BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Do I need to code the TRSVC Module (Reverse camera)
ARMA SPEED
      06-01-2019, 09:02 AM   #1
F30RiK
Drives: 13' 335 xdrive M-sport 6 Speed
My Reverse camera module wasn't working properly, It made other module crashes and stopped communicating (CON IHKA) and the reverse camera wasn't always working.
I bought one on Ebay, same part number (Hardware and software) but my previous one had been updated by BMW dealer to 2014 software (instead of 2013).
Long story short, I installed the one from Ebay (Came from a 5 series) and it's not communicating (Red in ISTA).
Do I need to code it?
      06-01-2019, 10:43 AM   #2
atzebmw
Germany
590
Drives: Tesla Model 3
Yes, it has to be coded.
      06-01-2019, 11:56 AM   #3
F30RiK
Thanks!
Can someone help me with the step to code it?
I can paypal a donation if needed
      06-01-2019, 12:02 PM   #4
atzebmw
Germany
590
Do you have E-Sys?
Then you only have to mark the TRSVC, assign a new CAFD and after that code the TRSVC.
      06-01-2019, 12:11 PM   #5
F30RiK
I have E-sys but I never used it. I'll try this afternoon. Thanks!!
      06-01-2019, 01:14 PM   #6
F30RiK
Ok so I followed the step by step for esys. I'm connected and I was able to read the ECU's. I have 19 ecu but the trsvc doesn't show in there.
      06-01-2019, 01:22 PM   #7
F30RiK
I should have 20 ECU's showing up. It look like the trsvc is dead ?
      06-01-2019, 01:46 PM   #8
atzebmw
Germany
590
But you wrote that you can see it in ISTA in red.
So it can't be dead.
In E-Sys did you try both buttons Read SVT and Read Ecu?
Can you again check the error memory with ISTA?
We have to know the error message.
      06-01-2019, 01:50 PM   #9
F30RiK
It's in red (no communication possible). Fault in ista is ; no communication with control unit possible.
I only tried read ecu, ill try read SVT right now
Thanks for your help!!
      06-01-2019, 01:52 PM   #10
F30RiK
Ohhh, thank you!!! Read SVT did the trick lol
      06-01-2019, 01:54 PM   #11
F30RiK
If you can help me a bit more lol, how can I assign a new cafd?
      06-01-2019, 01:59 PM   #12
F30RiK
Ok, I'm not able to "read coding data", it will give me an error.
      06-01-2019, 02:11 PM   #13
atzebmw
Germany
590
That's normal because the CAFD was not yet assigned.
To assign a CAFD mark the ecu TRSVC and on the right side "detect caf for swe".
      06-01-2019, 02:21 PM   #14
F30RiK
Ok so I think I made a big mistake lol.
I clicked code when CAFD was highlighted (in the trsvc module) and a screen popped up with a bunch of text in German . At the end it was written something like "cant find cafd file).
Now the trsvc module won't appear even when I click "read SVT".
      06-01-2019, 02:27 PM   #15
atzebmw
Germany
590
No, that was no mistake.
That's the right way to assign a new CAFD.
Did you see this window?
      06-01-2019, 02:32 PM   #16
F30RiK
No because I clicked "code" before clicking on "detect caf"
I just realised that TRSVC was supposed to be highlighted, but when I clicked "code" CAFD was highlighted instead.
Now the trsvc doesn't appear at all even when I click read SVT.
Like if it was erased from the list. I'll take a picture
      06-01-2019, 02:39 PM   #17
atzebmw
Germany
590
Ah OK, i understand.
But i think that's no problem.
Maybe you can try again to connect the car or you shut off the ignition and turn it on again.
      06-01-2019, 02:57 PM   #18
F30RiK
I tried letting the car go in sleep mode and also rebooting the computer. Its still doesn't show up in the SVT.
It's like if I deleted the trsvc module from the SVT
      06-01-2019, 03:03 PM   #19
F30RiK
I saved the SVT file (should of did that at the beginning lol) and all 19 ECU's are there but the trsvc is not in there
      06-01-2019, 03:04 PM   #20
atzebmw
Germany
590
OK, try the following.
Mark the ecu "SM" in your SVT list and then hit the button "Code".
After that try again to Read SVT or Read Ecu.
      06-01-2019, 03:48 PM   #21
F30RiK
Ok I did and it was completed with no errors, but trsvc still doesn't show up.
      06-01-2019, 03:56 PM   #22
F30RiK
Trsvc module doesn't appear anymore in ista
