.. |
01-07-2020, 10:15 AM | #76 |
98
Rep 121
Yes, I definitely think it's more of a road trip feature than daily commute feature. It's nice to be able to push addresses to the navigation from the phone, and switch playlists on long drives... but most days I prefer to just use Bluetooth.
SaNGRia986.00 |
01-07-2020, 06:20 PM | #77 | |
Rep 1,352
But I am really surprised no one came up with the idea running the Androids when CIC was hot.
01-12-2020, 01:56 PM | #79 |
Derbo Tuning
3610
Rep 3,022
I was able to make the combox work successfully. Does the combox Bluetooth name reflect the last 5 on the VIN? How do I change that?
Just kidding! Forgot to recode the MEDIA in ncsexpert
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services Last edited by derbo; 01-12-2020 at 04:11 PM.. |
02-26-2020, 11:16 PM | #80 |
Derbo Tuning
3610
Rep 3,022
Does anyones SOS button randomly turn on green solid for two seconds and then turns off randomly while driving it? I didn't tap the CAN high and CAN lo wires to the PDC.
IG:ruhrohz_m3
02-27-2020, 03:04 PM | #81 |
98
Rep 121
Hmm, I personally haven’t seen that, may one someone else here has. The lights are wired directly to the combox, maybe one of the LED wires is shorting?
02-27-2020, 07:16 PM | #82 |
Rep 927
03-14-2020, 12:50 PM | #83 |
Rep 38
Thank you for the write up! Very detailed. After everything is all said and done, I'm only getting artist name, album name, and title but no album art when streaming over Bluetooth. Is this normal, or is there a way to get the display to show it? Thanks again.
03-14-2020, 01:25 PM | #84 |
98
Rep 121
That is normal, Bluetooth does not transmit album art (it’s not in the A2DP protocol at all so no current standard headunit can do it). You can get album art if you hook up the phone to the combox via USB (6FL).
There is also an option for an MMI unit that provides wireless CarPlay from kersermino I believe. I have not tried this. |
03-15-2020, 01:55 AM | #85 | |
Derbo Tuning
3610
Rep 3,022
IG:ruhrohz_m3
03-15-2020, 10:05 PM | #87 |
Rep 38
03-15-2020, 11:14 PM | #88 | ||
Derbo Tuning
3610
Rep 3,022
My goal was to have somewhat an OE like Apple CarPlay feel. It is very close to what it is like in my Honda Civic and I'm happy I don't have to have an android unit screen replacement just for Apple CarPlay.
IG:ruhrohz_m3
