09-04-2015, 05:08 PM | #23 |
Rep 1,282
Sounds verrrry promising. I'm also a weenie, so I'll wait until there's more history on this. If it pans out, I'm definitely doing this!
M850i Vert with RaceChip
E46 M3, Euro Headers, Rasp Pipe, Kassel Tune Alpina B8, zero performance mods |
09-10-2015, 10:30 AM | #26 |
Christmas Poo
1029
Rep 1,180
This is either a dud, or noone wants to do it. 1 Month in I would have absolutely programmed this, Just as easy to hit my M1 button to put it in sport plus which is my standard daily driving mode anyhow. I don't find it jerky at all and my muscle memory is completely in tune with it.
If someone is brave enough to try this I'd still make sure the car is in neutral and test start without pushing the clutch in to make sure it really doesn't start up with the clutch out. All it takes is one attempted startup in gear with the clutch out for this to become a very expensive experiment. |
10-01-2015, 12:52 PM | #27 |
Rep 1,338
have more people been trying this? i'm waiting the requisite 6 months before i try it... just hoping others who are less risk-averse are trying this now? i'm not an early adopter, but am very hopeful about this. sport plus is not an acceptable solution for me.
10-05-2015, 07:38 AM | #28 |
Rep 5,316
Drives: G80 M3 6MT
I've read about issues with disabling the clutch start lock on the older model cars, gotta google around to see what the issues were though.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
11-02-2015, 09:11 AM | #29 |
Occasionally frequent poster
3000
Rep 2,744
Yippee!!!
Thanks KiteSurfer, for the informative post. I can confirm that this worked great on my F30 340i.
I tried coding both off, clutch and brake, and it was weird. My car wouldn't start. You have to push the starter button twice, and even then, the automatic starting sequence wouldn't work. Normally, if you hit the start button briefly, the starter will engage for about a full second even though you are no longer pressing on the button, to start the car. But if you code both pedals off, that feature no longer works and you have to hold the button down until the engine catches. I could live with that, but not the double press. It just confuses me. Plus, even with both clutch and brake inactivated, you still need to push the clutch pedal in to start the car, regardless of anything else that you do. There are a lot of neat other features that can be modified if you decide to do this. Now, if you have an older car than me (mine is a 2016) the features may not be available to you, but I did stuff like remove the iDrive disclaimer, added actual speed to the OBC display, added tire temperature to the TPMS display (awesome!) and some other trivial things. Just be careful. There is always the possibility of hosing the ECU if you make a mistake, click the wrong button or change the wrong parameters.
Current inventory:
F22 & G05 Cadillac CT5-V Blackwing w/3 pedals Past: E24,E28(3),E34,E36,E37,E38(2),E39(4),E46,E89,E92 (obviously),F01,F06,F10,F30,F87,G12,G30(2),G82(2) |
11-02-2015, 06:15 PM | #30 |
FLY NAVY
26
Rep 61
Inadvertent actuation
Similarly, I've been rolling for the past 3 months with rev matching disabled - but difference was I was unsure which coding action affected the change. As LuvMyE92 pointed out, coding both clutch and brake causes a major change in the start sequence, so much so that the first start attempt after coding caused me to think I had done irreparable damage to some segment of the ECU. As with the rev matching though, I'm finally accustomed to pressing the start button once and then holding it until the engine catches.
In all honesty, the lack of rev matching has made me a more precise and better driver, as there is more of a "penalty" for each shift in that they require more attention, a limited commodity while driving. Therefore, I find myself plotting out downshifts much further out, and making fewer of them. My throttle control is much better for it though. However, I do miss the option of using it when tired or just lazy, and find it unconscionable that the option would not be made available through a defeatable switch or at least through iDrive, as a hundred other less important options exist. OP: Good catch. If I had done the coding as it should be done, i.e. one step at a time, with a detailed evaluation of the results, this would have been documented a long while before. Reinforcing the eternal lesson: be careful while coding
ED April 2015 - F80 M3 YMB Executive & Lighting Package, 19's, 6MT M Performance Exhaust, 275/35&295/35 PSS
FLY NAVY |
11-06-2015, 04:37 PM | #31 |
Rep 763
I'm surprised not more 6mt drivers tested this yet
I would be super annoyed if my 3 pedals car doesn't allow me to rev match on my own except in Sport+ mode I also found this post from here - http://f80.bimmerpost.com/forums/sho...&postcount=197 Any truth to this? |
12-09-2015, 12:06 AM | #32 |
You got my money?
3159
Rep 4,646
Drives: Ice Cream Truck
Did anyone figure out how to add rev match to Sport plus?
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
biggripper726.50 |
01-17-2016, 07:09 AM | #33 |
32
Rep 77
biggripper726.50 |
01-17-2016, 11:35 AM | #34 |
Rep 10,176
Seems like an easy way to money shift on the track to me by coming close to the 2nd gear gate when grabbing 4th, but it is probably possible. It atuates the blip when approaching the downshift gate, not when you start to disengage the clutch.
I found myself heel/toeing anyway, even with rev matching enabled. As mentioned, muscle memory is strong. I can say that 90% of the time, the car was quicker than I was on the blip, so most of the time, my downshifts were two blips. I did get used to it, and found that I could "turn on" heel/toe in Sport+. |
02-25-2016, 07:34 PM | #37 |
Rep 477
04-16-2016, 10:09 AM | #38 |
Rep 1,922
Drives: 2011 e91
Has anyone gone more into depth with this? I'd like to be able to retain the rev match feature just for comfort, then have it disabled in sport/+ modes.
2011 E91
2016 M2 - Sold 2014 X1 - Sold 2002 Land Rover Discovery II - 3" lift & 33s |
04-20-2016, 02:34 PM | #39 |
Rep 1,338
still following this. still too big a wuss to be the guinea pig. still itching to do all my own matching before my footwork suffers. thankfully i still have the 135i to keep my teeth sharp, but that'll be for sale soon, making the m4 my only manual car!
04-20-2016, 08:19 PM | #40 |
235
Rep 390
I'm curious also. It would be nice to be able to rev match myself when I track the car but sport plus is way too aggressive for track use in my opinion.
06-26-2016, 07:02 PM | #41 |
FLY NAVY
26
Rep 61
I can confirm that disabling rev matching as in the OP's post works. I liked it enough to code it back on though.
FLY NAVY |
07-11-2016, 07:25 PM | #42 |
Rep 49
Nice
You buy $70K car to disable/enable some features to get $30K car. It is not easy to enable/disable it sometimes, but you are so persistent.
Of course, cars are not the same, you cannot drift with $30K. BMW does need to worry with that kind of buyers. |
07-11-2016, 07:31 PM | #44 |
2712
Rep 2,371
You, sir, are an idiot.
