Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      03-17-2017, 09:06 AM   #1
dbperformance
162
Drives: None
Coding F82 GTS Rear Lights
Hi,
What's has to be coded to activate the BMW M4 GTS Rear Lights on a BMW M4 F82? Can this be done with esys?
Do i need to add any VO code?
Thank you!
      03-17-2017, 10:30 AM   #2
Cybertronic
48
Drives: G30 M550i, E30 M3
Its a hardware difference... OLED Tail lights
I'm sure you could retrofit for $$$
      03-17-2017, 03:40 PM   #3
dbperformance
162
Drives: None
No coding needed. Works with the same connectors. Only need a harness to fit it all..
      03-23-2017, 10:33 AM   #4
dbperformance
162
Drives: None
Flashing lights are not working. Has this to be coded? Dealers wont do it because no original GTS...
      03-23-2017, 10:50 AM   #5
euro*
euro*'s Avatar
1658
Drives: F90 M5
where were you able to find those lights? and how much?
      03-23-2017, 11:22 AM   #6
packet.pilot
Drives: test mule
Why don't you just VO code them with a modified FA?
      03-23-2017, 12:40 PM   #7
dbperformance
162
Drives: None
But I need to know the VO code. Otherwise I can't code it haha.
Anybods knows where to find it?
      03-23-2017, 01:27 PM   #8
packet.pilot
Drives: test mule
4S91 for EU and 4S93 for US variants of GTS.
Change that in your FA, be sure E-Sys isn't set to write it back to your VCM, and then VO-code the appropriate module(s), which I'd imagine would be REM.
Nothing you need to know other than Typeschlussel.
      03-23-2017, 02:00 PM   #9
dbperformance
162
Drives: None
Thank you so much! I will give it a go these days.
Do I have to remove the original VO of the oem lights?
Thank you!!!!
      03-23-2017, 02:04 PM   #10
packet.pilot
Drives: test mule
Thank you!!!!
I think you might be confused about what VO-coding is, but maybe you aren't.
If OEM lights had an option code, then there'd be some removal necessary. Since taillights are, from what I understand, based only on zeitkriterium (possibly) and typeschlussel (definitely), oh, and chassis code (kinda), then in this case, no, there's no removal of anything necessary.
Good luck! I'll have my hands on a GTS for the first time (hopefully) sometime this week, and might be able to grab some FDL code captures for you if absolutely necessary. (I'd wager it's not.)
      03-23-2017, 02:08 PM   #11
dbperformance
162
Drives: None
To be sure: vo coding is like changing a normal transmission to a sport transmission? Edit the FA and add the VO code to the list and code the modules, right?
Like this: http://www.bmwesys.com/guides/VO%20C...ep%20Guide.pdf
Nice! Looking forward to hear more!
Thank you for the help!
      03-23-2017, 03:27 PM   #12
packet.pilot
Drives: test mule
Yes, it's like that.
In your case, I'd imagine REM would need to be involved, potentially also FEM_BODY, but with that said, I've read elsewhere that GTS taillights are plug-and-play (although I have no first-hand experience to say whether that's true), so there's a chance that the modules just need to be 'taught' in ISTA aka Rheingold... so tbh that's where I'd start first, personally.
      03-30-2017, 01:10 AM   #13
danielxzy
danielxzy's Avatar
China
Drives: m4
same here, need coding.....
2015 F82 M4 DCT
      03-30-2017, 04:28 AM   #14
dbperformance
162
Drives: None
I didn't find the solution yet. I have a vin of a GTS, but don't know how to do coding...
      03-30-2017, 09:00 AM   #15
StigJr
StigJr
Drives: 2017 F80 M3
http://ind-distribution.com/ind/cate...tail-light-set
      03-30-2017, 06:45 PM   #16
packet.pilot
Drives: test mule
Again, why don't you just VO code them with a modified FA for the GTS?
While this may seem like a pedantic response, it's simply a plea to consider the far simpler approach.
      03-30-2017, 10:36 PM   #17
danielxzy
danielxzy's Avatar
China
Drives: m4
Originally Posted by kurai View Post
Hi, care to share where one can get these lights from and price? Many thanks!
Its very very expensive
2015 F82 M4 DCT
      03-30-2017, 10:37 PM   #18
danielxzy
danielxzy's Avatar
China
Drives: m4
i dont think vin gonna help.
2015 F82 M4 DCT
      02-18-2024, 11:43 AM   #19
bertocolon
bertocolon's Avatar
Drives: 2019 M4 Comp
[/url]
I just got my set of OEM GTS OLED's and I have a 19' LCI, I just need some help with properly coding these? Can anyone help with the assist? or Can I do this through Bimmercode myself? or Is there someone you can recommend to help me do this?
Thank you!
      04-08-2024, 12:19 PM   #20
darrelwatson46
Drives: 2014 M5
Ever find out info about coding? Have a friend who is in the same boat and trying to see if I can code it for him with Carly or Bimmercode.
Thanks!
Originally Posted by bertocolon View Post
[/url]
Thank you!
      04-08-2024, 11:26 PM   #21
WhiteFox
WhiteFox's Avatar
108
Drives: BMW M4 F83
Thanks!
You can’t code them in with Carly or Bimmercode as you need esys to do this. This is only really if you want the start up animation. Else will work just fine if you have LCI lights on the car already. Note you need to install the correct wiring harness as well if you want the start up animation as well.
coding, f82, gts, lights, oled
f80post
