BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY: DCT paddle shifters retrofit for LCI paddle shifters
      08-02-2013, 02:42 AM   #1
tobypic
Drives: 2011 E90 LCI
I am making this DIY because there is no information about it and I don't want other people will have the same problem as I had.
If your car is 2011 LCI and you have planning to add DCT paddle on your car, you need to add resistors. Here is quote from wanlong:
Originally Posted by wanlong View Post
it wont work, and your DS should not be working as well.
for 2010 and before cars, ssg/dct paddles are just completing a circuit to ground in order to complete shift. Thats why by removing the resistors from lci paddles, they have the same functionality as ssg/dct paddles and will work on 2010 and before cars.
for 2011 cars, lci paddles are not connecting to grand anymore (no pin#2), and resistors are connecting between pin#1 and #3.
To make the dct paddles work on 2011 cars, I think the missing resistors need to add back to dct paddles in order to have the same functionality as lci paddles. I am working on add resistors back, will report after I finished.
This is not really difficult to do, so here is information how to make.
DISCLAIMER
It's your car, not mine.
PARTS
Total Kit Cost
$less $100 incl resistors, Soldering Tool Kit and heat shrink tubing
Part 1 - Resistors
- SIDE
6.2k ohm:
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
348 ohm:
+ SIDE
4.99k ohm:
1.18k ohm:
DIAGRAM SKETCH
Add resistors as diagram sketch, it works without any issues.
I would like to put some photos how I add resistors on wires, but I am writing it after I finished to put DCT paddle on my car. I will take it off tomorrow to add LED paddle, so I will update it ASAP.
      08-23-2013, 10:22 AM   #2
kenneymac
20
Drives: 2012 BMW 335is :)
great write-up hopefully it works on my setup!
      02-27-2016, 01:00 PM   #3
Supermoon
Supermoon's Avatar
South Korea
166
Drives: 2011 e92 335xi
I can't see the diagram skteches.
Could you re-upload them?
      03-04-2016, 06:22 PM   #4
Supermoon
Supermoon's Avatar
South Korea
166
For those who might wanna try this in the future.
I can confirm my dct paddles are working perfectly on my lci.
Crappy soldering but you get the idea.
BOM:
2x 61138377072
2x 61136931929
4x 61130005197
4x 61130005198
6.2K ohm resistor
348 ohm resistor (0.3KΩ is incorrect. 348Ω is the correct value)
4.99K ohm resistor
1.18K ohm resistor
heatshrink
Thanks to remlemasi.
      12-29-2019, 09:22 PM   #5
DanoSTL
Drives: BMW e70 x3.5i
Saved my bacon on an X5
I know this thread is a bit long in the tooth.
I want to reply with my sincerest thanks for posting this information. I had to UNDO turning my DCT paddles from resistance-based to switch on-off and back to resistance-based for my 2013 LCI X5 x35i heated wheel non-sport.
These adapter jumpers with the resistors led me to to finally get paddles working. I made the final connection under the hood at a connector leading to the 8HP tranny.
Cheers and THANKS A MILLION Supermoon!
      04-03-2024, 03:12 PM   #6
crm123
Drives: F01 pre LCI
Hello. I have a problem. I installed the M steering wheel with paddles from the F10 LCI 2015
My car is F01 pre LCI 2009 and the paddles don't work. The Coding is Correct.
Is the shift paddle resistance different from LCI to pre LCI?
What resistors do I need to use for the paddles to work?
Thx
      04-24-2024, 03:11 AM   #7
TiAgAu
TiAgAu's Avatar
150
Drives: E92 335i
Thx
Similar situation here. F10 wheel on a 2008 Pre-lci e92 non DCT so i would assume my original paddles aren't resistance triggered. i think that removing resisters and brigding the gap? Seems they also need to be grounded in the loop.
Anyone else had experience with similar?
See quotes again below:
