BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > E-Sys now free again!
Studio RSR
      04-11-2018, 05:11 AM   #23
teaston
10995
Drives: X3 M40d
Originally Posted by JVX View Post
What are the differences between coding with BimmerCode and Esys?
Is there more available on esys?
Yes with esys you can code everything available on the car whereas in bimmercode you're restricted to what they've included in the app
Plus esys can read/clear fault codes, check i-level, register new batteries etc,
Cheers - makes sense.
I presume esys is harder to use for a newbie than bimmercode?
It's pretty straightforward if you use the step-by-step guides that come with it
LobB5109.00
      08-09-2018, 05:59 PM   #24
matteis
9
Drives: bmw 118i f20 sport gp
Originally Posted by DonDP View Post
has anyone tried E-Sys Launcher Premium 2.8.0?
It fails to launch on my system. I get a system message 'E-Sys Launcher Premium has stopped working'
I have the same problem. Does anyone know what in my system could be preventing the launcher to open? It is a windows 7 x64 (just reinstalled/formatted) with framework 4.7
      08-16-2018, 07:47 AM   #25
marcuslee2032
Drives: F10 535d
+1 on the same issue (albeit Win7 32bit). If anyone knows??
      08-16-2018, 08:08 AM   #26
marcuslee2032
Drives: F10 535d
Actually fixed the issue, as per Shawn's advice, though I couldn't get .net 3.5 to install, the rest did, and it Launcher seems to go now
https://www.bimmerfest.com/forums/sh...&postcount=603
      09-07-2018, 12:47 PM   #27
matteis
9
I tried the solution above, but I still have the problem. Would you send me the links that you used to download the programs?
      09-07-2018, 01:18 PM   #28
teaston
10995
Drives: X3 M40d
https://www.bimmerfest.com/forums/sh...;postcount=603
You really should consider BimmerCode, so much quicker and easier!
LobB5109.00
      09-07-2018, 01:46 PM   #29
matteis
9
Tks, but I am trying to help a guy coding for him remotely. Bimmercode is not helpful in this situation.
      09-08-2018, 11:00 AM   #30
matteis
9
I did a simple upgrade to win 10 and it has fixed the issue.
      09-08-2018, 01:10 PM   #31
teaston
10995
Drives: X3 M40d
Oh I didn’t realise you were running a retro windows version!
LobB5109.00
      09-15-2018, 09:35 AM   #32
Ashdown
Drives: F30 328i
Hi everyone, specially Shawn whose name I have seen everywhere I have been on bimmerpost.
I am fairly new to ESYS and am currently coding adaptive headlight driver modules both sides. I have made some progress but frankly failed to get it working. This F30 RHD 2014 came with adaptive from factory. Needed replacement headlights and driver modules.
Starting off the first issue I ran into was getting the CAFD (cafd_00000794_017_068_102) file under FEM, it was non existant. So did a detect CAF and generated the cafd (which was slightly different the last number is 101 instead of 102).
Now when I edit FDL under FEM I don't get the name of the MODULES in the daten list. And search result is nil. So havent been able to code the headlight driver modules on this f30.
Any help would be greatly appreciated.
      09-17-2018, 05:57 AM   #33
Sasquartch
Drives: 520i G30
I can't help specifically with this but have you checked you have the latest psdzdata files ?
Shawn will provide a link if you need one and I've always found him extremely helpful as long as you've made an effort to eliminate anything silly and provide him with all pertinent information
LobB5109.00
      09-17-2018, 10:14 AM   #34
Ashdown
Drives: F30 328i
I have been able to sort that problem out as well. I think I needed the Token master premium launcher.
Unfortunately couldn't get to the bottom of my problem with the TMS driver modules. I have coding error fault code even though I VO coded out 524 and coded it back in. As soon as I do that the fault codes reappear. So I have for now totally removed the adaptive headlights option from the car. Don't see the adaptive headlights failure light anymore. I am not sure though if the lights will be working fine as they are originally adaptives. Everything turns on.
      11-03-2018, 12:05 AM   #35
492600621
Drives: BMW F30 LCI
Edit FA ,Add to 5A2 and back to code.And then select FEM to coding.
but frist,you want to read to the ECU, and then the ECU list appears ELE TMS or FLE TMS.
Select ELE, and then detect CAF for swe.
then finsing job.
good luck.
      01-03-2019, 03:22 PM   #36
deneyer
Belgium
35
Drives: BMW
premium launcher 2.8.2 isn't working anymore, anyone knows if there is a updated working version yet?
      01-03-2019, 03:28 PM   #37
teaston
10995
Drives: X3 M40d
Best to ask shawnsheridan
LobB5109.00
      01-03-2019, 06:06 PM   #38
ian332isport
ian332isport's Avatar
705
Drives: F31 340i Shadow Edition
Are you running Win10 ?
E-Sys is not happy with the current full release.
      01-04-2019, 02:39 AM   #39
deneyer
Belgium
35
Drives: BMW
Yes but i had no problem in 2018 since 2019 it stopped so i think the license by tokenmaster is dispierd. And i dont want to work with a vm
      01-04-2019, 02:13 PM   #40
ian332isport
705
Which build of Win10 are you running ?
It's Win 10 1809 Build 17763.134 (the latest current build) that is known to have issues. I had to update to one of the later insider builds (18290) to get E-Sys working again.
LobB5109.00
      01-05-2019, 06:08 AM   #41
ian332isport
705
Just to update this, it does look like Tokenmaster put an expiry date (31/12/2018) in the free token file.
Just tested on my diagnostic laptop, and had the same issue. After reading this:
https://f30.bimmerpost.com/forums/sh....php?t=1457494
I changed the system date to 16/06/2018, ran the .BAT file, and everything is working again.
      01-05-2019, 06:15 AM   #42
E60525d
E60525d's Avatar
281
Drives: 330d M Sport LCI
Do you have to run this application everytime you launch esys?
      01-05-2019, 08:45 AM   #43
ian332isport
705
It appears that you do. Launcher fires up just fine, but it doesn't then launch E-Sys. Not on my laptop anyhow.
Running the .BAT file appears to reset Launcher so it generates a new token each time.
      01-05-2019, 06:01 PM   #44
dy63
162
Drives: F30
anytime i change my system date and try to launch esys launcher it doesnt ever load up. when i reset my system date to today it loads up and asks for a pin?
ive changed my date to 15.06.2018
successfully ran the BAT file as admin
tried to launch esys launcher but it still doesnt open?
any ideas?
