02-22-2023, 04:51 AM | #1145 |
Rep 16
Hello, I bought this XTRONS 10.25"
android It seems works fine but I hame some problem wit navi gps. I installed HERE and downloaded maps for offline use but I don't have any audio. Please help me to fix this issue. But I have some issues: I installed Here maps, Maps.me, Sygic, but I haven't any vocal indications, just google maps specks throught a small speacker Do you know if I can personalized right side (android) of the screen??? thanks a lot Last edited by Il_Simo; 02-22-2023 at 05:03 AM.. |
02-22-2023, 06:05 AM | #1146 |
1050
Rep 2,369
Drives: E63 645Ci
02-22-2023, 08:47 AM | #1148 |
1050
Rep 2,369
Drives: E63 645Ci
03-02-2023, 11:29 AM | #1149 | |
Rep 29
I wanted to have a moving animation so I downloaded it from this link. (NBT boot animation) Splash file + the zip file under and made an OEM folder on the USB. I inserted the USB in the android and did nothing for the rest. Now I get a fuzzy screen when I am in the original part of the screen. Android still seem to work completely. I tried a factory reset in the android menu but this did not work. How to solve this please? What could be the problem? Did my main connection with the original menu crash? Need to fix asap because I need to sell the car.. Screen error when in original menu: Last edited by FrederikD; 03-02-2023 at 11:35 AM.. |
03-03-2023, 03:05 AM | #1150 | |||
1050
Rep 2,369
Drives: E63 645Ci
03-03-2023, 11:08 AM | #1151 | |
Rep 32
Is the info not displayed and the screen remains black? Do I have to set an image instead? Is this completely disappeared and am I already in the user menu at the time of the actual info display? Where can I find detailed installation instructions? Couldn't find anything about how to do this with the laptop Best regards & thank you very much for your patience. |
03-03-2023, 12:08 PM | #1152 | |
1050
Rep 2,369
Drives: E63 645Ci
How did you manage to miss the guide on how to install it? It's in the first post here, both as a link (KswOverlay) under Tools and as a few point writeup under TL;DR. |
03-06-2023, 04:20 PM | #1153 |
Rep 24
does anyone with A10 v3.9.4 successfully delete the phone is starting message? cause mine don't want to be deleted and the androidoverlay pushed the file with no errors, on my older version it went good.
03-07-2023, 01:22 AM | #1154 | |
1050
Rep 2,369
Drives: E63 645Ci
EDIT: both versions have identical frameworks, so I can't see any reason why my overlay wouldn't work. Last edited by RedErik; 03-07-2023 at 05:30 AM.. |
03-07-2023, 05:00 AM | #1155 |
Rep 4
Hello there,
awesome thread even though I might not get much out of it since I was reading my device with the 8259L is not supported customizing the themes. It has the ID7 theme installed stock so I thought it could work. Yesterday I got a new firmware by Xonrich for the device. Can somebody tell if the ID7 theme customization may work with my newer firmware? Also what is strange is that even the flowUX synesthesia launcher and the Drive Controller app are shown as incompatible with my device. I can install all other know launchers but those two that interest me and I would pay for it won't allow me to install. |
03-07-2023, 06:29 AM | #1156 |
Rep 24
Thanks for your reply, what should i check now?
03-07-2023, 07:58 AM | #1157 | |
1050
Rep 2,369
Drives: E63 645Ci
As for the FlowUX, I cannot comment on that - it's not my app. What I can comment on however is the Drive Keyboard which is mine. It has been tested with 8259L devices and it's running just fine on them. What version of Android are you running on that unit? |
03-07-2023, 08:00 AM | #1158 |
1050
Rep 2,369
Drives: E63 645Ci
03-07-2023, 10:15 AM | #1159 | ||
Rep 4
Thanks for your reply. I'm aware that the firmware is a big deal for compatibility on those devices. It was just a hope that the new firmware may be compatible since my unit uses the same ID7 skin stock. Quote:
The HU was sold as Android 11. The Android settings say it is 10. So it must be 9 then |
03-07-2023, 10:49 AM | #1160 | |
1050
Rep 2,369
Drives: E63 645Ci
What you're proposing to do will not work. If you download my app on your TV, extract the apk and try to sideload it on your headunit, the license verification will fail. |
03-07-2023, 12:49 PM | #1161 |
Rep 4
You are correct. The email was stuck in the outbox. Issues with Emclient...
Anyway. If I buy the app with my main Gmail account I should have the license for my account (in other words I use the same Google account on all devices) or is it bind to the device? How else can I download it? You already confirmed the 8259L is working with the app so it must be some Playstore bullshit then. Last edited by Mike8040; 03-07-2023 at 01:06 PM.. |
03-07-2023, 01:57 PM | #1162 | |
1050
Rep 2,369
Drives: E63 645Ci
I have just checked and there are no restrictions on any device in Google's catalogue. My only requirement is a big screen (tablet size) and API level 27 (Android 8.1) and higher. |
03-07-2023, 02:58 PM | #1163 |
Rep 4
Yeah, well than we are out of luck I guess. There is no country restriction I guess otherwise I would not see/find it in the store. The weirdest things of all of it, is the Android TV box is the oldest device with Android 8 and the other two Android devices I own that are not "compatible" are Android 10 and 13.
Does the Android DPI setting play a role for the requirement check? I switched it to 440p for the 8259 head unit. Can I not just send you the 4 bucks and you send me the app? Guess I do not get auto updates then? |
03-07-2023, 04:02 PM | #1164 | |
1050
Rep 2,369
Drives: E63 645Ci
The DPI setting does play a role, so possibly that's the issue here. If I disabled that requirement, the app will suddenly become compatible with all mobile phones, which clearly isn't, but people would still install it. The UI wasn't designed to scale to mobile phones and you cannot navigate the keyboard without the iDrvie knob. It would crash on every phone flooding my Play Console and Firebase crash reports. Some might even leave low star rating and negative feedback because of that. I have to think what to do with it. |
