Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - NY / NJ / CT / PA > *WESTERN NEW YORK* because we don't seem to exist without this thread...
      01-14-2019, 08:10 AM   #1849
Jpullen
Guest
n/a
Drives:
New Poster Here. My friend is up in Ithaca with her 09 328XI and is having some motor troubles. Sounds like Eccentric shaft sensor. Does anyone know of a good BMW mechanic around Ithaca. I typically fix the car but It’s a little far for me to drive at this point and shell be there for a few more years,
Thanks
      02-07-2019, 09:16 AM   #1850
E91xi
Drives: E91 325xi 6spd
Thanks
there is The Little Speed Shop in Rochester just a short trip north.
      02-20-2019, 10:00 PM   #1851
blueliner
22
Drives: E92 6MT - All black everything
There's also Cantech in Syracuse.
      03-25-2020, 09:48 PM   #1852
sleeeper335
23
Drives: 335i
hey everyone! im back with any n54 anyone still around?
      03-26-2020, 05:39 AM   #1853
Devildog0905
Drives: 2007 BMW 335i Coupe
2007 335i e92
Farmington, NY
      04-21-2020, 04:16 PM   #1854
sleeeper335
23
Drives: 335i
Anyone have a stock 335 exhaust laying around? I need the first section.
      05-04-2020, 10:32 AM   #1855
Becken_e90
Becken_e90's Avatar
Drives: 2011 328i E90 N51 6MT
Hey everyone, 328i e90 from Rochester here. Just posting up some work I recently did for maintenance during Covid-19 quarantine.
I upgraded front and rear control arms to M3, b4 bilstein shocks with Eibach lowering springs, rebuilt brake calipers and powder coated gloss black with zimmerman rotors and akebono ceramic pads, powder coated to sparkle silver the stock 17" rims, engine mounts. Also finally got to replacing oil leaks with the following gaskets: oil pan, oil level sensor, valve cover, spark plug wells, eccentric shaft sensor, oil filter housing. Not all these were leaking. My PCV system still seems to be functioning properly so I didn't replace my valve cover for ridiculous amount of money. I also had an exhaust leak at the flange connection after the cat that I had to remove the welded bolts with acetylene oxygen torch and replaced bolts. I have the stock exhaust and pretty much everything else on the car for that matter is stock. It's my daily driver so this was for maintenance to keep her going for some time hopefully.
I inspected the DISA valve as I know this can fail but it looked solid. Other near future maintenance items I have my eye on include output shaft seal and gear shaft selector seal replacement, one or both of them are leaking. I will also keep an eye on the rear main seal as it was hard to tell if that was leaking due to oil being everywhere from the oil pan gasket and other leaks. One thing for sure is these e90s like to leak oil!
haha yeah wny rulz!, i hate rental cars, snow seriously? fuuuuuu, tri-state chat>this, west ny = pa, where are my winter tires, wtf no fries?!?!, you mean canada?
