11-26-2019, 07:04 PM | #1 |
Rep 1,233
Steering wheel shake - new front wishbones, what else?
Got a bad steering wheel shake when braking, pedal is smooth (new brakes all around), diagnosed as worn out control arm bushings on the wishbones at the front.
I'm looking at this kit, as it's not much more than the standard replacements: https://www.fcpeuro.com/products/bmw...rade-bmwmcakit All other parts seem OK at the moment, is there anything else I'd require to put this kit in or that everyone highly recommends? I've got approximately 170K kms on the car, Bilstein B12 suspension with Dinan fixed camber plates. 2010 128i. Thx in advance. |
11-27-2019, 08:38 AM | #2 |
1Addict
3239
Rep 7,903
Have you done the rear guide rods or a toe arm? I'd recommend doing front and rear 1M/M3 arms at the same time so as not to upset handling balance. Standard M toe doesn't fit, but there are plenty of spherical and rubber options such as Megan and Rogue Engineering.
asbrr544.50 |
11-27-2019, 10:04 AM | #3 | |
Rep 1,233
Have people been running just the front M-arms without the rear upgrades? Trying to assess the balance concern in terms of what the car will feel like with just the front. Main reason I'm considering the front M upgrade is that it was almost the same price as the stock replacements. |
11-27-2019, 10:07 AM | #4 | |
1Addict
3239
Rep 7,903
asbrr544.50 |
11-27-2019, 12:33 PM | #5 |
Rep 1,233
Got it - thanks. Gonna look into it now, this year has been rough - did the AC evaporator, fresh brakes all around, etc etc. The car is bleeding me dry but I guess I'm into it for another couple of years at this point
11-27-2019, 02:16 PM | #6 |
2183
Rep 2,806
I also ran front M arms only for awhile and noticed nothing negative. Eventually did just the rear M guide rods. From the famous fe1rx OE vs M thread I gathered that was most bang for the buck.
E82 / BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
11-28-2019, 09:40 AM | #7 |
Rep 1,233
Thanks guys. I went ahead and ordered the kit (Black Friday discount).
I'm going to run the kit at the front by itself for now. This has not been a cheap year lol, for guide rods I'll see how it goes next year. |
01-07-2020, 08:47 PM | #9 |
Rep 1,233
Honestly - not many places. BMW Mississauga/Pfaff gives a decent discount to TrueNorth and BMW Trillium members. Otherwise mostly online for me. Check the Canada forum there was a post not long ago summarizing a few local places that had decent prices.
01-07-2020, 08:51 PM | #10 | |
Rep 1,233
Front end is definitely "tighter", downside being you certainly "feel the road" more, bumps have more harshness to them. All in all if you're not really going after that extra camber (ie only street driven vehicle) and you have rough roads, stock arms are fine and probably what I should have gone with. The steering wheel wobble is gone, and now replaced with a new wobble. Mostly likely due to the not so high quality front discs I put in (DURA from rockauto - great because they are cheap, 2 piece, and have aluminum hats but questionable metallurgy). I think there is some pad deposit on there - will do a full re-bedding in when I have my summer tires back on....for now just living with it. |
gjm1202183.00 |
01-07-2020, 11:30 PM | #11 |
9
Rep 46
I believe wobble should go away after re-bedding of front brakes.
I will check for parts with pffaf and online. Where did you source shocks from, if you remember. |
01-08-2020, 08:48 PM | #12 | |
Rep 1,233
https://alphamotorsports.ca/ |
