12-04-2020, 10:11 PM | #1 |
Rep 30
TPMS woes -
Went to COSTCO to replace my hideous RF tires that came with my 135is. Nobody could touch their price with install and balancing. My new MICHELIN Pilot Sport All Season 4's are a huge improvement. Luv them.
BUT, instead of having them to a soft-rebuild ($3 each) on the tire sensors that came with the car (my car only has 11k miles on it), I told them to install 4 new TPMS's from DILL (Redi-Sensor 5001) at a price of $43 each. That's the brand that they carry. Unfortunately, I can't get them the new sensors to relearn. Ugh - I checked these sensors and they appear to have the same frequency as factory sensors: DILL P/N 5001 FREQUENCY 433MHz DESCRIPTION Pre-programmed for 35% of 433MHz applications, programmable for most others; includes VS-240MC And, yes. The tire pressures on all 4 tires are correct. Has anybody run into a similar situation?
If there's someone inappropriate within a hundred-mile radius, I'll end up dating her.
12-05-2020, 01:32 PM | #2 | |
55
Rep 277
Or your car can read them but is still saying it low or high? There's a procedure to reset your tpms. If you know your tires are at the correct pressure you can do the procedure to set them as correct. https://www.google.com/amp/s/erwinsa...uction-manual/ |
12-05-2020, 05:40 PM | #3 |
Rep 30
tpms woes
Thanks for the info -
I tried those instructions with my Idrive. Drove a bunch of miles over 20mph. The dash just posts that low-pressure light and doesn't identify one specific tire. arghhh -
12-06-2020, 12:50 PM | #5 |
Rep 30
2 different frequencies?
That's useful, thx
Where can I find the factory frequency specs for a 135is? Maybe they gave me the TPMS part using a frequency for a 135i or a 128i?
12-09-2020, 12:20 AM | #6 | |
Rep 30
Happy ending
SOLVED: took my car back to Costco. They said their TPMS sensors were working on all 4 tires but it's having problems communicating with the ECM. They suggested taking the car to the dealer to get it sorted out. Huh? I told them to reinstall my original sensors. The light was on but after doing the relearning procedure the dashboard light went off shortly after I left. MORAL OF THE STORY: Don't buy those sensors from DILL
12-10-2020, 10:50 PM | #7 |
Rep 3,071
Just FYI some of the after market TPMS are programmable. Last time I changed tires I decided to change them out b/c mine were 10 yrs old. I looked up what I thought was the right part number & the tire shop ordered them. When they went to install them they wouldn't work.
The tire shop had some generic programmable ones that they put on a d they worked. They can be either frequency and the shop had a tool to change them.
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
12-13-2020, 08:40 PM | #8 | |
Rep 30
tool
Thanks - That's good to know. I wonder what type of tool is used? What's it called? Aftermarket vendors should clearly state this on their packaging. It's not on the (DILL) manufacturer's website, either. Anyways, the Michelin Pilot Sport All-Season 4 tires are a GOD-send. Before, I felt like I was driving a jack-hammer. Run-flat tires are the pits.
12-14-2020, 10:47 AM | #9 | |
828
Rep 2,232
"DESCRIPTION Pre-programmed for 35% of 433MHz applications, programmable for most others; includes VS-240MC" |
12-15-2020, 04:47 PM | #10 |
Rep 474
Drives: 2009 128i 6MT
I'm in the same position, just got a set or tires installed at Costco. One of my sensors died in February and I've been dealing with "TPMS inactive" ever since. Still no luck resetting TPMS in my non-Idrive car even with the new sensors.
I had to fight with them to install the 4 new Huff sensors I bought and know are correct. They told me they only install their sensors and they didn't sell any for my car. Manager finally caved and installed my sensors, but I'm still stuck with the TPMS inactive error. Don't think it was the RDC since I first got errors couple times during a cold snap, then the issue with gauges shutting off, the trifecta of errors, etc. and a constant light after that. Gonna check the RDC and antennas this weekend. Hopefully something just got unplugged. |
12-18-2020, 10:35 PM | #11 | |
Rep 30
OEM vs DILL
12-18-2020, 10:38 PM | #12 | |
Rep 30
65% of the time they won't work off the shelf
12-21-2020, 10:13 AM | #13 |
828
Rep 2,232
That's unfortunate. Just like getting wheels properly balanced, I would say sale/installation of the TPMS should include programming, especially if they sell you the TPMS as compatible with your car.
12-25-2020, 10:28 PM | #15 |
Rep 30
year?
mine is 2013, not sure of the other members who chimed in
03-04-2021, 04:48 PM | #16 |
19
Rep 120
Recently got a similar issue with my sensors. 2013 135is non-idrive. New tires, wheels and sensors (36106874829, 433mhz, bought them off ebay) 10k miles ago.
Randomly got the tpms light pop up, went and checked the pressure (36/38). All good, light is still on. I went to do the reset procedure and it basically won't let me. Just says "inactive", nothing else. I know there should be a "reset" option but its not there. Holding down the button does nothing. Weird.. I load up Protool and try to manually start the TPMS reset. It says "This operation cannot be done". Perplexed... I thought one of the sensors were shot since I bought them off ebay, it's possible I guess. Ran over to a tire shop and had them scan all 4 and they state they are working. So .. here I am. Who's got ideas? |
