BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > F30 NBT Navigation greyed out
ARMA SPEED
      06-01-2018, 10:35 AM   #1
manitaci
Netherlands
17
Drives: BMW 320d 2013
Hello guys, need help for next issue.
My friend installed a new NBT Navi Pro unit. Donor VIN is available.
But the Navigation is greyed out in the menu. Also NAV button not working.
I have found a simular thread, but no solution is posted:
http://g30.bimmerpost.com/forums/sho...php?p=22521119
I have E-sys
(the original Navi NBT Unit is stolen, including airbag.)
thanks!
      06-01-2018, 12:00 PM   #2
Dfahmy
Egypt
140
Drives: F30 335i PWG
2013 BMW 335i  [0.00]
I have E-sys
thanks!
It's greyed out because it needs an FSC code that matches your VIN to activate it, which you could get on eBay or BMW ag(super expensive). Another option would be to run an emulator which I would only recommend if you are not able to get the FSC codes
2013 335i BSM ~ Stage 3 turbo, forged internals and more check out my build thread https://f30.bimmerpost.com/forums/sh...7#post23789807
      06-01-2018, 01:25 PM   #3
manitaci
Netherlands
17
I am able to get FSC (FSC extented > StoreFSC > decode).
But how am I supposed to get the NBT navigation working? How to activate it?
      06-01-2018, 10:02 PM   #4
Dfahmy
Egypt
140
Since you replaced the headunit the FSC code on the head unit is linked to the donor vin not your vin. So you need to code the new headunit to your vin and then a new FSC code linked to your vin
      06-02-2018, 09:46 AM   #5
steve@codemybimmer
steve@codemybimmer's Avatar
Hong Kong
671
Drives: 2020 G20 320i M Sport
You need to get the repair FSC kit for your VIN ordered from BMW and swap the codes over so that Navigation, Voice Control and all other applications can work again. These are anti-theft codes that prevent head units from being installed to other vehicles.
I sent you PM.
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming
steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca
Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs
      06-05-2018, 03:02 AM   #6
manitaci
Netherlands
17
when things get complicated, just ask steve@codemybimmer
Thanks for the great job.
add: I installed esys on my XPS 9360, things go faster now
      11-04-2018, 10:00 AM   #7
kriya
Drives: e60
Need FSC repair kit.
Hi Steve: My car stop navigation and sat radio and voice control. I have a donor nbt evo head unit. Would I need repair fsc kit as well? It appears to be anti theft codes are preventing it to work? Appreciate your help. Thanks
      11-04-2018, 10:10 AM   #8
FunkyProtein
Drives: BMW 3 series 2008 220D
Hi guys.
I just bought a 3 series 2008 with a cic idrive and have the same problem as OP. Sat nav is greyed out. The guy who sold me the car said I just need an update for the maps. Is this correct? Am I able download the maps and simply install?
Any advice is greatly appreciated. I'm pulling my hair out with this.
Thanks
Steve
      11-04-2018, 10:15 AM   #9
FunkyProtein
As my sat nav won't load at all. I'm wondering if the unit itself or hard drive is on the way out? I'm hoping it's just an update that's needed 😐
      11-05-2018, 10:34 AM   #10
steve@codemybimmer
Hong Kong
671
Are you using this on your E60 or on an F chassis car?
      03-12-2019, 02:31 PM   #11
bud2011
Drives: 2013 BMW 328i Xdrive
I have the same issue as OP.
My navigation is greyed out and satellite radio is not greyed out but it has an empty list when I click on it (not even the siriusxm preview channels). The ESN number on the satellite radio is empty as well. Please I'll appreciate any help in advance.
SN: My head unit was replaced just before I got the car - F30.
      03-13-2019, 08:58 AM   #12
steve@codemybimmer
Hong Kong
671
It sounds like your head unit was not replaced properly as it is currently not activated to your VIN. If you need this fixed, feel free to send a PM.
      03-16-2019, 07:18 PM   #13
shlounek
Drives: 2014 520d
I sent you PM.
I think I might have the same problem, just purchased 2013 BMW 520d checked car VO online and its comes with Navigation from factory. Its a RHD UK car.
But the Navigation option is greyed out? What do I need to do to get it back working?
Last digits of Vin is D600713
      03-18-2019, 12:10 PM   #14
bud2011
Hi steve@codemybimmer ,
sorry I'm new to this thread I can't figure out how to start a PM. You can PM me and we can go from there. I will like my new head unit to be activated for my VIN so I can get navigation, satellite radio and voice command back.
Thanks in advance.
      03-23-2019, 09:52 PM   #15
p1p2p3p4
Drives: f31, f82,
Red face FSC Question
I sent you PM.
Hi Steve I have a question, I replaced the head unit on my 2014 f30. because mine was bad and kept rebooting every 3 minutes.(I still have it). the used replacement from a different car works great but now navi is grayed out on the screen. Was wondering is there any way to export the FSC from the old one and import it to the new one?
Thanks in advance.
      03-24-2019, 10:17 AM   #16
steve@codemybimmer
Hong Kong
671
Thanks in advance.
It's possible but very cumbersome as you would need to store and save the certificate file and FSC file every application. Also if the creation date for the existing files on your replacement NBT are newer than the files you have on your old unit, they would not be accepted on the new unit.
If you need help with reactivating your NBT, feel free to PM.
      03-24-2019, 11:45 AM   #17
steve@codemybimmer
Hong Kong
671
Do you happen to have the last 7 digits of the VIN from the donor unit? Let me know via PM and we can see what can be done.
      03-24-2019, 11:48 AM   #18
shlounek
Drives: 2014 520d
I am not sure of the vin of the donor vehicle since I bought the vehicle with the unit already installed, is there a way I can pull this info from the NBT.
      06-18-2019, 10:06 PM   #19
STONEY_M5
MAAD HEAD
STONEY_M5's Avatar
62
Drives: 2010 X5M 2013 M5
13 F10 M5  [0.00]
2010 X5M  [0.00]
07 335i  [9.26]
I’m having the same issue on a 2013 f10 I have the vin of my vehicle and donor vehicle. Any help would be greatly appreciated.
      06-19-2019, 01:47 PM   #20
steve@codemybimmer
Hong Kong
671
Sent you a PM.
      07-20-2019, 05:41 AM   #21
jopecasa
Drives: BMW E53 X5
Steve,
same here having issues.
kindly pm me please....just joined in today.
      07-21-2019, 08:09 AM   #22
justa3bmw
21
Drives: bmw
We can help you get your navigation activated with all FSC features via USB. Just send us a message.
