MULF2-High pinouts
02-28-2010, 06:33 PM | #1 |
Rep 935
MULF2-High pinouts
Hi,
Does anyone have the pinout for the Harman/Becker Automotive MULF2-High which come with option 6FL? I recalled there was a thread that had a link to a site which the MULF2 was approved and certified by some government agency and the pinouts were there...I think. Thanks, Jim |
03-07-2010, 03:40 PM | #3 |
Rep 5,984
Did you have any joy with this??
I retrofitted the USB today and the phone appeared in my menu too, so I want to add a mic and the bluetooth antenna, but not sure what the pins for the mic are. |
03-07-2010, 11:55 PM | #7 |
Rep 935
03-07-2010, 11:57 PM | #9 |
Rep 935
03-08-2010, 03:28 AM | #10 |
Rep 5,984
The cable for the antenna??
I have ordered this part...84320138217 It is a Fakra to Fakra coax that is about 5" long, I will mount the antenna in the boot. |
03-08-2010, 02:09 PM | #13 | |
Rep 935
Thanks! |
03-08-2010, 02:18 PM | #14 |
Rep 5,984
If you have the USB option 6FL, you already have bluetooth, all you need to do is tell the radio you have it and then add a mic and an antenna, bother of which are $50.
Running the harness if pretty easy, just have to be careful if you are in a car without MOST already in there as you are laying optical cables and they can break. |
03-08-2010, 03:02 PM | #15 |
Rep 13,012
03-08-2010, 03:23 PM | #16 |
Rep 5,984
The full retrofit comes with an extra cable, this is a cable that has MOST and Power.
The part listed above is now discontinued, probably because BMW have realised that people can order 6FL and then buy the parts to retrofit bluetooth for £120 instead of £575 they charge when ordering new. You can still get the whole kit for £250, this included the bracket, MOST cable etc. etc. You can then buy the single bits for the 6FL, so that is the better way to do it price wise. |
03-08-2010, 03:27 PM | #17 |
Rep 6
I retro-fitted the Bluetooth telephone function to my 2008 E92 Sport. The car was supplied with Professional radio, L7 & USB (6FL) as standard. As the ULF-SBX-High acts as both audio (via USB) & Bluetooth it was remarkable easy to complete and now I enjoy the full benefit of Bluetooth as SA644 with voice activation.
I purchased the following parts from the SA644 retrofit kit 84640398228 from my local BMW dealer. 1. Retrofit wiring harness 61120403137 2. Microphone 84316938762 3. Bluetooth Antenna 84506928461. All parts came to £160.00 As the ULF-SBX-High was already connected to the MOST fibre optic circuit I did not need to alter any STD settings. I simply located the wiring harness as per the retrofit instructions, connecting in both the microphone in the original location of the interior light housing (FSD) and Bluetooth antenna next to the driver footwell. This wiring loom came with a WHITE 54 pin block that does not directly fit the ULF-SBX-High unit which has a blue connecter block. I just needed to take the wiring pins out and relocating in the correct location of the original BLUE 54 pin block. I had the car re-coded by my local BMW specialist with the Auto logic system; they had to code 4 items in the car to get the Bluetooth switched on. Then it all worked. Auto logic cost just £35 So all in all, done for less than £ 200.00 I will add the eject box at a later stage when I decide to upgrade my phone, currently Sony Ericsson C902 which works really well & add a Antenna which sticks to inside of rear screen. Cheers, |
03-08-2010, 03:29 PM | #18 | |
Rep 13,012
03-08-2010, 03:35 PM | #20 | |
Rep 13,012
Therefore, if there's any other way of getting the proper OEM connectors for the mic and the BT antenna, any custom wiring could be done without buying the OEM harness... |
03-08-2010, 03:58 PM | #21 |
Rep 935
Yeah, I think the only custom wiring that is truly needed would be for the MIC. A two wire run from the FZD to the MULF and the correct ends. The antenna can stay in the boot I guess with a short antenna cable but I wonder if that would be optimal or good enough to cover the signal area without issues.
03-08-2010, 04:00 PM | #22 | |
Rep 935
