DIY: Improved Oil-Catch-Can System Keeps Oil Out of Intake Ports and Valves
03-25-2024, 11:57 PM | #1 |
Electronics Engineer
39
Rep 125
Why another PCV/Oil-Catch-Can Topic? Because the majority of catch-cans don’t work very well, and the direct-injection engine is vulnerable to severe oil-fouling of the intake and valves. Especially since BMW makes the PCV system inaccessible.
Background: At 120k miles, my N54 engine was spluttering and misfiring, shaking during idle, hesitating and jerking during sedate, low RPM driving, and smoking from the tailpipes. Downright embarrassing. I’d already installed an oil-catch-can on the high-side (boost) flapper, replaced the PCV valve, the valve cover, the spark plugs, the coils and the injectors (brand new index 12s), all to no avail. Walnut-shell blasting was next on my hitlist. As I dismantled my intake, I was appalled to find PUDDLES of oil throughout the intake system. Since the intercooler was swimming in oil too, I suspected the turbo seals, but the cause turned out to be the shockingly bad PCV system. Only 20k miles after walnut-shell blasting, my sparklingly-clean intake valves were again CAKED in oil and more puddles of oil were found throughout the intake system. I flipped my lid and began some research into proper oil-separation techniques. The Weakness of the N54 PCV System: This engine has a dual PCV system. The low-side (vacuum) PCV valve and its channels are built into the valve cover and are inaccessible to oil-catch-cans. The high-side (boost) flapper opens into the rear turbo intake. Sadly, if the low-side PCV system fails or becomes restrictive, the crankcase becomes pressurized and the vapors escape through the boost flapper, the turbo, the intercooler, the charge pipe, the diverter valves, the throttle body, the intake manifold and the ports, carrying loads of oil with it. To prevent oil-fouling, this oil needs to be extracted from the vapors on the low-side AND the high-side of the PCV system. The low-side is certainly the most critical. The External PCV Solution: An aftermarket “External PCV System” with a reliable, high-flowing PCV valve (like the one from “RB Turbo”), coupled with a good oil-catch-can, is a necessity to keep oil out of the intake ports. Note that certain “upgraded” aluminum PCV valves may be “reliable”, but very restrictive, resulting in oil-fouling through the turbo. Ask me… I know! The Weakness of Oil-Catch-Cans: When I tested a variety of catch-cans, I was pretty dismayed at the results. Most of them (even pricey ones) are pretty poor at extracting oil, water and fuel from the PCV vapors because they do not employ the best separation techniques, allowing much of the oil vapor to pass right through. To monitor the performance of these cans, I installed two compressed-air oil/water separators in series with each catch-can. On average, most catch-cans caught about half of the oil in the PCV vapors and allowed the rest to pass through. This is due to design flaws, guesses, or design compromises, such as space and cost constraints. These vapors are extremely hot, and they flow through the top of the can for a very short distance at high speed, leaving little opportunity to extract enough oil. The ultimate goal is to CONDENSE liquids out of the hot vapor. It’s not that difficult! Distilleries do this all day long. Here’s how... The Best Catch-Can Solutions Combine Four Methods of Oil/Fuel/Water Separation:
Some consumer catch-cans rely solely on a large expansion chamber, others combine a rudimentary baffle, whereas others (like the Michimoto cans) employ a sintered brass baffle element. All of these work to some degree, but are still inadequate. For example, if a sintered brass baffle element is designed into the outlet side of the can, that baffle will condense oil, but high-speed air through the outlet will suck that condensing oil straight into the intake manifold, faster than it can drip into the can. I’ve only found one OCC design that is based on thorough research, design and simulation. Of course, it costs a fortune. My quest led me to fabricate a custom system that works incredibly well for very little money... Last edited by GSB; 03-26-2024 at 03:14 AM.. |
03-25-2024, 11:58 PM | #2 |
39
Rep 125
Building a Better Catch-Can:
To begin with, the generic can shown below (WITHOUT breather) can be found on Amazon, eBay and many other places for around $20, and it makes an excellent starting point because it combines a few great features:
This can is not perfect, but a few simple mods can make it far more effective at oil separation...
WARNING: Do not use steel wool, which can rust and allow tiny metal fragments to be sucked into the engine! When cutting and packing the coarse stainless scrubber, be gentle with it, don't stretch it, and be cautious not to create shards that might come loose and fall into the can. Last edited by GSB; 03-26-2024 at 02:45 AM.. |
03-25-2024, 11:59 PM | #3 |
39
Rep 125
A Home-Built Condenser Perfects the System:
The modified catch-can does a pretty admirable job of extracting oil. However, I went one step further to ensure that NO oil makes it to my valves. I built a condenser out of a cheap, single-walled stainless-steel water bottle with dimensions about 9.25” x 2.75”. (Do not use double-walled thermos-type bottles). These bottles cost about $15 new, or $4 used. I picked one up from Goodwill for $2.50, then drilled and tapped both ends for 3/8” stainless steel barbs. I PACKED the bottle with as much course stainless-steel scrubber material as I could cram in there. This bottle is not at all restrictive to PCV airflow, yet, when laid on its side, it forms the ultimate velocity-slowing, abundantly-baffled, oil separator. At LAST, I have an oil-free intake system, with no more oily valves, no more performance issues, and no more smoking! The spark-plugs don’t foul anymore either, so they last much longer.
I regularly empty tablespoons of oil/fuel/water sludge out of the modified oil-catch-can, but nothing has ever dripped out of the stainless bottle. After a year or so, it certainly stank of oil, so I half-filled the bottle with gas and shook it for a few minutes. The gas came out almost black, indicating that it is indeed trapping plenty of oil. The diagram illustrates how the incoming vapor (blue) slows and spreads as it hits the wide bottle diameter and extremely convoluted stainless baffle inside. Gravity pulls any condensing oil (red) to the bottom of the can, while the clean air exits at the top. As that stainless material becomes sticky with oil mist, it only becomes more effective at trapping oil. Last edited by GSB; 03-26-2024 at 03:21 AM.. |
03-26-2024, 12:00 AM | #4 |
39
Rep 125
Placement of the Completed System:
Here’s how the system is placed in the engine bay. I haven’t painted the condenser bottle black yet because it makes people laugh…
03-26-2024, 12:01 AM | #5 |
39
Rep 125
Below are the hose connections for the RBTurbo External PCV adapter and the boost flapper…
03-26-2024, 12:02 AM | #6 |
39
Rep 125
Below is the intake manifold, drilled and tapped, with a 3/8” barb for the RBTurbo External PCV System. This is the perfect spot for the PCV hose to clear the throttle body and to avoid stress-cracking of the plastic manifold…
03-26-2024, 12:03 AM | #7 |
39
Rep 125
One more thing to bear in mind… When the low-side (vacuum) PCV system is working correctly, little to no oil gets through the boost flapper and into the high-side oil catch can. Usually, there’s only a mist of oil at the bottom of this can, or at worst, a millimeter or two. If you suddenly notice oil puddling in the high-side catch can, something is probably failing on the low-side. The PCV valve may be becoming restrictive or the PCV vacuum may be leaking somewhere. Fix it immediately to prevent your intake system fouling through the turbo, AND to prevent your rear main crankshaft seal from popping and leaking all over the place.
03-26-2024, 05:29 AM | #8 |
Rep 3,196
Drives: E92 325i MSport Coupe
Great post OP! I would be interested in your opinion on this OCC:
https://www.saikoumichi.com/internal_baffle_design.html It seems to answer some your criticisms of most OCCs. I've used it on my DI 6 cylinder (N53) for many years and it seems to do a great job. My indy recently reported minimal carbon build-up on the intake valves (at 130K+miles). He said the valve stems were still shiny bright metal...
03-26-2024, 01:03 PM | #9 | |
39
Rep 125
A white-paper addressed that very design to show how it could be further improved with a tangential outlet. The paper is entitled, "Design Optimization of an Oil-Air Catch Can Separation System" by Anuar Abilgaziyev, Nurbol Nogerbek, Luis Rojas-Solórzano (Department of Mechanical Engineering, School of Engineering, Nazarbayev University, Astana, Kazakhstan) This image, adapted from their paper, shows how a tangential outlet pipe creates a vortex swirl inside the can, keeping the vapor in contact with the walls of the can for longer, therefore maximizing condensation even further. |
03-26-2024, 01:19 PM | #10 |
39
Rep 125
An excellent reverse-variation on this design, is the tangential inlet system on the Improved Racing CCS High Efficiency, Quick Release Oil Catch Can
This design is well engineered, scientifically sound, and in this size, perhaps as good as it gets... If you can afford it. Last edited by GSB; 03-26-2024 at 03:19 PM.. |
03-29-2024, 02:08 AM | #11 |
39
Rep 125
By the way, the improved tangential outlet, referenced in the white paper above, only improved the can's efficiency to 70%, meaning that 30% of the oil in the vapor still gets through. Plus, the simulations were seemingly done without the filter in place. The filter would certainly add to the efficiency, but it would completely change the characteristics of the airflow inside, so we don't know for sure what the total efficiency would be.
Another technique used in distilleries, is the double-helix copper condensing coil (below). This makes an extremely effective high-speed centrifuge to force air-borne vapor particles into contact with the walls for much longer. Plus, copper is one of the most effective conductors of heat, so cooling capacity is a huge strength of this device. This is awesome for condensing oil/water/fuel out of crankcase vapors, and PCV hoses slide right on to the tube, but an expansion chamber with a catch can would still be required to slow the air enough to capture the condensed liquid. I've tried one of these in series with a catch can, and the results were very impressive. However, the stainless condenser I built above still takes the cake for performance, cost, simplicity and looks. |
diy, intake, occ, oil, oil catch can, pcv, valves |
