02-24-2024, 03:07 PM | #1 |
Rep 6
Detonation / knock?
Hello,
Apologies in advance if this is posted in the wrong section. I've been dealing with what appears to be a detonation or knock issue. I'm experiencing a loss of power, acceleration, and increased induction noise. I've also noticed odd behavior from the DCT, as it seems to rush into 7th gear as quickly as possible in any auto shift setting, causing the car to perform poorly when driving around town. Initially, I thought to service the DCT first, but all transmission symptoms cease when the car is running well. There are no diagnostic codes, and the car is completely stock. On the rare occasions it runs well, I can immediately tell by how little throttle input is needed just to get out of my driveway. After consulting threads with similar symptoms, I've replaced the spark plugs, fuel breather valve, primary O2 sensors, fuel injectors, and the low-pressure fuel sensor behind the plenum. Unfortunately, none of these fixes have resulted in a long-term improvement. Most recently, the car seemed to run well for about 100 miles after replacing the fuel sensor, but then it returned to its sluggish state. I've tried fuel from multiple stations and brands to rule out the possibility of bad gas. It's worth mentioning that I live in California, where only 91 octane is available. I'm reluctant to start another thread on a somewhat known issue, but I haven't seen many of these cases fully resolved. I don't consider myself someone who gives up easily, but this issue is beginning to frustrate me to the point of considering selling the car. I have a BW forward X pipe and Epic tune waiting to be installed, but I really want to resolve this issue before adding any modifications. Any suggestions or insights are greatly appreciated. I've exhausted all related threads and am finally reaching out for help! |
02-24-2024, 06:15 PM | #2 |
Rep 4,180
Error codes will help.
RocketyMan232.00 |
02-24-2024, 06:57 PM | #5 |
Rep 1,130
Drives: 2009 E92 M3 Dakar Yellow II
Smoke test your car.
02-26-2024, 05:15 AM | #8 |
mTekMods
2164
Rep 2,915
did you do a leakdown test or a compression test to rule out a broken valve spring?
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
02-27-2024, 09:15 AM | #9 |
Rep 6
