subframe bushings: powerflex yellow vs purple?
11-13-2014, 07:20 AM | #67 |
DIYER
614
Rep 5,521
installing in a few!
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
11-13-2014, 08:11 AM | #68 |
Rep 8,339
Very cool. I'm looking to do this in a few weeks and I do a ton of long drives. I want it to firm up but mot ride like a go cart rattle box. No track for me. Was thinking M3, purple, or this.
Thx again.
'08 e93 AW 335i 6MT,Vargas Stg 2+ 20T clipped,VRSF catless dps & 7"FMIC,ER chargepipe&Tial, MMP inlets&outlets,Motiv Stg 2 fuel rail&dual disc clutch/fly, JB4G5,MHD w/Motiv tune,Fuel-it Stg 3 LPFP,Wavetrac LSD w/lockdown, KwV2,M3(Strut brace,frt control arms,steering wheel)AKE blk sub bush,re11 245/305,19x8.5et30&19x11et43,SmartTop,RE trans mounts,Msport rear bump & skirts,15%tint,ZSP knob,Stoptech rotors,241k miles
11-13-2014, 01:54 PM | #71 |
DIYER
614
Rep 5,521
only thing is I don't like bleeding brakes...motors, turbos, suspension, tranny I am fine with lol! I am seriously thinking of crimping the line, taking loose, then reinstall with no bleeding. have seen a few do this method, Any thoughts?
11-13-2014, 01:56 PM | #72 |
DIYER
614
Rep 5,521
full aluminium are 299.00 and "should" be a bit harsher than delrin. Apparently delrin is not to bad on NVH according to jake@motiv.
11-13-2014, 02:00 PM | #73 |
Rep 4,088
Plus you minimally want the Al sleeves rather than just straight Delrin given how brittle Delrin is... longevity is better with this setup.
11-13-2014, 02:54 PM | #74 |
Rep 3,856
11-13-2014, 06:19 PM | #75 |
DIYER
614
Rep 5,521
Hope they are good, would of had then installed but can't give a brake bleeder...may just crimp the line lol!
11-14-2014, 08:58 PM | #76 |
DIYER
614
Rep 5,521
I can't understand why the Delrin sleeve doesn't sit flush on brace like others do? I am guessing for vibration ire some reason? Anbody know?
11-14-2014, 09:15 PM | #77 | |
Rep 5,623
I really want to upgrade my SF bushes too, but from reading your experience and this thread i'm not too convinced on the OEM M3 bushes. When you say the full aluminium ones would be harsher, how would that actually be felt in the driver's seat? Would it be harsh over bumps? Would it cause more oversteer? I currently only have Ohlins, no other suspension mods. Planning to get an M Factory diff later next year and perhaps upgrade rear springs to swifts and M3 arms. Would full aluminium be advisable? Its a 335D btw |
11-14-2014, 10:15 PM | #78 | |
DIYER
614
Rep 5,521
11-15-2014, 01:41 AM | #79 | |
164
Rep 2,556
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
11-15-2014, 04:53 AM | #80 |
Rep 4,088
11-15-2014, 08:31 AM | #81 |
Rep 1,075
I have Olhins with swift springs and yellow powerflex subframe bushings. My car is as comfortable as stock during normal driving conditions but under hard acceleration is uncontrollable and is very scary to drive as it TQ steers worse than any car I have driven.
I'm considering the powerflex black, group N or solid aluminum subframe bushings. I hate having power and not being able to use it. A lot of the m3 guys do solid subframe bushings and Delrin diff bushings. I already have purple diff bushings so it would make sense to do nothing less than black subframe bushings. I was with RobC during his Delrin install yesterday and can tell you they look even better in person. My only issue is they don't sit flush on the sub brace. I could see the bushing bolt break as the the sleeve hole is a lot bigger than the bolt. And it doesn't sit flush regardless of how you turn them. My question is: which bushing is harder/stiffer? (Powerflex black or group N) Once I eliminate one of these I can decide whether or not to make the jump to solids. I would like to think solids would be ok as my Ohlins are too soft. |
11-15-2014, 08:32 AM | #82 |
DIYER
614
Rep 5,521
it doesn't fully seat on to it, indention isn't deep enough for brace to fully seat inside bushing. It basically bottoms out before flanges on bushing make contact with brace.
11-15-2014, 10:12 AM | #83 | |
Rep 3,778
Drives: '11 328i '19 M6
http://www.e90post.com/forums/showth...light=justpete
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
11-15-2014, 10:58 AM | #84 | |
DIYER
614
Rep 5,521
You have something I have always wanted to do, the trailing arm bushings, stock I can flex with my hand and could see benefeit from this. Did you notice a difference?
11-15-2014, 11:03 AM | #85 | ||
Rep 1,075
Would you take a pic of how your delrins sit on the subframe brace? Rob's sit 1/4 inch higher than stock. |
11-15-2014, 11:14 AM | #86 |
Rep 4,088
11-15-2014, 11:17 AM | #87 |
DIYER
614
Rep 5,521
I would not want to take those delrins out...major pitia!
11-15-2014, 12:30 PM | #88 | |
Rep 3,778
The trailing arm bearings went in at the same time as everything else so I couldn't say what they did by themselves although the whole point of the work was to turn the suspension into as close a facsimile as a race suspension as possible. You'd use solid adjustable trailing arms on a racecar but a street car really should have the OE parts installed to minimize damage in the event of an accident by folding up. The spherical bearings make it as solid a link as possible given this limitation.
