2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Custom N55 air intake journey
      09-05-2019, 11:39 PM   #1
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
This is an experiment to see if I can make a decent air intake under 200 bucks. The mission is to increase time to spool and make a hybrid ram/cai intake. As we know the air ducts for the F10 N55 is a poor design from the standpoint of tuners like us. The intake starts by entering a 90-degree entry with no scoop, then takes a long path through the driver side around the hot engine bay and back down to yet another sharp turn into the turbo. If you're like me with a large fmic this makes for some horrible lag.
Since the F10 N55 shares the same body as the 550 and M5 there's another air entry passenger side that is much closer. I'm not sure why BMW decided against using that as the air intake entry for the N55 as it would seem it would've been cheaper in parts and added sportiness.
I'll be using a heat gun, some silicone couplers, black silicone adhesive, a U shaped plastic intake from a VW, and some spare N55 intake parts to dismantle and cut up. I'll be placing the same order of sensors and valve connectors and fusing them into the plastic.
Here's some preliminary photos. I'll be updating the thread as I make progress.
Here is the updated progress on the fitting the fuel vent and crankcase valve:
I never measured the exact circumstance so make the hole smaller then the crankcase fitting and carefully sandstone Dremel until you get a tight fit.
You have to very carefully Dremel underneath the lip. I used a small cutting Dremel tool and shaved it very carefully.
This is a 3/4" drill bit. You do not have to Dremel the hole afterwards as this is a perfect fit.
Warning: I am getting air plausibility errors. It will have to be tuned out.
101F01 Pressure too high
Yeah it is lol!
How to build this intake thread coming soon.
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles
Appreciate 6
      09-06-2019, 07:53 AM   #2
ziekxq
Drives: 2011 535i xDrive
Lemme know how it goes. I am wanting a new intake too like that!
      09-06-2019, 09:27 AM   #3
NYC535iowner
56
Drives: 2013 535i X-drive
keep up the great work idea and keep us posted. I thought about the same issue when it comes to the air coming into the turbo. It has to travel all over the hot engine bay before entering the turbo. But you have to understand that the car primary purpose wasn't for performance but more for luxury.
13'- F10--> Work in progress: V-Style front lip, HAMANN roof spoiler, M5 grill, high kick trunk spoiler, H&R sport springs, C-quence Drilled front rotors, VRSF Catless DP, VRSF charge pipe.
      09-06-2019, 12:34 PM   #4
BimmerHausPerformance
BimmerHausPerformance's Avatar
514
Drives: 2011 535i 6MT
2011 BMW 535i  [0.00]
I am very interested here. What are you doing for an air filter? Will that be a cone at the end of your intake?
Can you get any more pics of where the ram intake will end up?
Could it go in front of the radiator behind a mesh grille? that'd look sweet.
I love it.
      09-06-2019, 01:42 PM   #5
Henry.Serem
Kenya
Drives: BMW F10
Following closely, awesome job. I would like to replicate
      09-06-2019, 03:46 PM   #6
514
Wait, is this also replacing the turbo inlet as well? That is very restrictive if so this is a 2 for 1.
Also what about some of the vents that go into some of the tubing you are replacing?
      09-06-2019, 07:53 PM   #7
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Thanks, guys for all the support. As I'm chopping up stock pieces it's a little unsettling but they are spare parts so if I mess up the only harm is I spend a little more money getting new parts and loss of time. I'm happy to share the info I have now if anyone wants to follow along. I will disclose I've gotten a few things wrong so I was waiting to get all the parameters right and then share. If you want to try to catch up and follow along here's a shortlist.
- 2016 VW Passat intake
- Spare F10 intake
- Silicone coupler 2.75 to 2.5 connecting to the turbo intake
- 45-degree coupler 3.5 to 3 pointing into the air entry from the grill
The final parts I'm waiting for are
- black 3" 90 degree piping 12" in length
- elongated air cone
- heat shield for cone and additional material that extends the cone shielding and doubles as a scoop
BrowBMW the cone will be behind the grill. The custom heats shied scoop will be dope too! Also, in the pics you can see I will be attaching the custom inlet from AZ-MCRacer
Here are prelim photos of the upcoming air filter but not modified, yet.
IG: @bmwdoubles
ey2001310.00
      09-06-2019, 08:19 PM   #8
ziekxq
Why do you need heat shield if you are planning on putting the cone behind the grill?
      09-06-2019, 08:34 PM   #9
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
The heat shield is really a scoop in my case
IG: @bmwdoubles
      09-06-2019, 08:43 PM   #10
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Here's a frontal look in the VW intake. It has that Squared shape on one side, but the 3.5 coupler is a tight fit and seals it up nicely.
Also here's a closer look at my gorilla glues/ plastic tack weld/ black silicone adhesive
IG: @bmwdoubles
      09-06-2019, 09:33 PM   #11
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Awesome bro! This looks to be a great mod!
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~
Follow me on Instagram: lsturbointeg
      09-07-2019, 12:55 PM   #12
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Thick bead of flexible glue around the valve connectors. Looks ugly but I don't want the glue drying up and popping off under intense heat by the turbo. We'll see...
Next is the MAF sensor and cone by the grill and hopefully spool time dramatically increases.
IG: @bmwdoubles
      09-07-2019, 01:09 PM   #13
bake
bake's Avatar
Drives: 2011 F10, 2013 E93
Following. I have been waiting 6 years for an intake behind the grill so we can really get to hear that growl. Hoping this works out!
Bake
2011 Alpine White on Black 535i M-Sport
2013 Space Gray on Fox Red M3 Vert
      09-07-2019, 01:46 PM   #14
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
$howtime456 has a custom solution too. Mine theoretically should. work without error. I'll share the final details tools needs, hardware, etc once it's complete.
Also if it works out maybe I'll have it 3D modeled and people can print their own.
IG: @bmwdoubles
ey2001310.00
      09-07-2019, 02:38 PM   #15
ey2001
ey2001's Avatar
310
Drives: F10 535i 6spd
That would be awesome!!
      09-07-2019, 03:38 PM   #16
ezaircon4jc
ezaircon4jc's Avatar
Drives: 2019 540i M Sport
You also need to get it CARB certified so those of us in the PRK can use it!
      09-07-2019, 04:31 PM   #17
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Part of this experiment is to use a secondary set of hardware so come smog time just throw your stock gear back on with 0 modifications to get it back to original.
IG: @bmwdoubles
      09-08-2019, 03:14 PM   #18
$howtime456
$howtime456's Avatar
301
Drives: BMW 640i
G]https://scontent-lga3-1.xx.fbcdn.net/v/t1.0-9/54729963_10213497510847360_7169012436702330880_n.j pg?_nc_cat=108&_nc_oc=AQnW5iNoxeJV1tSmQqS1K179o_p3 tERPpk1_keZ3gGFprkoY3EJt2UkEWpumwABGmZg&_nc_ht=sco ntent-lga3-1.xx&oh=6fd78f85bc8e507ff05106be6b9fb7f7&oe=5DFB58 BB[/IMG]
N55 GENERAL
David Shoup Tuned
Fully Built By Miami Engines/Project Motorworks
Precision 6266 On Steroids
      09-08-2019, 03:18 PM   #19
$howtime456
301
Drives: BMW 640i
this was my prototype made. since then i went 4 inch skunk 2 velocity stack intake. Intake has a hole cut out on top of the cone to suck in the air. Good job BMW DOUBLES. Great effort and doing it for less than what i paid. This is a night and day difference especially upstairs. The sound is amazing at that.
N55 GENERAL
David Shoup Tuned
      09-08-2019, 04:58 PM   #20
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Dope setup $howtime! I went 3" because that is the width of the air entry and I don't have to cut any metal.
I think you $howtime456 and AZ-MCRacer have the fastest F10 N55s on the boards right now. I'll catch up once I get my fuel situated.
IG: @bmwdoubles
      09-08-2019, 06:45 PM   #21
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Creating the new harness extension is going to involve cutting the existing. Unless someone knows the female back to male connector for the MAF.
Here's what is needed:
- 16-18 gauge wire
- wire strippers
- Tesa wire loom tape
- electrical tape
- heat shrink tubing
- heat shrink butt connectors ( I'm not soldering )
- protective wire wrap
- heat gun
- test subject F10 MAF intake adaptor
IG: @bmwdoubles
      09-08-2019, 06:52 PM   #22
ezaircon4jc
this was my prototype made...
My OCD (or is it CDO?) couldn't handle a visible intake on one side only. I would need one on each side.
5post
