10-03-2014, 08:27 AM | #23 | |||
Bored all the time
382
Rep 2,173
Couple of questions about the ones below... I did most of the ones you did, plus some others.
Which one here is the mirror folding? I don't like that when I lock the car, mirrors fold in automatically... in e92 m3, I had to hold the lock button longer for it to do it. I like that better. Quote:
Couple of other coding things that made no sense... This one for instance... Mine was already OFF... yet the lights are still on. The little orange led next to the turn signal in the headlight. Turn off Amber Side Markers next to Headlight: 3063 MAPPING_SIDEMARKER_L_OUTPUT = OFF 3063 MAPPING_SIDEMARKER_R_OUTPUT = OFF This one, I would like to disable completely... I don't like it tilting... but I don't see the code for it... any help: Tilt Passenger Mirror farther down when in reverse 3110ASP_BORDSTEINAUTOMATIK_DELTA set to: werte=4B In my idrive... I have a menu called Mini active sounds... I think it came on after I coded this.. but I can't do shit with them. can't select or anything Is that what this does? Enable Active Sound Design Configuration Menu 3000 ASD_CONFIGURATION set to: aktiv 3000 ASD_SOUND_4 set to: aktiv Thanks for your help.
Current: 2014 991 Turbo RS
Past: 15 GT3, 17 R8 SC, Two 16 M4 GTS’s, Two 18 GT350R's, Two 13 RS5’s, 13 M3, 10 R8, 15 M4, 09 M3, 04 M3, 09 S5, 02 M3... It all started with an RX-7 (FD). |
10-03-2014, 09:03 AM | #24 | ||
54
Rep 121
Drives: 2015 M3
These three control the side mirrors:
3110 → ASP_BEIKLAPPEN = aktiv (werte=01) 3110 → ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN = (werte=01) 3110 → ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN = (werte=01) Quote:
http://f80.bimmerpost.com/forums/sho...59&postcount=6 http://f80.bimmerpost.com/forums/sho...4&postcount=14 Quote:
Can't help you on the other stuff. |
10-03-2014, 09:11 AM | #25 | |
Bored all the time
382
Rep 2,173
Is the stuff above for when you hold the lock button or just when you lock. Right now (I think) when I hold the button, the windows roll up, which is good. IF I only lock the car, the mirrors fold. That I don't like. It wasn't that clear in the coding options. Have you managed to disable your amber little corner light?
10-03-2014, 09:13 AM | #26 | |
Bored all the time
382
Rep 2,173
Was I supposed to do something else after coding 6NS?
10-03-2014, 09:16 AM | #27 | |
54
Rep 121
Drives: 2015 M3
10-03-2014, 11:47 AM | #28 |
24k GOLD
148
Rep 1,453
I just had my f15 x5 coded. You can set the how fast you want the mirrors to close after lock. I set it to 1sec delay. You can set it to additional 3-5 second hold on the comfort access for the mirrors to close.
I also would like the three little led coded off on headlight. My friend couldnt crack that one. |
10-03-2014, 01:53 PM | #29 |
1st Sergeant
9
Rep 100
10-03-2014, 04:38 PM | #30 | |
Rep 66
10-04-2014, 03:47 AM | #31 | |
471
Rep 2,991
10-04-2014, 04:08 AM | #32 |
General
10447
Rep 40,805
KOMFORT_SCHLIESSEN = Werte=00
10-04-2014, 10:12 AM | #33 |
Bored all the time
382
Rep 2,173
i got this taken care of. The AC memory thing didn't work for me... it made AC go nuts and i couldn't turn it off... Also the 3 little led's in the headlight... i can't disable those... i tried bunch of things and nothing worked.
10-04-2014, 10:34 AM | #34 | |
Rep 1,656
10-11-2014, 08:15 PM | #35 |
Rep 480
Thanks very much for the report, very helpful.
Did you notice any suspicious looking entries that might resemble Euro MDM (disabling US MDM)? I presume it must be the same setting as on F1x chassis (M5, M6), but actually no coding sheets on F1x forums note this. There are just a couple of local or remote coders that claim that can do it. So... challenge accepted for a DIY. My car is still on a ship so I can't plug in to OBD port and investigate, but was wondering if you found it. |
10-13-2014, 03:31 PM | #36 |
Rep 1,338
10-14-2014, 06:35 AM | #37 |
54
Rep 121
Drives: 2015 M3
Updates
Updated first post with some new codes and commented on a few others that I have since changed back to default.
10-15-2014, 07:47 AM | #38 |
54
Rep 121
Drives: 2015 M3
I turned 6NS on a forum member's car that didn't have it. In HU_NBT there is a setting to show office on the menu. Don't remember exactly which setting it was but if you search for office in HU_NBT you will find it.
10-15-2014, 08:00 AM | #39 |
General
10447
Rep 40,805
HU_NBT => MACRO_PIM = aktiv
10-15-2014, 08:12 AM | #40 |
54
Rep 121
Drives: 2015 M3
That's the one -- thanks, Shawn. "Office" is in the comments field for that code.
Pressing and holding the speech button on the steering wheel to talk directly to Siri or Google has become my favorite way to read and reply to texts & emails, however. |
10-15-2014, 09:57 PM | #41 |
ID10T Specialist
90
Rep 269
Drives: F90 | F97
Garage List 2019 BMW M5 (f90) b ... [9.92]
2021 (F97) BMW X3mc [10.00] 2017 Toyota Land Cr ... [9.50] 2000 Toyota Land Cr ... [0.00] |
Lap Timer requires a connected phone to function.
10-15-2014, 10:08 PM | #42 | |
Rep 1,450
It's a must do if you have the top cams. The handle lights illuminate things well at night. |
10-22-2014, 09:40 PM | #44 |
General
10447
Rep 40,805
