      03-04-2023, 12:29 PM   #1
iliketurns
21
Drives: 128i slicctop
18x9 ET 51 Square Setup
Ok I'll preface this with saying that yes I searched I promise
I picked up a set of 18x9 ET 51 square Advans for my 128i thinking that they would work but just barely. I did not think about different coilover types when making this decision and how they impact fitment. I have Bilstein B14's on the car. I am planning to run a 245/35 square tire all around. 200tw so it will probably run a bit wider than advertised.
Does anybody know if I would be even remotely close to fitting without rubbing? I have camber plates on the car so camber adjustment isn't an issue. From what I was able to gather maybe a 15 mm up front and 5 In the back
Thanks in advance for the help!
      03-04-2023, 01:29 PM   #2
bnace10
Drives: 2011 E82 135i DCT Lemans Blue
The rear should be completely fine, but definitely need some spacer up front.
      03-05-2023, 12:44 PM   #3
Eyeman
Eyeman's Avatar
122
Drives: 2008 135 blk, blk, step
The front will be very hard to get to work. Probably need around an 8mm spacer and then you'll have to run enough camber to tuck the wheel in that would be like 12mm poked out too far. 3 deg of camber might make it work.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
      03-08-2023, 08:45 AM   #4
iliketurns
21
Thanks. Yeah that's about what I was gathering from other people's 17x9 setups. My fenders are rolled a bit but not sure if that would be enough. These cars are finicky with fitment lol
