06-13-2015, 04:24 PM | #67 |
30
Rep 33
Hi all:
Just got my upgrade plugged in and loaded the DSP tool. It said the profiles were out of date and seemed to do an automatic update and all EQ settings are flat. Are the OEM and BavSound profiles available for download somewhere since everything now appears flat/reset across all settings? Thanks! Drew |
06-14-2015, 02:39 AM | #69 | |
Rep 2,013
06-15-2015, 01:41 PM | #70 |
30
Rep 33
Well, the upgrade is installed and with a quick download of the OEM profile from Patryk, I am in business.
First impressions: much more detail and extended "punch" in the lows and the highs, even with OEM speakers. The sound stage is A LOT better. I plan to spend some time tweaking and tuning over the next week or two but from an immediate impact perspective, this upgrade does not dissapoint! Now I'm going to need to convince myself that I don't need better speakers before I get a chance to truly dial-in the sound profiles! I also took some pictures that I will post later in the hopes that it can help other 2015 F30 owners install. There are a few tricks that might have helped me save at least one of the fasteners in the trunk. Drew |
06-16-2015, 10:29 AM | #71 |
Info-Maniac
Rep 55
How is the USB cable intended to be "routed" to the front seat? It this simply running through one of the back seat openings across the center console and coiled back into the trunk when finished?
MW 328i Sport/Premium, Cold Weather & Tech Pkgs/Sport Auto. Trans/Variable Sport Steering/Xenons/Park Distance Control/M Performance Black Kidney Grills & Gloss Black Whiskers/Black Gloss roof Wrap/Dinan Exhaust/aFe Intake/JB4 w/ Bluetooth
06-16-2015, 11:02 AM | #72 |
Rep 832
06-17-2015, 07:34 AM | #74 |
tends to get irritable
202
Rep 798
If it is .afp, then yes. .afpx would be for 3.11
AC Schnitzer/Eibach/M Performance/RaceChip/Compustar/Drone/BimmerTech/FireTV/Helix/Dynaudio/Micro-Precision/Jehnert/Audiomobile |
06-17-2015, 12:55 PM | #75 |
30
Rep 33
Version 3.11 will open the .afp file just fine so long as during the Load dialog window you choose the that as the file filter extension in the bottom right.
That said: does anybody know if 3.11c (being a Beta) correctly imports and applies .AFP files? I had a couple of glitches where all channels were muted after application but not sure if that's just a bug in 3.11c or whether there's something of more concern going on? Which version of the tool is recommended at this point? Drew |
06-17-2015, 01:37 PM | #76 | |
Rep 3,834
Daily: G12 750 MSPORT Weekend Car: E90 M3
06-17-2015, 11:53 PM | #77 |
30
Rep 33
After hearing the muting of the channels affected you to, got to testing tonight. I downloaded and installed V2.93 of the software which ONLY loads .afp files and I was very surprised at what happened when I loaded that profile with it's native software: My volume increased by at least 20% and the EQs applied to all speakers truly kicked in!
I then stored the preset in Slot 1 of the DSP, closed V2.93 and opened V3.11c. First thing V3.11c tells me is that the profile is too old and needs to be updated. I agree to let it update and the unit appears to do some sort of firmware update because the amp does a full reboot (you can hear it power down and back up). Upon doing so, everything is flat, so I load the same .afp file I used in V2.93 and while the definition and sound stage got better, the volume remained low or perhaps even reduced. I closed V3.11c, opened V2.93 and it tells me the profile is too old (the same file I *just* loaded in V3.11c and need to update. I agree to let it do so, the amp powers down and back up and is set flat again. I then load the exact same .afp as the first one and excellent audio returned along with the power/volume! So for now, either the firmware included in V3.11c of the software has an issue or the .afp file load of the DSP tool has a bug or both. If you have one of these units and it just doesn't sound right after using V3.11c, I highly recommend loading V2.93 and loading the profile back up. Since this is a BimmerTech product, I'm not exactly sure how to get this feedback to the original manufacturer for the next rev of the DSP firmware or DSP tool. If anybody knows, please advise! Drew |
06-18-2015, 12:23 AM | #78 | |
202
Rep 798
06-18-2015, 12:24 AM | #79 | |
202
Rep 798
They are already aware.
06-18-2015, 12:30 AM | #80 |
30
Rep 33
Thanks!
Did you build your own profile or did you get the profile from Bimmertech in .afpx format? Mine came as .afp which I now know only works with V2.93! If you built your own, which IO routing did you use to get your volume back? |
06-18-2015, 12:38 AM | #81 |
30
Rep 33
I should add that I started with a freshly reset profile (Reset All, cleared routing) on V3.11c and manually added back the routings. Please see attached screenshot.
06-18-2015, 12:45 AM | #82 | |
202
Rep 798
If you would like to send me your file, then I can covert it over for you. Although it is also quite simple to do yourself, just open 2.93 and 3.11 at the same time and copy over. The biggest difference would be the IO as 2.93 did not allow as much on the input side and quite substantially different on the outbound side.
06-18-2015, 12:46 AM | #83 |
202
Rep 798
Sorry, I don't know what the original is supposed to be, so to comment prematurely wouldn't be wise !
06-18-2015, 02:52 AM | #84 | |
Rep 2,013
We understand everyone wants to use the latest version but we will stick to the official final releases and therefore will keep AFP files and 2.93 software as recommended until the new final version is released. All of you who want to use the latest beta software we will have AFPX files for you ready soon but we will provide them only if requested. We can't guarantee everything will work properly with beta software. I hope you guys understand. AFP and APFX files have different structure so if you are opening an AFP file in the 3.10/3.11 beta software you have to carefully check all settings/adjustments with the 2.93 software to make sure they are the same. The import of AFP files in the latest beta versions might not work properly. Please use 2.93 and AFP files with BimmerTech Premium Audio System until the new final release of the software is available. |
06-18-2015, 10:22 AM | #85 | |
30
Rep 33
Thanks for the clarification! It's very clear to me after further testing this morning that 2.93 and 3.11 are very different. I even attempted to manually setup a 3.11c file from clean and can't get the same results as 2.93. I am very happy staying on 2.93 and .afp files until a final build and .afpx file are available.
I'm not sure if I missed this guidance in the manual or in the box? If so then I'm guilty of RTFM. That said, I noted the OP on this thread had downloaded 3.11c so assumed that was the right version to use. I think that making this more well known somehow via website, release notes or a note when you open the box would be helpful so that initial impressions with the unit are *much* better! I guess the upside is that I am no longer considering upgraded speakers because I essentially have a whole brand new unit to play with for a few weeks! Quote:
06-18-2015, 11:20 AM | #86 |
47
Rep 66
Thanks you all for the clarifications.
2.93 is more stable than 3.11c. Hope Bimmer-tech can notify us when the official 3.xx version become available, because the 3.11c EQ fine tuning features and the multiple graphs display is awesome during speakers setup. Cheers |
06-18-2015, 11:46 AM | #87 | |
202
Rep 798
06-20-2015, 08:05 PM | #88 |
@obriennathaniel_f30 on Instagram
515
Rep 1,062
Drives: 582whp/596wtq '13 335i
i bought this amp just because of this article lol. Now my BVS1 and SWS underseat subs will sound amazingggggg
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
schmedley0.00 |
audiotec fischer, bimmertech premium sound system, bmw amp upgrade, bmw hifi |
