BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > CANADA > brake fluid leak when i change brake pad
proTUNING Freaks
      04-06-2024, 11:41 PM   #1
tylertyler
Drives: BMW 2014 320i
Hello,
I changed the front brake pads of my f30 320i. I noticed some brake fluid leak under my car on driver's side.
I did not remove/open this Brake fluid container at any time and I figured that when I used a clamp to push the calliper pistons in, that pressure must have pushed the brake fluid out of the brake fluid container.
I tried to drive a couple of miles, seems the brake is working fine but feels softer than before.
I am worried that the pressure of pushing the callipers broke some seals/hoses. any thoughts, please?
thanks
      04-07-2024, 11:29 AM   #2
Djphonics
45
Drives: MK7 GSW - E91 - 5th gen VFR
I would suggest doing an inspection of the seals on the calipers. Last thing you want is brake fluid dripping on your rotor whilst loosing pressure in the system.
      04-07-2024, 11:50 AM   #3
tylertyler
i see, thanks!
      04-07-2024, 11:51 AM   #4
Shirazkhan
38
Drives: bmw
If the brake fluid came from the reservoir then that was when you pushed the piston back and thats normal.
      04-07-2024, 12:28 PM   #5
tylertyler
ok, so it that how brake fluid reservoir design like this, to leak overfilled fluid? i do see there were leak around reservoir, it seems like from seal of reservoir. but no more new leak found, and car brake is working fine. thanks again
      04-07-2024, 02:36 PM   #6
Shirazkhan
38
Drives: bmw
Yeah just throw water around that area were the brake fluid leaked.Or it might remove the paint from the brake booster.
      04-07-2024, 02:39 PM   #7
Shirazkhan
38
Drives: bmw
Its not from the seal of the reservoir,if it is then its not normal.It came out the top where the cap fits,which is fine.You can always mark and note the level of the fluid.
      04-07-2024, 04:08 PM   #8
tylertyler
got it, thank you!
      05-01-2024, 01:39 PM   #9
casualDIYer
Drives: 340i xDrive M Sport
Definitely follow this guy's advice. Brake fluid will dissolve paint. Clean up spills with water ASAP.
340i xDrive (F30), 228i (F22), 320 (F30), 325i (E46)
      05-01-2024, 02:04 PM   #10
casualDIYer
The reservoir is pretty much the flimsiest part of the brake system as you can take the cap off with just a turn. Any other place in the brake system, including the calipers, lines, ABS pump, or master cylinder, is significantly more difficult as you need tools. You can replace the reservoir cap if the seal is faulty. That would be part 34336851090 - BMW Brake Fluid Reservoir Tank Cover Filler Cap. Inside the cap is a gasket that, like all gaskets, wears over time. The big surprise here is the price. It's $13, from the dealer.
If you can operate a pop bottle, you're qualified for this repair.
